Insteon scene change
Is there a way to remove these links or scenes from within the UI or HA at all? I used to be able to do this with insteon-mqtt and Indigo before that. Thank you so much for all your progress on this!
Use the Insteon panel from the navigation page. Select any device with a scene you want to remove. Select the ā€œAll Link Databaseā€ tab and find the scene number record. Click on the record and uncheck the ā€œin useā€ check box. Hit ā€œOkā€ and then click ā€œWrite to deviceā€. This will effectively delete the record.
