I had the same issue where my RPI was so slow with SSD that it was unusable. Your recommendation to try out the different USB to SCSI adaptor solved my problem.
USB to SCSI – Benfei USB 3.0 to SATA III Hard Driver Adapter w/UASP Compatible for 2.5 inch HDD and SSD
Replaced USB to SCSI with (as you had recommended): StarTech.com USB 3.1 to 2.5" SATA Hard Drive Adapter - USB 3.1 Gen2 10 Gbps with UASP External HDD/SSD Storage Converter (USB312SAT3CB), Black
Does anyone know if I can use Balena on my laptop and flash home assistant is to ssd on the argon 1 m2 case? I have to return the m2 ssd because the argon 1 requires a key b or b+m ssd.
Just trying to figure out if I also need to buy a usb ssd adapter or flash directly to the ssd in the argon through usb attached to laptop. Or even clone from sd.
And then bought a USB 3 male A to male A. Hooked up the bottom of the argon case and flashed the latest (today) 64 bit RPi4 for the 4gb. Everything was fast. I was up and running within 20 minutes.
Just plugged in my husbzb and it must have an internal memory since it retained all my zwave and zigbee devices. Just had to rename them.
This is so much faster than the Pi 3 I initially was running. That one is going to be setup at my parents place. I think eventually it may get replaced by a Pi 4 or 5 whatever is out then. And of course with an ssd.
I have a PI4 with 128Go SD card running HASSOS and just switch to a yKingston 240Go SSD. It works but I do not see any perceptible improvement in speed.
Before the move, I did not have any speed issue except when I restart HA which took quite a moment to perform. After the move, … well … it is the same.
I will keep the SSD since it does not cost much but wonder if it was worth to switch.
Well, then there is nothing left to create act load for the SD/SSD. Then it is logical that you don’t see a difference. HA’s history is the one component that creates the majority of disk writes.
The good news is: With SSD you can turn history back on for all of your entities without a noticable performance penalty.
Because I wrote this guide and want to give feedback to you and to @agners early. ;D
I also hope that v6 might solve some of the problems that other users have described here. (Although the author says in his posting that these issues are still hard to track down and not yet specifically addressed.)
Beside that - no, there is no reason for me to upgrade. My system performs exemplary for over 2 years now on all versions from OS 5 dev till 6 rc.
would like to run 32b as i encounter problem with the raspbee2 connected to the gpio
and esphome seems not to be working OS 6.0.rc1 32b variant also wont boot in 32b
32b version on my Pi3b with SSD runs flawless but i really want to upgrade to Pi 4 with USB 3.
Can anyone tell how to boot with the 32b
or tell me how to get the raspbee2 working on the 64b os
My nodes are online and in the log it is running
my flashed Xiaomi BLE sensors are also sending data which is visible in the log
but somehow the data is not pushed through to the entity values. they remain on Unknown
Flashed HASS.io onto Kingston A400 2.5″ SATA SSD with StarTech 2.5″ SATA to USB 3.0 Adapter.
0b. I had issues with networking, so I added wifi config for first setup. My network is a little complicated. you may not need to do so
Using the RPI Imager, I created a bootloader reset, that read from usb first and sd second.
Shutdown
Removed the SD
Attached the Kingston A400 2.5″ SATA SSD with StarTech 2.5″ SATA to USB 3.0 Adapter
Attached a USB extension cable to my conbee II.
Started up and let the installation happen as usual.
6b. After setup switched to Ethernet cable.
Home Assistant OS 5.13 on RPI4
StarTech 2.5″ SATA to USB 3.0 Adapter with Kingston A400 2.5″ SATA SSD
NOT working: Adata SSD my previous ssd
Super stable and fast for 2 weeks, no issues rebooting and upgrading the supervisor or installing etc.
