Open 2 SSH sessions. In one, tail the homeassistant log and in the second journalctl -f
Your snapshot size is 0.1 MB. Thatās 100KB. Way too small for a correct snapshot. The snapshot itself is the problemā¦
Redo it. Retransfer it. You can also open it on your PC (it is a compressed tar file) to check whether the content looks ok.
GV
The snapshot was that small because it was a test. I did a fresh install of proxmox and home assistant. I just installed one addon made the snapshot and then removed the addon. Then I tried to restore the snapshot (with one addon) to an empty home assistant.
Iām not sure it this is what you ment but this is what I have done:
1 open ssh to promox as root ang gave command journalctl -f
see log below
root@pve:~# journalctl -f
ā Logs begin at Sun 2020-08-23 09:21:21 CEST. ā
Aug 23 10:07:29 pve systemd[1770]: Listening on GnuPG cryptographic agent (ssh-a gent emulation).
Aug 23 10:07:29 pve systemd[1770]: Reached target Paths.
Aug 23 10:07:29 pve systemd[1770]: Listening on GnuPG network certificate manage ment daemon.
Aug 23 10:07:29 pve systemd[1770]: Listening on GnuPG cryptographic agent and pa ssphrase cache (restricted).
Aug 23 10:07:29 pve systemd[1770]: Reached target Sockets.
Aug 23 10:07:29 pve systemd[1770]: Reached target Basic System.
Aug 23 10:07:29 pve systemd[1770]: Reached target Default.
Aug 23 10:07:29 pve systemd[1770]: Startup finished in 59ms.
Aug 23 10:07:29 pve systemd[1]: Started User Manager for UID 0.
Aug 23 10:07:29 pve systemd[1]: Started Session 5 of user root.
Aug 23 10:08:00 pve systemd[1]: Starting Proxmox VE replication runnerā¦
Aug 23 10:08:01 pve systemd[1]: pvesr.service: Succeeded.
Aug 23 10:08:01 pve systemd[1]: Started Proxmox VE replication runner.
Aug 23 10:09:00 pve systemd[1]: Starting Proxmox VE replication runnerā¦
Aug 23 10:09:01 pve systemd[1]: pvesr.service: Succeeded.
Aug 23 10:09:01 pve systemd[1]: Started Proxmox VE replication runner.
Aug 23 10:10:00 pve systemd[1]: Starting Proxmox VE replication runnerā¦
Aug 23 10:10:01 pve systemd[1]: pvesr.service: Succeeded.
Aug 23 10:10:01 pve systemd[1]: Started Proxmox VE replication runner.
Aug 23 10:11:00 pve systemd[1]: Starting Proxmox VE replication runnerā¦
Aug 23 10:11:01 pve systemd[1]: pvesr.service: Succeeded.
Aug 23 10:11:01 pve systemd[1]: Started Proxmox VE replication runner.
Aug 23 10:12:00 pve systemd[1]: Starting Proxmox VE replication runnerā¦
Aug 23 10:12:01 pve systemd[1]: pvesr.service: Succeeded.
Aug 23 10:12:01 pve systemd[1]: Started Proxmox VE replication runner.
Aug 23 10:13:00 pve systemd[1]: Starting Proxmox VE replication runnerā¦
Aug 23 10:13:01 pve systemd[1]: pvesr.service: Succeeded.
Aug 23 10:13:01 pve systemd[1]: Started Proxmox VE replication runner.
Aug 23 10:14:00 pve systemd[1]: Starting Proxmox VE replication runnerā¦
Aug 23 10:14:01 pve systemd[1]: pvesr.service: Succeeded.
Aug 23 10:14:01 pve systemd[1]: Started Proxmox VE replication runner.
Aug 23 10:15:00 pve systemd[1]: Starting Proxmox VE replication runnerā¦
Aug 23 10:15:01 pve systemd[1]: pvesr.service: Succeeded.
Aug 23 10:15:01 pve systemd[1]: Started Proxmox VE replication runner.
Aug 23 10:16:00 pve systemd[1]: Starting Proxmox VE replication runnerā¦
Aug 23 10:16:01 pve systemd[1]: pvesr.service: Succeeded.
Aug 23 10:16:01 pve systemd[1]: Started Proxmox VE replication runner.
Aug 23 10:17:00 pve systemd[1]: Starting Proxmox VE replication runnerā¦
Aug 23 10:17:01 pve systemd[1]: pvesr.service: Succeeded.
Aug 23 10:17:01 pve systemd[1]: Started Proxmox VE replication runner.
Aug 23 10:17:01 pve CRON[3131]: pam_unix(cron:session): session opened for user root by (uid=0)
Aug 23 10:17:01 pve CRON[3132]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Aug 23 10:17:01 pve CRON[3131]: pam_unix(cron:session): session closed for user root
Aug 23 10:18:00 pve systemd[1]: Starting Proxmox VE replication runnerā¦
Aug 23 10:18:01 pve systemd[1]: pvesr.service: Succeeded.
Aug 23 10:18:01 pve systemd[1]: Started Proxmox VE replication runner.
Aug 23 10:19:00 pve systemd[1]: Starting Proxmox VE replication runnerā¦
Aug 23 10:19:01 pve systemd[1]: pvesr.service: Succeeded.
Aug 23 10:19:01 pve systemd[1]: Started Proxmox VE replication runner.
Aug 23 10:20:00 pve systemd[1]: Starting Proxmox VE replication runnerā¦
Aug 23 10:20:01 pve systemd[1]: pvesr.service: Succeeded.
Aug 23 10:20:01 pve systemd[1]: Started Proxmox VE replication runner.
Aug 23 10:20:56 pve pvedaemon[18974]: root@pam successful auth for user āroot@pamā
Aug 23 10:21:00 pve systemd[1]: Starting Proxmox VE replication runnerā¦
Aug 23 10:21:01 pve systemd[1]: pvesr.service: Succeeded.
Aug 23 10:21:01 pve systemd[1]: Started Proxmox VE replication runner.
Aug 23 10:21:23 pve smartd[634]: Device: /dev/sda [SAT], SMART Prefailure Attribute: 194 Temperature_Celsius changed from 66 to 68
Aug 23 10:22:00 pve systemd[1]: Starting Proxmox VE replication runnerā¦
Aug 23 10:22:01 pve systemd[1]: pvesr.service: Succeeded.
Aug 23 10:22:01 pve systemd[1]: Started Proxmox VE replication runner.
Aug 23 10:22:44 pve pveproxy[18995]: worker exit
Aug 23 10:22:44 pve pveproxy[1024]: worker 18995 finished
Aug 23 10:22:44 pve pveproxy[1024]: starting 1 worker(s)
Aug 23 10:22:44 pve pveproxy[1024]: worker 3926 started
Aug 23 10:23:00 pve systemd[1]: Starting Proxmox VE replication runnerā¦
Aug 23 10:23:01 pve systemd[1]: pvesr.service: Succeeded.
Aug 23 10:23:01 pve systemd[1]: Started Proxmox VE replication runner.
Aug 23 10:24:00 pve systemd[1]: Starting Proxmox VE replication runnerā¦
Aug 23 10:24:01 pve systemd[1]: pvesr.service: Succeeded.
Aug 23 10:24:01 pve systemd[1]: Started Proxmox VE replication runner.
2 installed SSH addon in home assistant and gave command tail -f /config/home-assistant.log
Only entry is
Received message for unregistered webhook b70c0e96878fe3a06cb455cd09bf3ef539a8d8*********** from 192.168.1.*****
The restore command was given around 10:13.
I think it has something to do with chrome.
I restored the snapshot with the ssh terminal and that went fine. I also tied it with firefox and that also went fine.
Successfull install in a Beelink U55 server ( 2GB memory and 1 CPU Core for now)
I would suggest you add this part for people who want a static IP address: https://tech.borpin.co.uk/2018/10/18/using-nmcli-to-set-a-static-ipv4-address-in-hass-io/
Glad it was of use - how this is still an issue 2 years later. However, I think I saw a Tweet the other day that implied there was shortly (in dev) going to be a native way to do this via the UI.
[edit]
I just installed proxmox on a NUC and used Whiskerz script to install HA. All went well.
I did the samba config from Kanga-Who.
I can connect with winscp to the ip address of the proxmox machine. But when I try to connect to the IP address of the HA VM I got āconnection refusedā.
All I want is accessing the HA files to make some changes (Automations, configuration.yamlā¦)
Any ideas?
I have installed successfully Home Assistant using Proxmox following the guide of post #1 ( and setting the USB in USB port in proxmox to use the Aeotec Gen5 Zwave Dongle ZW090 )
The addon Mosquitto Broker and OpenZwave ahec been installed and configured .
The issue is that the Aeotec Zwave Dongle ZW090 is not showing in the Openzwave UI ( no zwave device added yet ) , as per the attahced screenshot :
However at the botton in the OZW log , the usb port of the Zwave dongle seems to work correctly .
Any idea ?
Thank you
EDIT FOR THE SOLUTION : The Aeotec USB Dongle is correctly detected in the HA VM , after modification of the USB device configuration in Proxmox from USB USB PORT to USB USB Vendor/Device ID + Choose device 0658:0200 ( The ZW090 USB dongle) as per the lsusb command :
Bus 0002 Device 0003 : ID 0658:0200
=> This is the Aeotec ZW090 USB Dongle
Then the ZW090 equipment is displayed in the OZW panel
Did you install the ssh addon? I have a HA running in Proxmox as well and it works for meā¦
As David mentioned, you will need to install SSH to each VM you wish to connect too. Each VM is treated as itās own entity, or PC if you like, so each one needs itās own SSH config.
Use the built-in HA SSH add-on to enable SSH to the HA VM.
You can just use the PVE web console.
Solved , Post #109 updated with the solution
Yes, installed the SSH from Homeassistant but still get ārefusedā.
Access the configuration.yaml file with proxmox web console? How?
My bad, I was thinking of my supervised install. You can use the Samba Add-on.
I donāt have that issue on my end with a PVE install. All 21 add-ons from your first screenshot are listed for me. Any errors in your Supervisor log?
Doh! Hadnāt enabled āAdvanced Modeā
