I was wondering also if anyone has been able to communicate directly with the device on the local network. In an ideal world I’d like to see some sort of event from it to indicate the door was opened for example, because currently the polling every 60 seconds isn’t much use. I guess I could poll every 1 second but then would the HUUM api like that, or does anyone know the fastest polling rate permitted?
Integration PR created Let’s see if we can get a proper integration in there in a couple of versions.
@fireheadman I have an automation that triggers alexa and notify my phone to say that the target temperature has been reached. I added a 1 hour delay at the end to make sure it didn’t get triggered repeatedly.
alias: sauna target reached
description: ''
- platform: numeric_state
entity_id: sensor.sauna_temperature
above: input_number.sauna_target_temperature
condition: []
- service: notify.notify
message: >
sauna has reached {{ states('input_number.sauna_target_temperature')|int }} degrees
- service: notify.alexa_media_foo_s_echo_flex
message: >
type: tts
method: speak
- delay:
hours: 1
minutes: 0
seconds: 0
milliseconds: 0
mode: single
I use this format for the shell command to shield private info, I also have a split configuration, so these are both in the /config/entities/shell_commands/huum_shell_command.yaml
sauna_light_toggle: !secret huum_rest_sauna_light_toggle
sauna_off: !secret huum_rest_sauna_off
also… @deejbee Thanks for the new automation… I have my sauna in downtime for a remodel.
As for direct communication, I would be interested in that also, but I believe the UKU requires a login from estonia (HUUM), although, there may be a way to trigger a /etc/hosts entry ?
What is the status of this integration pull request ? is it still processing or its off the table now ?
Hi, i am also very interested in an HUUM Integration. As i am a total newbie to Home Assistant and Programming in total - an integration would be perfect. Is there an update on the process? Thanks!
As i understand from the gihub thread that there will be no official plugin. So, could you explain how to make a custom install? BR Christoph
Hi @frwickst,
Thanks a lot for the Huum component. Too bad it wasn’t approved.
I would be super interested.
Is there anything I can do to help? I have some intermediate Python dev skills.
Otherwise, do you think it’s possible to do a custom component?
can anyone tell me why the component wasn’t approved and whether there will be other attempts to integrate huum?
Or how to use the snippets you have been providing?
I’m also interested in this integration. Is there any way to sponsor its development?
Hi, what a great Topic…I also have a HUUM Sauna and want to implement it in HA. I copied the Code below in the config and got the data for the sensors, but the shell commands doesn’t work.
my Code:
shell_command:
sauna_light_toggle: ‘curl “https://mail:[email protected]/action/home/light”’
sauna_off: ‘curl -X POST “https://mail:[email protected]/action/home/stop”’
if I try it via Webbrowser then it works, but not from HA.
What im doing wrong?
small addendum:
Switching on the sauna is possible with a set temperature via HA, but switching off is not possible…just like switching on or off the light.
Something with the shell_command does not fit with me yet.
ok, I found a solution for my problem.
i toggle the light and switch the sauna off with the rest functionality.
code:
rest_command:
sauna_licht_an_aus:
url: https://user:[email protected]/action/home/light
sauna_aus:
url: https://api.huum.eu/action/home/stop
username: user
password: password
verify_ssl: true
content_type: application/json
method: post
I use the configuration.yaml and script.yaml from upper and change the code
and now it works
Seems that this was not merged upstream. Maybe you want to provide it as HACS Addon?
I’m back to revisit my setup… I recently migrated my HA setup to a Apple Mac Mini (runs debian now) for a some power savings.
Count me in +1 more for a HACS integration.
Right now I am needing to sort out my light and sauna toggle as well as my input slider (which I wish was in F).
As a side note, I am also getting ready to add some small metal circulation fans, which will use the light relay.
Here is my current layout
the code:
I use a restriction card to prevent my kids from playing with it… Mimics the lockout function on the UKU control
type: vertical-stack
cards:
- type: custom:restriction-card
action: double_tap
duration: 10
restrictions:
pin:
code: XXXX
text: >-
Before confirming the PIN, Please ensure the Sauna is Safe and Ready!
Dont burn my house down!!.. Oh, and enjoy your session. [XXXX]
retry_delay: 10
restriction-regular-lock-color: red
restriction-success-lock-color: green
card:
type: entities
title: Sauna [Hint - Double Tab]
icon: mdi:radiator
show_header_toggle: false
entities:
- entity: binary_sensor.sauna_door
- entity: sensor.sauna_status_code
- type: attribute
attribute: light
- entity: light.sauna
- entity: switch.sauna
icon: mdi:radiator
- entity: input_number.temperaturesauna
name: Sauna Set Temperature (°C)
icon: mdi:gauge
- type: horizontal-stack
cards:
- type: conditional
conditions:
- entity: sensor.sauna_target_temperature
state_not: unknown
card:
type: gauge
max: 190
min: 45
segments:
color: '#ff0d00'
color: '#ff1a00'
color: '#ff2600'
color: '#ff3300'
color: '#ff4000'
color: '#ff4c00'
color: '#ff5900'
color: '#ff6600'
color: '#ff7300'
color: '#ff8000'
color: '#ff8c00'
color: '#ff9900'
color: '#ffa600'
color: '#ffb200'
color: '#ffbf00'
color: '#ffcc00'
color: '#ffd900'
color: '#ffe600'
color: '#fff200'
color: '#ffff00'
color: '#ffff00'
color: '#f2ff00'
color: '#e6ff00'
color: '#d9ff00'
color: '#ccff00'
color: '#bfff00'
color: '#b2ff00'
color: '#a6ff00'
color: '#99ff00'
color: '#8cff00'
color: '#80ff00'
color: '#73ff00'
color: '#66ff00'
color: '#59ff00'
color: '#4dff00'
color: '#40ff00'
color: '#33ff00'
color: '#26ff00'
color: '#19ff00'
color: '#0dff00'
needle: true
- type: gauge
entity: sensor.sauna_temperature
max: 190
min: 45
segments:
color: '#ff0d00'
color: '#ff1a00'
color: '#ff2600'
color: '#ff3300'
color: '#ff4000'
color: '#ff4c00'
color: '#ff5900'
color: '#ff6600'
color: '#ff7300'
color: '#ff8000'
color: '#ff8c00'
color: '#ff9900'
color: '#ffa600'
color: '#ffb200'
color: '#ffbf00'
color: '#ffcc00'
color: '#ffd900'
color: '#ffe600'
color: '#fff200'
color: '#ffff00'
color: '#ffff00'
color: '#f2ff00'
color: '#e6ff00'
color: '#d9ff00'
color: '#ccff00'
color: '#bfff00'
color: '#b2ff00'
color: '#a6ff00'
color: '#99ff00'
color: '#8cff00'
color: '#80ff00'
color: '#73ff00'
color: '#66ff00'
color: '#59ff00'
color: '#4dff00'
color: '#40ff00'
color: '#33ff00'
color: '#26ff00'
color: '#19ff00'
color: '#0dff00'
needle: true
Just installed my HUUM sauna so in for helping to test, etc.
I did notice that the response between the HUUM app and the sauna itself is not terribly fast. Has anyone had any success trying local integration? I port scanned the controller but found no open ports (not terribly surprising). Also out of curiosity did anyone else notice that the MAC address on the sticker of the main control box is exactly backwards of the real MAC address?
I’ve made some good progress with the original code posted here (which I’ve also converted to English just for my own purposes because it makes it easier for me while editing). I will gladly share that as well. Before I do just trying to do some troubleshooting and clean a few things up. Hoping someone can help with the following questions:
I see a lot of entities that aren’t able to be assigned an area because the “entity does not have a unique id” but from what I can tell it does in fact have a unique id? See images below
I noticed that the light off command in the original yaml above seems to use the word “duplicate” (in German of course) but I don’t really see a conflicting non-duplicative off command. Am I missing something or am uninformed (or is my German just bad) - the original is below
sauna_lampen_uit_dupliceer:
alias: 'sauna lampen uit '
sequence:
- service: script.sauna_licht_toggle
- service: input_boolean.turn_off
- What is refreshing the door open/closed status? I didn’t see it in the automations.yaml code. The reason I ask this is that it does seem to be still updating, which makes me wonder why we need automations to refresh the status of the light and heating.
So I sorted out the answer and solution to number 1 above - adding unique_ids fixes it. I created IDs for each item that would be very unlikely for anyone to be non-unique. Adding my updated code here which allows you to set areas for all the entities.
I just also want to say I’m standing on the shoulders of giants here, I claim no credit for any of this, @Razor109 and @fireheadman deserve the credit for anything here.
Configuration.yaml (make sure you update and to replace with your info, note the %40 in front of the domain vs. using @ directly in the shell commands)
################ HUUM #############
shell_command:
sauna_light_toggle: 'curl "https://<EMAIL>%40gmail.com:<PASSWORD>@api.huum.eu/action/home/light"'
sauna_off: curl -X POST https://<EMAIL>%40gmail.com:<PASSWORD>@api.huum.eu/action/home/stop
rest_command:
sauna_on:
url: https://api.huum.eu/action/home/start
username: <EMAIL>
password: <PASSWORD>
payload: '{"targetTemperature":{{ states("input_number.temperaturesauna")|int }} }'
verify_ssl: true
method: post
- platform: rest
resource: https://api.huum.eu/action/home/status
username: <EMAIL>
authentication: basic
unique_id: sauna_rest_status_2272022
scan_interval: 60
value_template: "OK"
json_attributes:
- door
- temperature
- targetTemperature
- statusCode
- light
sensors:
sauna_temperature:
unique_id: sauna_temperature_2272023
value_template: "{{ state_attr('sensor.sauna_status', 'temperature') }}"
device_class: temperature
unit_of_measurement: °C
sauna_target_temperature:
unique_id: sauna_target_temperature_2272023
value_template: "{{ state_attr('sensor.sauna_status', 'targetTemperature') }}"
sauna_door:
unique_id: sauna_door_2272023
value_template: >-
{% set state = state_attr('sensor.sauna_status', 'door') %}
{% if state == true %}Closed
{% elif state == false %}Open
{% else %}Unknown{% endif %}
sauna_light:
unique_id: sauna_light_2272023
value_template: >-
{% set state = state_attr('sensor.sauna_status', 'light') %}
{% if state == 0 %}off
{% elif state == 1 %}on
sauna_statuscode:
unique_id: sauna_statuscode_2272023
value_template: >-
{% set state = state_attr('sensor.sauna_status', 'statusCode') %}
{% if state == 230 %}Offline
{% elif state == 231 %}on
{% elif state == 232 %}off
{% elif state == 233 %}Blocked
{% elif state == 240 %}Emergency
light:
lights:
sauna:
friendly_name: "Sauna Light"
value_template: "{{ states('input_boolean.sauna_lightstate') }}"
turn_on:
service: script.sauna_light_on
turn_off:
service: script.sauna_light_off_dupe
switch:
switches:
sauna:
unique_id: sauna_heater_2272023
friendly_name: "Sauna Heater"
value_template: "{{ states('input_boolean.sauna_state') }}"
turn_on:
service: script.sauna_on
turn_off:
service: script.sauna_off
input_number:
temperaturesauna:
initial: 75
min: 41
max: 108
step: 1
input_boolean:
sauna_state:
sauna_lightstate:
name: Status Sauna Light
scripts.yaml
sauna_light_toggle:
alias: '[SAUNA] Light toggle'
sequence:
- service: shell_command.sauna_light_toggle
mode: single
sauna:
alias: '[SAUNA] Sauna Off'
sequence:
- service: shell_command.sauna_off
mode: single
sauna_sauna_on_75:
alias: '[SAUNA] Sauna on 75 degrees C'
sequence:
- service: rest_command.sauna_on
mode: single
sauna_on:
alias: sauna on
sequence:
- service: script.sauna_sauna_on_75
entity_id: input_boolean.sauna_state
- delay:
hours: 0
minutes: 1
seconds: 0
milliseconds: 0
- choose:
- conditions:
- condition: state
entity_id: sensor.sauna_statuscode
state: 'on'
sequence:
- conditions:
- condition: state
state: 'off'
sequence:
default: []
mode: single
sauna_off:
alias: sauna off
sequence:
- delay:
hours: 0
minutes: 1
seconds: 0
milliseconds: 0
- choose:
- conditions:
- condition: state
state: 'on'
sequence:
- conditions:
- condition: state
state: 'off'
sequence:
default: []
mode: single
sauna_light_off_dupe:
alias: 'sauna light off '
sequence:
- service: script.sauna_light_toggle
entity_id: input_boolean.sauna_lightstate
- delay:
hours: 0
minutes: 1
seconds: 0
milliseconds: 0
- choose:
- conditions:
- condition: state
entity_id: sensor.sauna_light
state: 'on'
sequence:
- conditions:
- condition: state
state: 'off'
sequence:
default: []
mode: single
sauna_light_on:
alias: sauna light on
sequence:
- delay:
hours: 0
minutes: 1
seconds: 0
milliseconds: 0
- choose:
- conditions:
- condition: state
state: 'on'
sequence:
- conditions:
- condition: state
state: 'off'
sequence:
default: []
mode: single
Automations.yaml (I’m not 100% convinced this is needed)
- id: '1640475808847'
alias: Sauna Status Update
description: ''
- platform: state
- platform: time_pattern
seconds: '30'
condition: []
- choose:
- conditions:
- condition: state
state: 'on'
sequence:
data: {}
- conditions:
- condition: state
state: 'off'
sequence:
data: {}
default: []
mode: single
- id: '1640476303582'
alias: Sauna Light Update
description: ''
- platform: state
seconds: '30'
condition: []
- choose:
- conditions:
- condition: state
state: 'on'
sequence:
data: {}
- conditions:
- condition: state
state: 'off'
sequence:
data: {}
default: []
mode: single
Feedback welcome, and hope this is helpful for someone
Thanks for your input.
Lately I adjusted my template for the sauna light and switch, to be more responsive. I’v found out how to put the contents of the scripts and automations directly in the template. In the old situation it could take a while for the status to change. Now it triggers an REST update directly after you flip te switch so it will update the status accordingly.
It also makes the automatisations and scripts unnecessary.
The status of the door is being refreshed when the REST sensor gets updated.
light:
lights:
saunalight:
value_template: >-
{% if state == 0 %}Off
{% elif state == 1 %}On
{% else %}Onbekend{% endif %}
turn_on:
- delay: 00:00:01
- service: homeassistant.update_entity
turn_off:
- delay: 00:00:01
friendly_name: Sauna Lampen
switch:
switches:
sauna:
value_template: >-
{% elif state == 231 %}On
{% elif state == 232 %}Off
turn_on:
- delay: 00:00:01
turn_off:
- delay: 00:00:01
This is my lovelace config:
cards:
- type: entities
entities:
- entity: sensor.sauna_door
- entity: sensor.sauna_statuscode
- entity: sensor.sauna_temperature
name: Huidige temperatuur
- type: conditional
conditions:
state_not: unknown
row:
name: Ingestelde temperatuur
- entity: light.saunalight
icon: mdi:radiator
- entity: input_number.temperatuursauna
- entity: media_player.sauna
type: custom:mini-media-player
toggle_power: true
shortcuts:
buttons:
- name: ClassicFM
type: service
entity_id: media_player.sauna
command: playlist
parameters:
- play
- classicfm
- name: Skyradio
type: service
command: playlist
parameters:
- play
http://opml.radiotime.com/Tune.ashx?id=s224032&formats=aac,ogg,mp3,wmpro,wma,wmvoice&partnerId=16&serial=7a068b625989fd18b463b262fd7dd78f
- name: 100.5 Das Hitradio
type: service
command: playlist
parameters:
- play
http://opml.radiotime.com/Tune.ashx?id=s2730&formats=aac,ogg,mp3,wmpro,wma,wmvoice&partnerId=16&serial=7a068b625989fd18b463b262fd7dd78f
- name: X-Mas Hits
type: service
command: playlist
parameters:
- play
https://stream06.dotpoint.nl:8006/stream?DIST=TuneIn&TGT=TuneIn&maxServers=2&partnertok=eyJhbGciOiJIUzI1NiIsImtpZCI6InR1bmVpbiIsInR5cCI6IkpXVCJ9.eyJ0cnVzdGVkX3BhcnRuZXIiOnRydWUsImlhdCI6MTY0MDE5ODY2OSwiaXNzIjoidGlzcnYifQ.c0w2YmufQO-tadk_CrRWQgeSNnFGD0ywrPwwlaiM49s
title: Sauna
Offcourse add your unique_id / friendly_name to meet your needs, since i dont use them in my own config.
it makes the following unnecessary
light:
lights:
sauna:
friendly_name: “Sauna Light”
value_template: “{{ states(‘input_boolean.sauna_lightstate’) }}”
turn_on:
turn_off:
switch:
switches:
sauna:
friendly_name: “Sauna Heater”
value_template: “{{ states(‘input_boolean.sauna_state’) }}”
turn_on:
turn_off:
input_boolean:
sauna_state:
sauna_lightstate:
and the automations and scripts are also not necessary anymore.
