I’ve basically given up on Insteon.
They make great hardware. Combo fan/light controllers, switches with beeps and chips and adjustable ramp rates, a basic input/output module with a outlet pass though.
Their documentation and protocol though is sparse and frequently wrong. All theory and no examples. There’s one bug in the I/O Linc where you can’t get the sensor output because it returns the relay output instead, and they probably can’t fix it because if they do they’ll break existing implementations.
Anyway, besides their internal HouseLinc software, I’ve only ever seen halfway decent Insteon projects before the programmer just abandons the project. I figure they get it working well enough for their case, or get frustrated.
What I’m doing is replacing any critical components that need to be automated with Z-Wave stuff and keep the Insteon stuff for when using the little remote to control a light or when two light switches control each other directly is good enough.
Right, so now that I’ve gotten that out of my system, here are all the changes I’ve done to my own copy of Insteon_plm.
I’ll also say that I recall some point in time where it worked without all these hacks, and I don’t think the Insteon module was updated during that time so it very well could be some link inside the PLM that it’s choking on.
insteonplm/ipdb.py | 21 +++++++++-------
insteonplm/plm.py | 3 ---
insteonplm/protocol.py | 68 ++++++++++++++++----------------------------------
3 files changed, 34 insertions(+), 58 deletions(-)
diff --git a/insteonplm/ipdb.py b/insteonplm/ipdb.py
index e098a4b..7b3b176 100644
--- a/insteonplm/ipdb.py
+++ b/insteonplm/ipdb.py
@@ -12,21 +12,24 @@ class IPDB(object):
"""Embodies the INSTEON Product Database static data and access methods."""
products = [
- Product(0x01, 0x00, None, 'LampLinc 3-pin', '2456D3', ['light', 'dimmer']),
- Product(0x01, 0x01, None, 'SwitchLinc Dimmer (600W)', '2476D', ['light', 'dimmer']),
- Product(0x01, 0x02, None, 'In-LineLinc Dimmer', '2475D', ['light', 'dimmer']),
- Product(0x01, 0x03, None, 'Icon Switch Dimmer', '2476D', ['light', 'dimmer']),
+ Product(0x00, 0x12, None, 'Remote', '2444A2WH8', ['switch']),
+ Product(0x01, 0x00, None, 'LampLinc 3-pin', '2456D3', ['light', 'dimmable']),
+ Product(0x01, 0x01, None, 'SwitchLinc Dimmer (600W)', '2476D', ['light', 'dimmable']),
+ Product(0x01, 0x02, None, 'In-LineLinc Dimmer', '2475D', ['light', 'dimmable']),
+ Product(0x01, 0x03, None, 'Icon Switch Dimmer', '2476D', ['light', 'dimmable']),
Product(0x01, 0x04, None, 'SwitchLinc Dimmer (1000W)', '2476DH', ['light', 'dimmable']),
- Product(0x01, 0x06, None, 'LampLinc 2-pin', '2456D2', ['light', 'dimmer']),
+ Product(0x01, 0x06, None, 'LampLinc 2-pin', '2456D2', ['light', 'dimmable']),
Product(0x01, 0x07, None, 'LampLinc Dimmer V2 2-pin', '2856D2', ['light', 'dimmable']),
Product(0x01, 0x0d, None, 'SocketLinc Dimmer', '2454D', ['light', 'dimmable']),
Product(0x01, 0x0e, None, 'LampLinc Dual Band 2-pin', '2457D2', ['light', 'dimmable']),
Product(0x01, 0x13, 0x000032, 'SwitchLinc Dimmer (Lixar)', '2676D-B', ['light', 'dimmer']),
Product(0x01, 0x17, None, 'ToggleLinc Dimmer', '2466D', ['light', 'dimmer']),
- Product(0x01, 0x18, 0x00003F, 'Icon SwitchLinc Dimmer Inline Companiion', '2474D', ['light', 'dimmer']),
+ Product(0x01, 0x18, 0x00003F, 'Icon SwitchLinc Dimmer Inline Companiion', '2474D', ['light', 'dimmable']),
+ Product(0x01, 0x19, None, 'SwitchLinc Dimmer', '2474D', ['light', 'dimmable']),
Product(0x01, 0x1a, 0x00004F, 'In-LineLinc Dimmer', '2475DA1', ['light', 'dimmable']),
Product(0x01, 0x1b, 0x000050, 'KeypadLinc Dimmer, 6-button', '2486DWH6', ['light', 'dimmable']),
- Product(0x01, 0x1b, 0x000051, 'KeypadLinc Dimmer, 8-button', '2486DWH8', ['light', 'dimmable']),
+# Product(0x01, 0x1b, 0x000051, 'KeypadLinc Dimmer, 8-button', '2486DWH8', ['light', 'dimmable']),
Product(0x01, 0x1d, None, 'SwitchLinc Dimmer (1200W)', '2476D', ['light', 'dimmable']),
Product(0x01, 0x1e, None, 'Icon Switch Dimmer i2', '2476DB', ['light', 'dimmer']),
Product(0x01, 0x1f, None, 'ToggleLinc Dimmer', '2466D', ['light', 'dimmer']),
@@ -68,9 +71,9 @@ class IPDB(object):
Product(0x02, 0x37, None, 'On/Off Module', '2635-222', ['switch']),
Product(0x02, 0x38, None, 'On/Off Outdoor Module', '2634-222', ['switch']),
Product(0x02, 0x39, None, 'On/Off Outlet', '2663-222', ['switch']),
+ Product(0x02, 0x1e, None, 'KeypadLinc Dimmer, 6-button', '2486S', ['light', 'dimmable']),
- Product(0x03, 0x15, None, 'PowerLinc Modem (USB)', '2413U', ['plm']),
- Product(0x03, 0x20, None, 'USB Adapter', '2448A7', ['plm']),
+ Product(0x03, 0x15, None, 'Modem', '2413U', ['switch']),
Product(0x05, 0x0b, None, 'Thermostat', '2441TH', ['climate']), #<- Coming Soon!
diff --git a/insteonplm/plm.py b/insteonplm/plm.py
index 1704a5c..0cc0e0f 100644
--- a/insteonplm/plm.py
+++ b/insteonplm/plm.py
@@ -88,9 +88,6 @@ class PLMProtocol(object):
self.add(0x60, name='Get IM Info', size=2, rsize=9)
self.add(0x61, name='Send ALL-Link Command', size=5, rsize=6)
self.add(0x62, name='INSTEON Fragmented Message', size=8, rsize=9)
- self.add(0x64, name='Start ALL-Linking', size=4, rsize=5)
- self.add(0x65, name='Cancel ALL-Linking', size=4)
- self.add(0x67, name='Reset the IM', size=2, rsize=3)
self.add(0x69, name='Get First ALL-Link Record', size=2)
self.add(0x6a, name='Get Next ALL-Link Record', size=2)
self.add(0x73, name='Get IM Configuration', size=2, rsize=6)
diff --git a/insteonplm/protocol.py b/insteonplm/protocol.py
index b13415f..21f3390 100755
--- a/insteonplm/protocol.py
+++ b/insteonplm/protocol.py
@@ -2,6 +2,7 @@
import asyncio
import logging
import binascii
+import time
from .ipdb import IPDB
from .plm import Address, PLMProtocol, Message
@@ -185,20 +186,20 @@ class PLM(asyncio.Protocol):
self._message_callbacks = []
self._insteon_callbacks = []
+ self._me = None
self._buffer = bytearray()
self._last_message = None
self._last_command = None
self._wait_for = {}
self._recv_queue = []
self._send_queue = []
+ self._wait_time = 0
self.devices = ALDB()
self.log = logging.getLogger(__name__)
self.transport = None
- self._me = {}
self._userdefineddevices = {}
for userdevice in userdefineddevices:
@@ -352,9 +353,8 @@ class PLM(asyncio.Protocol):
if 'cat' in device and device['cat'] > 0:
self.log.debug('I know the category for %s (0x%x)',
address, device['cat'])
- self.product_data_request(address)
else:
+ self.product_data_request(device)
for userdevice in self._userdefineddevices:
if self._userdefineddevices[userdevice]["status"] == "notfound":
self.log.info("Failed to discover device %r.", userdevice)
@@ -423,6 +423,14 @@ class PLM(asyncio.Protocol):
def _process_queue(self):
self.log.debug('Send queue contains %d items', len(self._send_queue))
+ if time.time() - self._wait_time > 1:
+ #junk it
+ self.log.debug('Junking it')
+ self._last_command = None
+ self._wait_for = {}
+ self._buffer = bytearray()
+ #self._process_queue()
if self._clear_to_send() is True:
command, wait_for = self._send_queue[0]
self._send_hex(command, wait_for=wait_for)
@@ -449,7 +457,7 @@ class PLM(asyncio.Protocol):
msg = Message(rawmessage)
- # if hasattr(msg, 'target') and msg.target != self._me['address']:
+ # if hasattr(msg, 'target') and msg.target != self._me:
# self.log.info('Ignoring message that is not for me')
# return
@@ -521,9 +529,6 @@ class PLM(asyncio.Protocol):
callback, criteria)
self._loop.call_soon(callback, msg, device)
- if msg.cmd1 == 0x03 and msg.cmd2 == 0x00:
- self._parse_product_data_response(msg.address, msg.userdata)
def _parse_insteon_extended(self, msg):
device = self.devices[msg.address.hex]
@@ -652,11 +657,7 @@ class PLM(asyncio.Protocol):
def _parse_get_plm_info(self, msg):
self.log.info('PLM Info from %r: category:%02x subcat:%02x firmware:%02x',
msg.address, msg.category, msg.subcategory, msg.firmware)
- self._me['address'] = msg.address
- self._me['category'] = msg.category
- self._me['subcategory'] = msg.subcategory
- self._me['firmware'] = msg.firmware
+ self._me = msg.address
def _parse_get_plm_config(self, msg):
self.log.info('PLM Config: flags:%02x spare:%02x spare:%02x',
@@ -666,30 +667,17 @@ class PLM(asyncio.Protocol):
self.log.info('ALL-Link Record for %r: flags:%02x group:%02x data:%02x/%02x/%02x',
msg.address, msg.flagsval, msg.group,
msg.linkdata1, msg.linkdata2, msg.linkdata3)
- if self._me['subcategory'] == 0x20:
- # USB Stick has a different ALDB message format. I don't actually
- # think that linkdata1 is firmware, but whatever. Shouldn't have
- # any effect storing the value there anyway.
- category = msg.linkdata2
- subcategory = msg.linkdata3
- firmware = msg.linkdata1
- else:
- # Regular PLM format
- category = msg.linkdata1
- subcategory = msg.linkdata2
- firmware = msg.linkdata3
if msg.address.hex in self.devices:
self.log.info("Device %r is already added manually.", msg.address.hex)
if msg.address.hex in self._userdefineddevices:
self._userdefineddevices[msg.address.hex]["status"] = "found"
else:
self.log.info("Auto Discovering device %r.", msg.address.hex)
- self.devices[msg.address.hex] = {'cat': category,
- 'subcat': subcategory,
- 'firmware': firmware}
+ if not msg.linkdata1 == 0x00:
+ self.devices[msg.address.hex] = {'cat': msg.linkdata1,
+ 'subcat': msg.linkdata2,
+ 'firmware': msg.linkdata3}
if self.devices.state == 'loading':
self.get_next_all_link_record()
@@ -726,10 +714,13 @@ class PLM(asyncio.Protocol):
if self._last_command or self._wait_for:
self.log.debug('Still waiting on last_command.')
+ self.log.debug('Which is :%s',self._last_command)
+ self.log.debug('Wait :%s',self._wait_for)
self._queue_hex(message, wait_for)
else:
self._send_raw(binascii.unhexlify(message))
self._schedule_wait(wait_for)
+ self._wait_time = time.time()
def _send_raw(self, message):
self.log.debug('Sending %d byte message: %s',
@@ -787,21 +778,6 @@ class PLM(asyncio.Protocol):
self.log.info('Requesting PLM Config')
self._send_hex('0273')
- def factory_reset(self):
- """Reset the IM and clear the All-Link Database."""
- self.log.info('Nuking from orbit')
- self._send_hex('0267')
- def start_all_linking(self):
- """Puts the IM into ALL-Linking mode without using the SET Button."""
- self.log.info('Start ALL-Linking')
- self._send_hex('02640101')
- def cancel_all_linking(self):
- """Cancels the ALL-Linking started previously."""
- self.log.info('Cancel ALL-Linking')
- self._send_hex('0265')
def get_first_all_link_record(self):
"""Request first ALL-Link record."""
self.log.info('Requesting First ALL-Link Record')
