Yes I understand that the RPi4 is underpowered. My production HA system is running in a NUC i5 flawlessly. But that is still a docker system. I want to move that to a Proxmox 7 install. But in order to do that I thought I better could get some experience with Proxmox, since that is new to me.
Thatโs why I wanted to create an test/development HA system in Proxmox in an RPi4 which I have for this purpose (It has an ssd and runs HA/test in Docker).
But searching for How-Toโs on RPi4, I found only negative advices to take this path.
Thatโs a pity, I have to find an other way to make myself familiar with Proxmoxโฆ
Thank you for your reactions.
BTW, I shoud have read in the first line of your tutorial that it was meant for X86/64 machines. Sorry.
Kind regards, Bert
Anyone else having issues with a clean install? I keep running into the dockerhub rate limit, even after creating an accout (to increase the download limits). Is there any way to pace the installation to fall below the limit?
Further investigation revealed the Netgear router (R6260) only sends out itโs own ip address as the DNS nameserver address. The timeouts built into upgrading or installing add-ons are short enough that passing the DNS requests thru the router first cause the requestes to time out and never complete. The workaround is to use the home assistant cli interface to set the ipv4 interface to static, which enables setting static dns servers for HA directly. I set them to 1.1.1.1 (cloudflare dns) and everything completes successfully.
@kanga_who May I know how is the CPU usage for your HA VM? I have an old HA VM with Proxmox 6 in an old notebook. It was running very well till few months back when the CPU usage is always hovering around 90-100%. I used 2 cores of CPU. When it was doing fine few months back, the CPU would be around <25%.
Thinking something could be wrong, I installed Proxmox 7 in a newer Dell 7080 micro I recently bought and again use the script to create the HA VM. With HA being totally bare and I have not setup anything yet, below are the CPU usagesโฆ
Not sure what is wrong in that VM. I have not changed any settings so far except upgrading versions. Looks like now I have no choice but to force myself to move everything to the new 7080 micro. Hopefully everything will turn out fine.
Update: Moving to the new system did not help after I configured network. As I have 3 networks that HA is connected to, the mDNS implementation of HA was causing issues even though I have not changed any settings previously both on my network and HA. I now have resolved the problem with a very simple fix that I mentioned in the other thread (Setup VLAN and HA tutorial - #66 by skull29). Hopefully it helps anyone encountering the same issue as me
@kanga_who this might be a stupid question, but is there a reason why you recommend putty instead of using the Shell option that is available within Proxmox?
