I did ask about the hardware but did not get an answer. I suspect the hardware is considerably underpowered, particularly the amount of RAM. I have a HP Gen8 microserver with 16G of RAM, a boot SSD, and a Xeon 1265L which barely gets past 15% usage. An under-resourced TrueNAS config will struggle with several jails. I think an answer to the hardware is needed before proceeding further.
I figure out how to work around ( I think) I have to configure the each new jail, VNET, Berkeley Packet, pick my other vnet_default Interface (1 have 2 NIC), IPV4 interface: vnet0 and the jail started without freeze up. My default card is the built-in card not configure correctly.
It just happen recently. I installed Plex server and Syncthing from plug-in just fine.
Thanks, Troy for you good help. I got the MQTT service running on the separate jail. Then I goto the HA and add integration for MQTT and it works!!!
I will try the ESPHome next same manual way and scripts…
Do I need to add the mounting point on MQTT ??
No luck getting the ESPHome from repositories. I entered “pkg install esphome” on the new ESPHome jail shell. Message stated No packages available to install matching ‘esphome’ have been found in the repositories. IS the ESPHome spelling is incorrect or I did it wrong way??
EDIT to add: One more thing to keep in mind about using ESPHome on FreeNAS / TrueNAS
There is currently no USB detection for device flashing on FreeNAS . You can create, compile and download the initial firmware using ESPHome on FreeNAS. You will need to use esphomeflasher on a separate computer for the initial flash . After the initial flash and your device is connected to your network, you will be able to manage and flash future firmwares using the ESPHome OTA process.
I understand, I very familiar with ESPHome create and compile in bin using PC then use OTA on ESPHome. I got it esphome running now on my TrueNAS on separate jail. I tried to integrate to HA with the IP from ESPHome but I got this message:
What is best way to edit the yaml file? I usually do it on the Notepad++ but I need to use Samba share so I can open up on my PC. I already have samba share pointing to the iocage folder. Then I have permission issue to make changes on the yaml files. How do I do this on the permission issue so the TrueNAS user group can full access these yaml files?
I got the ESPHome GUI comes up by using the panel_iframe shortcut at HA. Why not work like MQTT using the ESPHome on the HA intregration? Is there any differences?
I still need a way on how to edit the yaml files inside the TrueNAS jails.I need help on how to get the correct permission so I can use samba share and use Notepad++ to edit the files inside jail. Or create a new mounting point for HA and user in TrueNAS to assess using correct permission. Which way is better way?
So basically, this is a rinse and repeat of the same process you have already used for Plex and Home Assistant. There are more than a few ways to set this up, but these are general steps can be applied to almost any Jail or Plugin on TrueNAS
First, you need to know a few things about the jail.
What is the username, group and UID of the the user who is running the service inside the jail?
What is location you need to mount the dataset inside the jail?
Next on your TrueNAS, create the following
User/Group using the same UID as the user inside the jail
A separate dataset, with owner /group set to the user you just created
Group permissions set to RW, since these methods use the group to control access
Then copy the existing configuration (from inside the jail) to the new dataset you have created.
And finally add dataset to correct mount point inside the jail.
Again, I’m sorry I don’t have every step available to just copy and paste. I’ve only looked at ESPHome but have not used it for more than testing the plugin installation.
You did not answer my question, so I will guess, this should be all the information you need.
NAME | SERVICE | PORT | USER | CONFIG DIR
ESPHome | esphome | 6052 | esphome | /var/db/esphome
You should be able to follow the guides for moving the Home Assistant configuration to an external dataset and setting up the samba share, except for ESPHome, you should use substitute the information provided in the table above, when setting everything up.
That is an old system that seems to give problems when you ask it to work hard. There are two possibilities;
First, the power supply cannot cope with the demands of all the hardware. Do you have a spare PSU that has enough power to test?
Second, some component/s are faulty, again manifesting under load. There are bootable ISOs available on the Web that can run a full range of diagnostics.
I would try them in that order. Have you checked the TrueNAS logs too?
