my problem is this:
the daily yield should show how much the solar panels produce. but somehow they show a positive production even during night time (roughtly 2kwh when no sun is shining). has someone else have this problem?
Hi at all, I need to minimize grid consumption of my plant (SUN2000-5KTL-L1 + Luna2000 20.0 kWh).
During the day (24h) Iâve about 1,00 kWh of grid consumption (about a constant average imported energy 50/80 w) with full sunny day and 100% charged Luna2000 .
So, to reduce grid consumption, I connected remotely to my inverter via FusionSolar app ad setted this value:
â>Device Managementâ>select the S-dongle unit and pressâ>Set Parametersâ>Active Power Controlâ>and modified the âPower raising thresholdâ (kW) parameter from 0.050kW to 0.010kW. (see attached picture)
So grid consumption during 24h is lower, but can I reduce grid import too by setting < 0,010 kwh value ? (Ex can I set 0,005 kWh ?).
And if I reduce âpower adjustment periodâ (from 0,5 s to 0,2 s), (see attached picture) can I improve inverter reactivity and so reduce grid import?
Lately Iâve been checking sensor.internal_temperature as summer is approaching and I was curious about other userâs readings. Iâm getting up to 53ÂșC which I assume itâs normal for a 5KTL operating at near-maximum capacity, but I think it would be good If some of you can share your values so we can compare, as temperature is one of the main factors affecting service life of inverters.
My unit is in the basement, at around 20ÂșC ambient temperature, but the installer placed it too close to the ceiling ignoring Huaweiâs specs, so Iâm a bit concerned about proper heat ventilation.
It seems a bit too hot, today mine itâs 49,3° (5.155W power peak). Also my installer placed in a very small room I will install a heat ventilation too.
that was what i did. But is was always showing me the wrong value. And now suddenly itâs showing the correct value. And i havenât changed any setting
What is the exact difference between sensor.active_power and sensor.input_power?
I have a HUAWEI SUN2000-4.6KTL, but my smart power meter module is not yet connected over RS485 (forgotten by installer). The input power is mostly ± 20W higher than the active power value.
is it also possible to change to port after you did the config?
I had it setup to port 507 on the inverter ip (192.168.200.1)
but after the installer did the firmware update, i think i have to change it to 6607? but i canât find where to change tot port in the configuration
