Integration Solar inverter huawei 2000L
Yes, seems to be OK now
screenshots are always welcome. :partying_face: Post the setting used for the OpenWrt 22.03 rc4. Do hide your external ips.
Done ! they will process to its remplacement in the next few days !
did you call them on the phone or installer did it for you?
The installer did it for me, I didnt had time this week with the work…
Did I do something wrong ?
seems to be. When selecting the destination, the mac address of the inverter will be visible. and in rewrite the Ip address field the wlan0 i.e 2.4Ghz radio interface.
Ok. And what do you think is not correct in my configuration?
Go to network – firewall – Nat rules – Edit
select destination IP from the dropdown, do you see all mac addresses of other devices too? In my case, it does mention each device’s mac address beside the Ip.
Also, check the dropdown menu of re-write Ip address all interfaces will be mentioned there beside their IP address.
I have this :rofl:
what is the status overview – status – Wireless
@wlcrs regarding the How-to I came up with following diagrams
and
this is strange, no-host IP, why two SSIDs on single radio?
you are right, I did not paid attention…
EDIT: will try to flash the router and start again from scratch, I may miss something
Step4: keeping track of Huwaei inverter with OpenWrt router.
  • Either set up a ping sensor
    These connections/disconnections were to due rebooting OpenWrt router for installing opkg packages.
or
*Use Presence detection scanner for OpenWrt using luci.
This was only setup after 11:38.
Well, some changes :
30:c5… seems to be the inverter
so you can now ping the inverter from HA, which means you just need to find the right port and slave ID combination for this to work.
OK but that’s normal this kind of desconnection of the inverter?
Not able to ping it every time, some time, it doesn’t work.
it depends on signal strength.
