Integration of a Fronius Symo Gen 24 plus Inverter via Modbus TCP
Surely I can share my code/nodes :slight_smile: Hopefully you can get something out of it.
All the data gathering is in this flow.
Data gathering flow
Whenever I have calculated values to send as InWRte, OutWRte, StorCtl_Mod or ChaGriSet then I send the values throug this function:
Before sending into the “Modbus execute” group:
Modbus execute group
Likewise I use the function node to send WMaxLim_Ena and WMaxLimPct in the same Modbus command, - also to the Modbus execute group.
Lots of the other nodes has been refactored and are primarily used as very specific calculations for our house, and most can only be used coherent with my other flows and specific data from Home Assistant.
Hope the above gives you some ideas - and if you find anything not working out, please write so I can change it :slight_smile:
