Hi - have you had any success with this?
I am a newbie, have just installed HA via docker which already seems like a major accomplishment
But now I donāt seem to be able to install HACS. It says that the version is too old.
INFO: Verifying versions
INFO: Current version is 2023.4.6, minimum version is 2023.6.0
ERROR: Version 2023.4.6 is not new enough, needs at least 2023.6.0
Did anyone manage to install HACS on HA 2023.4.6? Did anyone have luck installing 2023.6.0 on WD My Cloud Ex2?
Hi, new noob here. i followed exactly your protocol (install from cloudsmith, connect to portainer.io, add stack, docker compose web, insert text, deploy). It starts than stops and give an error back: write /var/run/docker/containerd/daemon/io.containerd.runtime.v1.linux/moby/a24c92936a7ab3db75387bdade1d3306b51abf95c0f8fa4f4c626bc2df92f7bc/config.json: no space left on device: unknown
I also get a deployment error on one packet somewhere there: 6131f554f803 Extracting [======> ] 49.58MB/400.3MB 6131f554f803 Extracting [======> ] 50.14MB/400.3MB 6131f554f803 Extracting [======> ] 50.69MB/400.3MB
Has anyone a tip for me? i tried a lot of different packages. I even clean my images with the docker command docker system prune -a -f using ssh connect through macos terminal.
Hey guys! Thanks a lot for helping me installing linuxserver/homeassistant:2023.4.6-ls141 on my ex2ultra. Did anyone manage to install a later version? Did anyone manage to install HACS? Thanks a lot!
