I just stopped playing those games (trying to fix the cgroup version problem manually as quite a while ago that didn’t fix my issue) and just run the below commands one at a time - will only take you a few minutes - (you won’t lose anything):
sudo -i
apt update && sudo apt upgrade -y && sudo apt autoremove -y
apt --fix-broken install
cd /usr/local/src
Check the above thread - or this URL to see if the OS-Agent I use below is the latest one first - (currently 1.6.0) -
At this point I check on the contents of the directory and clean the old .deb files out if I am getting newer ones, then (make sure you are still in there a “sudo -i” first):
wget https://github.com/home-assistant/os-agent/releases/download/1.6.0/os-agent_1.6.0_linux_aarch64.deb
dpkg -i os-agent_1.6.0_linux_aarch64.deb
wget https://github.com/home-assistant/supervised-installer/releases/latest/download/homeassistant-supervised.deb
dpkg -i homeassistant-supervised.deb
Best to reboot at this point -
This happens from time to time, sometimes after you update the underlying OS… with a variation of:
sudo apt update && sudo apt upgrade -y && sudo apt autoremove -y
So, the above steps allow you to ensure you have the latest and greatest and yet, not have to worry about cgroup version issues (and you do not lose your configuration either) - but always back everything up!
