@ svenshomelab, Tks for the info but unfortunately everything is stuck and don’t have terminal apps either since I try to clean it and deleted them before. Now it ignore all terminal add on or new add ons.
If some created a terrible beta version that’s stuck, then that person should release a solution.
I still have add on “Check Home Assistant configuration” but activating it and log says,
Collecting sniffio
Downloading sniffio-1.3.0-py3-none-any.whl (10 kB)
Collecting rfc3986[idna2008]<2,>=1.3
Downloading rfc3986-1.5.0-py2.py3-none-any.whl (31 kB)
Collecting MarkupSafe>=2.0
Downloading MarkupSafe-2.1.1-cp39-cp39-musllinux_1_1_aarch64.whl (30 kB)
Collecting text-unidecode>=1.3
Downloading text_unidecode-1.3-py2.py3-none-any.whl (78 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 78.2/78.2 KB 10.3 MB/s eta 0:00:00
Collecting urllib3<1.27,>=1.21.1
Downloading urllib3-1.26.13-py2.py3-none-any.whl (140 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 140.6/140.6 KB 12.0 MB/s eta 0:00:00
Collecting idna<4,>=2.5
Downloading idna-3.4-py3-none-any.whl (61 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 61.5/61.5 KB 8.3 MB/s eta 0:00:00
Collecting dbus-fast<2.0.0,>=1.22.0
Downloading dbus_fast-1.82.0.tar.gz (65 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 65.7/65.7 KB 6.1 MB/s eta 0:00:00
Installing build dependencies: started
Installing build dependencies: finished with status ‘done’
Getting requirements to build wheel: started
Getting requirements to build wheel: finished with status ‘done’
Preparing metadata (pyproject.toml): started
Preparing metadata (pyproject.toml): finished with status ‘done’
Collecting pycparser
Downloading pycparser-2.21-py2.py3-none-any.whl (118 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 118.7/118.7 KB 13.0 MB/s eta 0:00:00
Collecting h11<0.15,>=0.13
Downloading h11-0.14.0-py3-none-any.whl (58 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 58.3/58.3 KB 7.8 MB/s eta 0:00:00
Collecting anyio<5.0,>=3.0
Downloading anyio-3.6.2-py3-none-any.whl (80 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 80.6/80.6 KB 7.2 MB/s eta 0:00:00
Building wheels for collected packages: home-assistant-bluetooth, lru-dict, dbus-fast
Building wheel for home-assistant-bluetooth (pyproject.toml): started
Building wheel for home-assistant-bluetooth (pyproject.toml): finished with status ‘done’
Created wheel for home-assistant-bluetooth: filename=home_assistant_bluetooth-1.8.1-cp39-cp39-musllinux_1_2_aarch64.whl size=72328 sha256=be4f2ab78d28828e630b643a6d531daa1af53753d166f80ff26bcaaee621a31c
Stored in directory: /root/.cache/pip/wheels/80/8b/fa/2b396d66ae1db7ed71d2fa900f850ffe0995f905c501a0c2e5
Building wheel for lru-dict (setup.py): started
Building wheel for lru-dict (setup.py): finished with status ‘error’
error: subprocess-exited-with-error
× python setup.py bdist_wheel did not run successfully.
│ exit code: 1
╰─> [8 lines of output]
running bdist_wheel
running build
running build_ext
building ‘lru’ extension
creating build
creating build/temp.linux-aarch64-cpython-39
gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -fno-semantic-interposition -fno-builtin-malloc -fno-builtin-calloc -fno-builtin-realloc -fno-builtin-free -DTHREAD_STACK_SIZE=0x100000 -fPIC -I/usr/local/include/python3.9 -c lru.c -o build/temp.linux-aarch64-cpython-39/lru.o
error: command ‘gcc’ failed: No such file or directory
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
ERROR: Failed building wheel for lru-dict
Running setup.py clean for lru-dict
Building wheel for dbus-fast (pyproject.toml): started
Building wheel for dbus-fast (pyproject.toml): finished with status ‘done’
Created wheel for dbus-fast: filename=dbus_fast-1.82.0-cp39-cp39-musllinux_1_2_aarch64.whl size=857993 sha256=fb680efd5971c6e120dc3027f91ef719bc789fe4090b44f58e47c68abbda3987
Stored in directory: /root/.cache/pip/wheels/c5/98/08/0882f0e002b6d14ae04902ebe9fe2b28b02bcc9ed135d3b972
Successfully built home-assistant-bluetooth dbus-fast
Failed to build lru-dict
Installing collected packages: voluptuous, text-unidecode, rfc3986, pytz, lru-dict, ifaddr, ciso8601, voluptuous-serialize, urllib3, typing-extensions, sniffio, six, pyyaml, python-slugify, PyJWT, pycparser, orjson, multidict, MarkupSafe, idna, h11, frozenlist, charset-normalizer, certifi, awesomeversion, attrs, atomicwrites-homeassistant, async-timeout, astral, yarl, requests, jinja2, dbus-fast, cffi, anyio, aiosignal, httpcore, cryptography, bleak, bcrypt, aiohttp, httpx, home-assistant-bluetooth, homeassistant
Running setup.py install for lru-dict: started
Running setup.py install for lru-dict: finished with status ‘error’
× Running setup.py install for lru-dict did not run successfully.
│ exit code: 1
╰─> [10 lines of output]
running install
/usr/local/lib/python3.9/site-packages/setuptools/command/install.py:34: SetuptoolsDeprecationWarning: setup.py install is deprecated. Use build and pip and other standards-based tools.
warnings.warn(
running build
running build_ext
creating build
[end of output]
error: legacy-install-failure
× Encountered error while trying to install package.
╰─> lru-dict
note: This is an issue with the package mentioned above, not pip.
hint: See above for output from the failure.
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
Is “home assistant” a coding cowboys paradise ?
