ans still
is there a way to install it by an other way?
Sorry you’re still having trouble @Xsto4 - I don’t know what we’re missing here.
I see you’re now trying to use the haos_generic-aarch64
image. I think you should be using the haos_ova
, but that’s not the issue here.
I’ve posted your error in the TrueNAS forum to see if anyone there can help.
@Xsto4 I just noticed you’re using the zsh
shell - I don’t think that should matter, but let’s try using bash
instead.
To avoid confusion, let’s first remove the previous files you downloaded and start again.
rm haos_ova-12.4.*
Next, switch to bash
bash
Finally, try again (I’ve used your new APPLICATIONS/ha
ZVOL below)
wget https://github.com/home-assistant/operating-system/releases/download/12.4/haos_ova-12.4.qcow2.xz
sudo unxz haos_ova-12.4.qcow2.xz
sudo qemu-img convert -O raw haos_ova-12.4.qcow2 /dev/zvol/APPLICATIONS/ha
I would have been surprised if using a bash
shell would have helped, but it was worth a shot.
Anyway, someone replied to my post in the TrueNAS forum.
I’ve seen the device fail to be constructed at the location, especially when under load.
I suspect if you
ls
the location, you won’t see the device.Suggest a reboot.
Let’s try their suggestion. The following will recursively list any ZVOL located in /dev/zvol
- Please share the output after running this command.
ls -R /dev/zvol
Then, try rebooting your TrueNAS server and run the command again. When we see your ZVOL listed using the ls
command, the HAOS installation should work.
Ok, I think I see it now! It looks like APPLICATIONS
has a space after it.
Try this
sudo qemu-img convert -O raw haos_ova-12.4.qcow2 "/dev/zvol/APPLICATIONS /ha"
That looks like a winner!
i will try to pursuit the install and see if it worked ! thx again because my app dataset is already set with my files
finally !
after get my truenas unreachable this morning ( bad bridge setting), reset and new zvol cause to erase bad vm setting i got this
thx troy for the support !
i have the same issue, i’m logged as root because is the only login that i have
unxz: haos_ova-13.1.qcow2.xz: Unespected end of input
qemu-img: Could not open 'haos_ova-13.1.qcpw2': Could not open 'haos_ova-13.1.qcpw2':No such file or directory
root@truenas[]
i also tyed using these command line but nothing
sudo wget https://github.com/home-assistant/operating-system/releases/download/13.1/haos_ova-13.1.qcow2.xz
sudo unxz haos_ova-13.1.qcow2.xz
sudo qemu-img convert -O raw haos_ova-13.1.qcow2 /dev/zvol/tank/vm/haos
how can i remove the old files?
Looks like a corrupt download. You can remove old files using
rm haos_ova-13.1.*
