Integrating SRNE MPPT Inverter with HA
Hi Mattias,
Thank you for your input, but first step I need some help to figure out how to get data from the PowMr inverter into Home Asistsant.
The inverter has a RJ45 rs485 serial interface. with following pinout:
1: RX
2: TX
3: VCC
4: VCC
5: RS485-A
6: RS485-B
7: GND
8: GND
Would it be possible for example to extract the data from he inverter and transfer these to Home assistat by esphome or over mqtt?
Your inverter probably has a different wire scheme and won’t work with my guide. You need to find those settings in you manual, I can’t help you unfortunately
I also use a epever tracer inverter and have to wire it differently to get data from it through my gateway, all info in the manual though
Hey all, just wanted to share my personal feedback on my latest SRNE / PowMr (POW-LVM3K-24V) setup.
I tried many ways and so far, those are the results:
- Probes and Connection type:
It appears the USB and the RS485 are tied to the same controller internally, and pulling both at once will create conflicts, as in if once port polls data, the other port is unavailable for that timeslot.
- USB:
iPow connection is stable on the computer, however data in the third tab is fractional, not direct reading (as in voltages readings can be *2 or /2 from real life)
Trying to read USB port through a VM connected to /dev/ttyUSB0 worked, but was highly unreliable, with half the readings not happening because ā€œCommand unrecognized or invalidā€
Trying to read USB port from a RPi (to try sending over MQTT) under Raspbian failed 100% of the time. Port is detected, but for some reason, I had the ā€œCommand unrecognized or invalidā€ every single poll.
RS-485:
RS-485 through RS485-USB adapter : Works, but I didn’t like it
RS-485 through ESPHome : Couldn’t make it work
RS-485 through Waveshare : Worked 100% of the time
Final and best solution (for my use case and liking):
Finally, this is what I used, Waveshare 485 to PoE Eth ā€œBreaker styleā€ device and YAML config to poll each address I needed.
Note : I found that readings were… of average accuracy. Especially in the grey zone where your solar production is close to the inverter output. Most of the time, my panel would say ā€œ0Wā€, my battery discharge would also be ā€œ0Wā€ but my inverter would output ā€œ100Wā€.
Note2 : I also find the internal SoC to be very badly implemented. It does not the battery capacity, hence I am suspecting the SoC is just a curve based on the battery voltage. For accurate SoC, I can’t recommend enough getting a coulombmeter or even code your own SoC (probably what I’ll do next)
Hey Mattie, I also found some discrepency in the Panel measurements, especially when battery is charged. At that point, for example, I can use 200W from the inverter, but battery discharge would be 0W, but also panels would read 0W/0A. Which I believe is wrong, as it is set to PV Priority and assuming those 200W are indeed pulled from the panel. Also reading 264.
Does anyone ever solved this discrepency (by polling anther register or making home-made helpers to correct this offset?)
Hey! Thanks for all your info, I’ve noticed the same as you regarding the polling and the battery charge. I think this is an issue with bad coding in the internal computer of the inverter and not the rs485 at all. It’s only a guess but srne is not exactly a high end product imo, and the data you get from the display is totally crap. The hardware and components over all feels great but where they save money is probably the coding and data calculation. But still, with the price taken into account I’m totally satisfied with the inverter. It does what is should and the overall consumption graph seems ok at least which is most important for me.
Also I think everyone is having a hard time calculating power draw from batteries in general, ESPECIALLY lead acid like many still use (including me). It’s just too many factors that the inverter can’t take into account, like how the battery bank is built, cable sizing, connections, other resistances etc. So I don’t think you can expect much more unless you calculate the SOC yourself.
Hey all,
I got two SRNE inverters in PAL and I am using the USB connector to go to an Linux appliance and have the USB to Serial terminate there.
I have been unable to communicate to the second inverter, it does not respond to the slave addressing.
How do we communicate to the other inverters through the master address 01 inverter with the RS482 and rtu modbus? Has anyone been successful with this?
RESET01_DEVICE=ā€˜01 10 df 01 00 01 02 00 01 48 8C’
RESET01_RETURN=ā€˜01 10 df 01 00 01’
RESET02_DEVICE=ā€˜02 10 df 01 00 01 02 00 01 5C 7C’
RESET02_RETURN=ā€˜02 10 df 01 00 01’
I did some more research with testing on a two parallel inverter setup and it seems that when connecting the RS485 port with both the T568b pin 8 (brown), pin 7 (brown/white) and pin 2 (orange) to each other it does create a Modbus RTU bus and I can communicate with the inverter build in USB connector to the other inverter (with the different slave address)
Which made me have the question how the heck the inverters communicate with each other when in parallel mode, I was expecting they where linked with the communication cable and used Modbus on there, but maybe they have to separated communication channels…
Next step would be to have an ESP32 to RS485 with an IPaddr as gateway… instead of using the USB cable to my Linux appliance with socat.
@Mattie I have the exact same inverter as you. Do you happen to have the modbus manual pdf for this model?
Out of curiosity, I have found out that this model is very likely to be the same as EASUN ISolar MLV 3KW-U.
Answering to myself:
I asked SRNE support, and they confirmed this is the modbus manual for such inverter (SRNE HF2430U60-100):
SRNE.Solar.Charge.Inverter.MODBUS.Protocol1.96.pdf
I have a ASF48100S200-H SRne inverter but I’m stuck to connect to my HA.
I have a USB to rs485 waveshare usb stick.
I have tried in many way but seams to not communicate. Can you please give me some info about to connect and communicate?
Your info will be really appreciated
I’m sorry that I cant answer everyons questions here, I’ve got both limited knowledge and time due to work and family. It’s nice to see so many users for this setup though!
@3industries I have no idea how to connect a USB waveshare, my guide is about a waveshare TCP/IP Gateway. I’m guessing you have the usb connected directly to the hassio unit, so you need to set up the controller with the modbus integration as a USB device like described in the docs here Modbus - Home Assistant
# Example yaml:  typical serial connection
modbus:
  - name: modbus_hub
    type: serial
    port: /dev/ttyUSB0
    baudrate: 9600
    bytesize: 8
    method: rtu
    parity: E
    stopbits: 1
My latest dashboard of my 3 inverters for some inspiration, the setup works like a charm! It may look like much but the coloring is key, I set thresholds so I only need to look for red on any value. If all is green/orange all is good!
I’ve got 2 SRNE 1.4kWh & 4kWh and an Epever 3.6kWh connected. The Epever is only a chargecontroller connected to the batterybank
First column is a genreal oversight of the total parameters and my current devices running on the system ordered by load
Second is divided in two columns showing each SRNE and the third is the Epever with some other values including the batterybank measured separately to see the eventual deviation between the two strings. I alsom have my zwave/shelly plugs connected to the incoming power for the inverters. That way I can also control them in inverterstate if I want them to switch to invertermode earlier than the voltage parameter I can turn off the power from the mains to make them fallback. Also I take advantage of their build in fuses if by any chance the power gets to high
The third column shows the log of events so I can see when the inverters change operations followed by their actual operation values and how to control them through specific command or automation to start the charging based on my current electricityprice
@Mattie, just a small issue in your config. The address for Modbus_Inverter_load_daily_consumption should be 61488.
Thanks, that was my first version of the config wich was alot of testing. I cleaned out many of the sensors after that mainly because I did have performance issues in the beginning due to to many requests or bad timeout settings in the integration I think. So I didn’t use that one for too long. I can’t find that address in my config anymore. Probably because I only need to measure the total draw from mains instead and that metric is given to my from the shelly/zwave plug (16A) instead
did you ever share you dashboard configs? I am especially interested in the one that maps the energy flow.
If you mean the Powerflow plus card in the first column it has this code:
type: custom:power-flow-card-plus
entities:
  battery:
    state_of_charge: sensor.inverter_batterybank_soc
  grid:
    entity:
      consumption: sensor.totalkwhfaser
    icon: mdi:transmission-tower
  solar:
    display_zero_state: true
    entity: sensor.daily_solar_total_energy
    secondary_info:
      entity: sensor.solprocent_template
      unit_of_measurement: "%"
      decimals: 1
  individual:
    - entity: sensor.daily_energy_ac
      icon: mdi:air-conditioner
clickable_entities: true
display_zero_lines:
  mode: show
  transparency: 50
  grey_color:
    - 189
    - 189
    - 189
use_new_flow_rate_model: false
w_decimals: 0
kw_decimals: 1
min_flow_rate: 0.75
max_flow_rate: 6
max_expected_power: 5000
min_expected_power: 10
watt_threshold: 1000
transparency_zero_lines: 0
If you mean the energy diagram it is made in Grafana/Influx and embedded as a website
Hi! SRNE inverter does not have registers like Today Battery Charge (kWh), wich need to ENERGY FLOW . On you picture I can see Battery in (kWh), how you did it ? thanks
The sensor looks like this:
From modbus GW:
#Accumulated battery charge AH
      - name: Modbus_Inverter_500v_battery_charge
        unique_id: Modbus_Inverter_500v_battery_charge
        scan_interval: 245
        unit_of_measurement: ah
        state_class: total_increasing
        scale: 1
        precision: 1
        slave: 1
        address: 61492
        input_type: holding
The sensor is more of an assumption and not at all an exact value, but it gives me a hint of whats happening and I have found it pretty accurate
(the if else template is preventing the sensor from showing ā€œunknownā€ as value if HA wont get any response from the waveshare GW. it also made the historical charts way cleaner back when I had more connection issues with my integration)
#SRNE 4kW
      inverter_500v_battery_charge_ah_daily:
        unique_id: inverter_500v_battery_charge_ah_daily
        friendly_name: Batteri laddat idag
        device_class: energy
        unit_of_measurement: 'kWh'
        icon_template: mdi:battery-high
        value_template: >
          {% if (states('sensor.modbus_inverter_500v_battery_charge') in ['unavailable', 'unknown', 'none']) %}
            {{ states('sensor.inverter_500v_battery_charge_ah_daily') }}
          {% else %}
            {{ (states('sensor.daily_inverter_500v_battery_charge_ah') | float(0) * 24.9 / 1000 | float(0)) | round(2) }}
          {% endif %}
same question
i ended up using this solution GitHub - thewestlabs/RNG-SyNC-doc: Documentation for RNG SyNC device
