Yes, you should be able to input a comma-separated list of slave-ids now. Please let me know if you need to put them in a specific order or not for it to work.
Since updating today…
I cannot get the intergration to work anymore! (It was working yesterday)
2022-01-28 22:34:26 WARNING (MainThread) [pymodbus.client.asynchronous.async_io] Failed to connect: [Errno 104] Connect call failed (‘10.50.3.10’, 502)
2022-01-28 22:34:33 ERROR (MainThread) [huawei_solar.huawei_solar] Modbus client is not connected to the inverter.
NoneType: None
2022-01-28 22:34:37 ERROR (MainThread) [huawei_solar.huawei_solar] could not read register value, is an other device already connected?
- I assume you do not have a power meter connected to your inverter? I will add them to the list of fields for the inverter.
- Internal temperature is disabled by default, but should work if you enable it manually. (it will populate after the next update, which is done every 30 seconds).
- “Input Power” is the power in W that is produced by the PV
Got it intergrated now with Slave1
But now coming up with these errors
2022-01-28 22:41:54 ERROR (MainThread) [homeassistant.components.sensor] Error while setting up huawei_solar platform for sensor
File “/usr/src/homeassistant/homeassistant/helpers/entity_platform.py”, line 249, in _async_setup_platform
await asyncio.shield(task)
File “/config/custom_components/huawei_solar/sensor.py”, line 62, in async_setup_entry
has_optimizers = (await inverter.get(rn.NB_OPTIMIZERS, slave_id)).value
File “/usr/local/lib/python3.9/site-packages/huawei_solar/huawei_solar.py”, line 107, in get
return (await self.get_multiple([name], slave))[0]
File “/usr/local/lib/python3.9/site-packages/huawei_solar/huawei_solar.py”, line 154, in get_multiple
raise ReadException(
huawei_solar.exceptions.ReadException: Got error while reading from register 37200 with length 1: Exception Response(131, 3, IllegalAddress)
I’ve added all the line-voltage, phase voltage and phase current entities to the integration. Note that I leave them disabled by default. Because:
- There is no easy way to detect if the inverter is a one-phase or three-phase version. So this could result in a lot of useless sensors for people with one-phase inverters
- They are duplicate anyway for people with a power meter installed (which is always the case when you have a battery attached)
Not yet in trouble as my installation will happen only next week, but as i will get Huawei Hybrid Inverter i was installing in advance this great component. Problem tough is that after installing in HACS when I go to install the integration it does not appear. I have restart my HA instance but it does not work. I run HA in OdroidN2.
I’ve updated a previous version of this integration but HA duplicated installation and all sensors :(, so I’ve unistalled all versions and installed agan a clean integration. In this new release some sensors changed ID and I updated my grafana dashboard. but all seems works well with my SUN2000-5KTL-L1 + Luna2000 (20kWh) + Power Meter. Many thanks 4 your excellent work.
Please open an issue in my GitHub repo. It contains a template with all the things I need to help you. When filling in ‘Steps to reproduce’ I mean: EVERY button you clicked, EVERY bit of input you put somewhere. Be detailed! Otherwise I won’t be able to find the problem.
@MicheleMercuri I made some updates in the naming of things to improve consistency. Sorry to hear that this messes up your existing sensors.
No worries, not in a hurry. Thanks
Dear wlcrs
Thanks for great job. Installed an working perfectly.
Just one doubt:
- By default line-voltage, etc are Disabled.
How to enable it?
What file i need to edit?
Regards
Neves
Go to Configuration > Devices & Sensors
Click on the tile from your inverter
Choose the inverter device
On the detail page of your inverter, you will find the disabled entities, which you can now enable as needed:
Thank you.
Please make sure that you are using the latest version. This is currently 0dd4699 .
@wlcrs
The integration works great for me.
Is it possible to change update interval? Now it is 15s, but for me 30s or 60s is better. Less data - smaller database and faster respond in drawing graphs.
how can I do ir? it is on inversor I think
Installing your integration will remove the Emily one correct?
thanks
Sorry but I can nof fint it in integrations … All the files inside
- /config/custom_components/Huawei_solar
and then all the files correct??? Not the folder huawei_solar-0dd4699273143078c1269285a6fcd89bb27f826c
thank you in advance
Yep its working great now!
