Integration Solar inverter huawei 2000L
Hello!
I have 2 inverters, a 10 kW and a 6 kW. Both inverters are connected to 2 x 5 kWh batteries, so each inverter has its own dedicated battery. The 10 kW inverter controls the system, and battery charging is prioritized. When the house is consuming power, it is supplied via the battery. However, until the battery is fully charged, the solar energy production is not displayed, and the minus value appears twice on the energy panel, but only there. What can I do to fix this? Also, solar production appears at night too. :)))
Needless to say, the house’s consumption is also displayed incorrectly because of this. It only shows the real consumption correctly around midnight.
KépernyoĢ‹fotó 2024-09-26 - 20.28.54
I have a problem with the values coming from the smart meter. In particular, the house consumption shows the energy used. I would have expected to see power used. Is it possible to get that info?
And another question - the values for the power meter updates very slowly, sometimes more than an hour between updates. Is it possible to improve that somehow? I’m currently connected through the Sdongle, as I could not get the connection to the Inverter’s AP to work. I can connect, and port 6607 is open, but I do not get any data.
Any help i highly appreciated.
It looks like this template solved the problem. I looked up an example for this earlier.
I love this forum, you can always find alternative solutions here :slight_smile:
template:
  - sensor:
# 6PV  second battery pack
      - name: 6KTL Total PV
        #friendly_name: "PV Energy"
        unique_id: "PV Energy 6"
        state: "{{ (states('sensor.sun2000_6ktl_total_yield') | float) - (states('sensor.luna2000_battery_2_total_discharge') | float) + (states('sensor.luna2000_battery_2_total_charge') | float)}}"
        device_class: energy
        state_class: total
        unit_of_measurement: kWh
      - name: 6KTL Daily PV
        #friendly_name: "PV Energy daily"
        unique_id: "PV Energy daily 6"
        state: "{{ (states('sensor.sun2000_6ktl_daily_yield') | float) - (states('sensor.luna2000_battery_2_day_discharge') | float) + (states('sensor.luna2000_battery_2_day_charge') | float)}}"
        state_class: total
# 10PV first battery pack
      - name: 10KTL Total PV
        unique_id: "PV Energy 10"
        state: "{{ (states('sensor.sun2000_10ktl_total_yield') | float) - (states('sensor.luna2000_battery_total_discharge') | float) + (states('sensor.luna2000_battery_total_charge') | float)}}"
        state_class: total
      - name: 10KTL Daily PV
        unique_id: "PV Energy daily 10"
        state: "{{ (states('sensor.sun2000_10ktl_daily_yield') | float) - (states('sensor.luna2000_battery_day_discharge') | float) + (states('sensor.luna2000_battery_day_charge') | float)}}"
        state_class: total
Hi!
I use Homewizard instead of the Power Meter because it’s not accurate for me either; sometimes it shows a difference of 2-3 kWh compared to the HW, which is directly connected to the electricity meter via the P1 port. I’ve been using it for 2 years without any issues. I’ve already tested to see if everything goes through the Huawei Power Meter, and it seems that it does, but the data still differs. Since the electricity provider uses the electricity meter as a reference, I prefer using the HW.
Do you do some calculations on top of that? My electricity meter only shows import and export. But the actual consumption would something along the line of (solar power + import + battery discharge) - (export + battery charge).
But then it becomes a bit tricky if I charge the battery from imported electricity, or discharge the battery for export.
And the power values from the inverter and power meter have such slow update frequency that it becomes very inaccurate.
Yes, I used exactly the code you mentioned above. I subtract the battery charge, if that’s what you’re referring to. I got the example from here.
Example
the only way i did it is:
manual ip in HA lan conected to router 192.168.1.1 [minipc lan]
and automat ip conected with HA on huwaei hotspot 192.168.200.1 [minipc wifi dongle]
host: 192.168.200.1
port 6607
so it seems its about vlans management the problems when u have FE dongle conected to invertor by lan it gets vlan 1 : 192.168.1.1 as internet
when conecting by minipc dongle to invertors hotspot u get vlan 200: 192.168.200.1.
else try remove fe dongle and use invertor’s wifi hostspot.
have fun guys
Hi everyone,
I’m David and I’m new to Home Assistant. I’m excited to learn more about this platform and connect with other users.
Hello Home Assistant community,
I’m having some trouble adding a second Huawei inverter to my HA setup. I’ve already integrated one inverter using a dongle and it’s working fine.
The second inverter doesn’t have a dongle, but I can access it via its IP address. However, when I try to add it to HA using the same integration method as the first one, I get a connection error.
Thanks for your help!
ā€œIf you want to connect through the dongle, then you need to put in the two slave IDs as Thijs has said above. In a lot of cases it is either 0 and 1, 1 and 2 or 1 and 16. However, if you want to find out which slave ids your system has, then you need to login to the inverter using the Fusionsolar app and the internal AP. There you can see the slave id under the communication settings.ā€
good user and pasword
Unexpected error???
It worked very well 2 weeks but after the last homeassistant update- out of order…
Tried to delete and reinstall, no results.
Can you share your dashboard please.
Thx
Assuming your talking about two inverters in the same location / home setup?
If so, then you shouldn’t be looking to ā€˜add’ the second inverter via LAN / IP address, you need to lookup the RS485 networking section of the inverters manual.
In there you’ll see that you should be wiring the secondary inverter into the primary inverter using the RS485 connectors. When thats done correctly and configured in FusionSolar, you should then go to the FusionSolar Portal and you’ll see the site with the sDongle and below that the two inverters should show.
In HA you then just need to reconfigure the Huawei intetgration (WLCRS) and refer to the Wiki section on Github for WLCRS, that refers to the ID numbers you need to use (by default will probably be ā€˜1,2’) that should be entered, at which point the integration should query your setup and see the two inverters (and any batteries / optimisers also).
Thank you @wlcrs for your hard work!
I have a Luna2000 battery, which I want to control based on electricity prices. I am doing this from within the Node-Red addon.
I have done what I thought would be the difficult part, calculating the required battery state as ā€œchargeā€, ā€œdischargeā€ or ā€œstandbyā€. But as it turns out, the difficult part is actually controlling the battery.
Here are my questions, that I hope the infinite wisdom of the people in this thread can shed some light upon:
  • The idea is to use ā€œforcible_charge_socā€ together with charge_from_grid when the battery should be charged. (As there is not much solar power this time of the year where I live). How do I specify device_id, power and target_soc in the action_node?
  • When discharging, I plan on using ā€œMaximise self consumptionā€ as I believe that would result in power going from the battery to my house. Is there a better mode for this state?
  • It seems that the trickiest state is ā€œstandbyā€. I charge the battery at night and want to use it many hours later. Meanwhile, the battery should be in standby or hibernation, as it consumes an insane 100W in normal mode, even without feeding anything to the house. How can I set it to standby?
These questions shouldn’t be difficult, but I fail to find any answers by searching through the almost 3000 comments in this thread.
I am trying to get this integration running with elevated permission so I can use home assistant to manage battery charging. Without elevated permissions the integration is connecting to the inverter, I can ping the inverter I have all the measurements available
I had my account role changed to installer which is visible on the fusionsolar web page
I also configured the dongle to enable modbus unrestricted
but when I try to turn on the elevated permission in the integration I am stuck on the installer login screen of the integration
because my credentials for my fusionsolar installer account are not accepted.
How can I approach solving this issue?
Hi, I have small favor to ask.
I set up this integration long long time ago and today when I was checking logs I noticed some warnings regarding entities from Huawei Solar. Pasting only short example I will adjust rest accordingly once this is solved. Can anyone advise how to fix it?
Logs:
homeassistant.exceptions.TemplateError: ValueError: Template error: float got invalid input 'unknown' when rendering template '{{ '%0.2f' | format(states('sensor.power_meter_consumption') | float) }}' but no default was specified
2024-12-20 11:09:25.973 ERROR (MainThread) [homeassistant.components.template.template_entity] TemplateError('ValueError: Template error: float got invalid input 'unknown' when rendering template '{{ '%0.2f' | format(states('sensor.power_meter_consumption') | float) }}' but no default was specified') while processing template 'Template<template=({{ '%0.2f' | format(states('sensor.power_meter_consumption') | float) }}) renders=4>' for attribute '_attr_native_value' in entity 'sensor.m_grid_accumulated_energy'
2024-12-20 11:09:25.974 ERROR (MainThread) [homeassistant.helpers.event] Error while processing template: Template<template=({{ '%0.2f' | format(states('sensor.inverter_total_yield') | float) }}) renders=2>
Part from config.yaml:
    self_consumption:
      friendly_name: "Autokonsupcja"
      unit_of_measurement: 'kWh'
      value_template: >
        {{ '%0.2f' | format(states('sensor.inverter_total_yield') | float -
                            states('sensor.power_meter_exported') | float) }}
    m_grid_accumulated_energy:
      friendly_name: "Energia pobrana z sieci"
      value_template: >
Thank You in advance.
Use a reasonable default value for float, like | float(0) in the template.
Hello!
I tried to enable the Peak-shaving functionality, since we here in Sweden now have to pay for peak consumption.
However, I can not get the call to huawei_solar.set_capacity_control_periods to work.
I get the error :
2025-01-01 14:57:03.269 ERROR (MainThread) [homeassistant.core] Error executing service: <ServiceCall huawei_solar.set_capacity_control_periods (c:01JGH2FN55A3VKV6FYJFHFPDZ8): device_id=3fda7578187a27d2e7794148b5b0f9a0, periods=00:00-06:00/1234567/5000W
22:00-23:59/1234567/5000W
06:00-21:59/1234567/2500W>
  File "/usr/src/homeassistant/homeassistant/core.py", line 2822, in _run_service_call_catch_exceptions
    await coro_or_task
  File "/usr/src/homeassistant/homeassistant/core.py", line 2845, in _execute_service
    return await target(service_call)
  File "/config/custom_components/huawei_solar/services.py", line 575, in set_capacity_control_periods
    await bridge.set(
AttributeError: 'tuple' object has no attribute 'set'
I can run huawei_solar.set_tou_periods without problems, so I do think the parameters are correct.
I managed to configure the peak-shaving through FusionSolar, and that is now visible in Home Assistant.
Have anyone been able to call the huawei_solar.set_capacity_control_periods correctly or know if there are any problems with it? Or should I file a bug-report?
hi all
I’ve managed to install a battery to my huawei 5KTL inverter and the daily yeld statistics are higher than what fusion portal reports.
I’ve read the wiki from wlcrs and imported his code to test located HERE.
Apart of that, does anyone have an working solution instead of trying and fail?
The code shared in 2022 i in this topic above is not matching the 2024 Home assistant code at least from Riemann perspective.
Surely it will help others too.
thanks in advance
Anyone experiencing connection issues at the moment. Inverter/Battery data is coming and going every so often. Getting timeout issues fetching power_meter_data_update_coordinator data and inverter_data_update_coordinator data. Was working fine for the last year. Had upgraded to HAOS today but dont know if thats just a coincidence.
Edit: I have the Huawei Inveter added through the wifi network interface option in Home Assistant and see that it is sometimes dissapearing from this. Would that be due to network interference between the inverters wifi signal and my pc’s wifi connection?
