yousaf465
(Yousaf465)
August 29, 2021, 4:07pm
669
Here is my configuration.yaml there is some mistake with sensor template which I can’t understand, but rest is working fine. I am connected via RPi4
sensor solar:
- platform: huawei_solar
host: '192.168.200.1'
optimizers: false
battery: false
template:
- sensor:
total_yield:
friendly_name: "total yield"
unit_of_measurement: 'kWh'
icon_template: mdi:transmission-tower
value_template: "{{ state_attr('sensor.sun2000_10ktl_m1', 'total_yield') }}"
yousaf465
(Yousaf465)
August 29, 2021, 5:13pm
670
Here is my near final look
sensor solar:
optimizers: false
battery: false
sensors:
pv_input_power:
friendly_name: "Solar Production"
#entity_id: sensor.sun2000_10ktl_m1
unit_of_measurement: 'W'
icon_template: mdi:solar-power
value_template: "{{ state_attr('sensor.sun2000_10ktl_m1', 'input_power') }}"
sensors:
pv_daily_yield:
friendly_name: "Daily Yield"
value_template: "{{ state_attr('sensor.sun2000_10ktl_m1', 'daily_yield') }}"
sensors:
pv_total_yield:
friendly_name: "Total Yield"
sensors:
pv_string_01_voltage:
friendly_name: "Pv String 01 Voltage"
unit_of_measurement: 'V'
value_template: "{{ state_attr('sensor.sun2000_10ktl_m1', 'pv_string_01_voltage') }}"
sensors:
pv_string_01_current:
friendly_name: "PV String 01 Current"
unit_of_measurement: 'A'
value_template: "{{ state_attr('sensor.sun2000_10ktl_m1', 'pv_string_01_current') }}"
sensors:
pv_string_02_voltage:
friendly_name: "PV String 02 Voltage"
value_template: "{{ state_attr('sensor.sun2000_10ktl_m1', 'pv_string_02_voltage') }}"
sensors:
pv_string_02_current:
friendly_name: "PV String 02 Current"
value_template: "{{ state_attr('sensor.sun2000_10ktl_m1', 'pv_string_02_current') }}"
sensors:
pv_active_power:
friendly_name: "Power Meter Active Power"
unit_of_measurement: 'kW'
value_template: "{{ state_attr('sensor.sun2000_10ktl_m1', 'power_meter_active_power') }}"
sensors:
consumption:
friendly_name: "Consumption"
value_template: '{{ states("sensor.sun2000_10ktl_m1") |float - states("sensor.pv_active_power") | float }}'
sensors:
pv_device_status:
friendly_name: "Device Status"
value_template: "{{ state_attr('sensor.sun2000_10ktl_m1', 'device_status') }}"
sensors:
pv_string_02_power:
friendly_name: "PV String 02 Power"
value_template: '{{ states("sensor.pv_string_02_voltage") |float * states("sensor.pv_string_02_current") | float / 1000|round(2) }}'
sensors:
pv_string_01_power:
friendly_name: "PV String 01 Power"
value_template: '{{ states("sensor.pv_string_01_voltage") |float * states("sensor.pv_string_01_current") | float / 1000|round(2) }}'
sensors:
pv_efficiency:
friendly_name: "Solar Efficiency"
unit_of_measurement: '%'
value_template: "{{ state_attr('sensor.sun2000_10ktl_m1', 'efficiency') }}"
Thull3
(Thull3)
August 29, 2021, 6:06pm
671
Do anyone have this working ???
I only get unknown
m_grid_exporterd_energy:
friendly_name: "Exported energy"
value_template: "{{ state_attr('sensor.sun2000_15ktl_m0', 'grid_exporterd_energy') }}"
ligeza
(Rafał)
August 29, 2021, 6:22pm
672
change to
value_template: "{{ state_attr('sensor.sun2000_15ktl_m0', 'grid_exported_energy') }}"
Thull3
(Thull3)
August 29, 2021, 6:38pm
673
Took me many times to read what the different was but super thanks
tremebundo
(Juan Manuel)
August 30, 2021, 6:03pm
674
Hi all,
I have configured and have access to the sensor created by Emil’s custom component and I created sensor templates for many attributes as @yousaf465 do.
But I could not use any of them for the new Energy feature in HA.
Anyone has been able to use that way?
yousaf465
(Yousaf465)
August 30, 2021, 6:26pm
675
for that, you will need to you need to check @ligeza ’s video or this link Integration Solar inverter huawei 2000L - #589 by yousaf465
Evka2k
(Evka2k)
September 2, 2021, 7:53am
676
I added template sensor like this:
sensors:
pv_total_yield:
unit_of_measurement: "kWh"
value_template: "{{ state_attr('sensor.sun2000_8ktl_m0', 'total_yield') }}"
And this:
homeassistant:
customize_glob:
sensor.pv_total_yield:
last_reset: '1970-01-01T00:00:00+00:00'
device_class: energy
state_class: measurement
yousaf465
(Yousaf465)
September 2, 2021, 9:51am
677
what I am doing wrong?
pv_total_yield:
and
energy_used:
friendly_name: "total energy used"
value_template: >
{{ '%0.2f' | format(states('sensor.total_yield') | float -
states('sensor.grid_exporterd_energy') | float +
states('sensor.grid_accumulated_energy') | float) }}
After upgrade to 2021.9, the Energy stopped working. I had to change customize & template sensor to this:
sensors.yaml:
sensors:
solar_kwh:
friendly_name: "Solar Energy"
value_template: "{{ state_attr('sensor.sun2000_12ktl_m2', 'total_yield') }}"
customize.yaml:
sensor.solar_kwh:
unit_of_measurement: kWh
last_reset: "1970-01-01T00:00:00+00:00"
state_class: total_increasing
yousaf465
(Yousaf465)
September 2, 2021, 11:26am
679
Yes they changed total increasing.
hybrix
(Gonzalo)
September 4, 2021, 6:04am
680
@Emilv2 since a few days the inverter local access modbus gets hanged after 24h moreless. Even connecting by wifi is imposible. So a reboot is required. Maybe delaying requests could help, can you tell me how to change the python so that I can give a try? Thanks
adilsk
September 4, 2021, 7:33am
681
Hi everyone,
I’ve been trying to integrate my Sun2000l system with Home Assistant Energy Management.
I’ve managed to get my system integrated with Home Assistant courtesy of @Emilv2 but now I’m confused about how to setup Energy Management. I’ve setup the Grid Production with @sakalauskas sensor. Theres still nothing on the dashboard but Home Assistant says that it can take 2 Hours for changes to occur.
But I’m confused on how to setup the Grid Consumption and Return to Grid parameters with the attributes available for me to use. I’m assuming that it’s asking for the total amount of energy used from the grid and total amount of energy returned to the grid over the day (or is it total?).
Would appreciate if someone could help me use the existing attributes to obtain these values.
The values I have available to me are:
model_id:
serial_number:
nb_pv_strings:
rated_power:
grid_standard:
grid_country:
daily_yield:
total_yield:
grid_voltage:
grid_current:
line_voltage_A_B:
line_voltage_B_C:
line_voltage_C_A:
phase_A_voltage:
phase_B_voltage:
phase_C_voltage:
phase_A_current:
phase_B_current:
phase_C_current:
day_active_power_peak:
reactive_power:
power_factor:
efficiency:
grid_frequency:
power_meter_active_power:
input_power:
grid_A_voltage:
grid_B_voltage:
grid_C_voltage:
active_grid_A_current:
active_grid_B_current:
active_grid_C_current:
active_grid_power_factor:
active_grid_frequency:
grid_exported_energy:
grid_accumulated_energy:
active_grid_A_B_voltage:
active_grid_B_C_voltage:
active_grid_C_A_voltage:
active_grid_A_power:
active_grid_B_power:
active_grid_C_power:
startup_time:
shutdown_time:
internal_temperature:
device_status:
nb_optimizers:
system_time:
friendly_name:
gfpinto
(GustavoPinto)
September 4, 2021, 8:26am
682
I use HA Modbus and its the same… Since 2 says ago i need to restart because is stuck.
Note… Could it be after 2021.09…
hybrix
(Gonzalo)
September 4, 2021, 9:37am
683
2021.6.5, i dont update since june… HA cant be the issue
yousaf465
(Yousaf465)
September 5, 2021, 1:21pm
684
here is my configuration.yaml
sensor solar:
optimizers: false
battery: false
sensors:
pv_input_power:
friendly_name: "DC Production"
sensors:
pv_daily_yield:
sensors:
friendly_name: "grid exported energy"
value_template: "{{ state_attr('sensor.sun2000_10ktl_m1', 'grid_exported_energy') }}"
sensors:
energy_used_by_house:
friendly_name: "energy used by house"
value_template: "{{ state_attr('sensor.sun2000_10ktl_m1', 'grid_accumulated_energy') }}"
sensor total:
sensors:
pv_total_yield:
energy_used:
value_template: >
sensors:
sensors:
sensors:
sensors:
sensors:
pv_active_power:
value_template: "{{ state_attr('sensor.sun2000_10ktl_m1', 'power_meter_active_power') | float / 1000|round(2) }}"
sensors:
consumption:
sensors:
pv_device_status:
sensors:
pv_string_02_power:
sensors:
pv_string_01_power:
sensors:
pv_efficiency:
for energy dashboard these values are important.
sensors:
pv_daily_yield:
sensors:
sensors:
sensor total:
sensors:
pv_total_yield:
energy_used:
value_template: >
you have to change their attributes as described here Integration Solar inverter huawei 2000L - #589 by yousaf465 . These instruction are for upto 2021.8.8, from 2021.9.x onward use
seanmccabe
(Seán McCabe)
September 7, 2021, 12:11am
685
I’m just wondering if anyone elses attributes are sat stuck, specifically:
Mine have both just sat at 21474836.47 since day one, and wondered if there is a fix in the integration for this, or how it is supposed to be, or whether there is an issue with the invertor?
The Solar Fusion app shows grid export values.
Evka2k
(Evka2k)
September 7, 2021, 12:00pm
686
There already was discussion about this:
I think those properties are available only when power meter is connected to the inverter. Mine shows some big values :), but i ignore them.
Grid exported energy 21474836.47
Grid accumulated energy 21474836.47
domelek
(Radek)
September 7, 2021, 9:06pm
687
quick question - is your dongle TCP available 24h? Mine is going offline when inverter is in sleep mode, also consumption graphs are only available within inverter ‘working’ hours - I have KTL8-M0 model? has someone solution for this?
yousaf465
(Yousaf465)
September 8, 2021, 6:57pm
688
Here is inverters two day status. I don’t think night consumption data is available
