Installing HAOS on Raspberry pi 3 B 1.2 failed
Hi, I’m trying to install HAOS on a Raspberry Pi 3 B 1.2. Followed the instructions but when I insert the flashed SD the pi won’t boot. It flashes the green led 1 time and then nothing happens. The Ethernet leds are dead and when I check the monitor output it remains black. I tried the Raspberry pi OS and that just boots fine. Also the Ethernet and I can reach it with SSH.
I read more people have this issue but I can’t find a solution. Hopefully someone knows what’s going on. Thanks!
Seconding this, exact same scenario!
Tested with PI OS works perfectly.
Following the instructions and flashing succesfully but get black screen, no ethernet lights, can’t find a way to connect to it.
Tried OS 9.3, 64 bits, 32 bits, 9.2 32 bits, 8.5 32 bits. no avail. Please help.
SD Card install
