Could you provide the specific name, and maybe the repo, for the Emporia integration in HACS?
Searching for “Emporia” doesn’t turn up any results for me just now.
Thanks!
Thanks!
In case you didn’t figure it out yet (it took me a bit of digging), you have to add a custom repo to HACS. See the install instructions at GitHub - magico13/ha-emporia-vue: Home Assistant Integration for Emporia Vue Energy Monitor
Hi Have you or anyone here recently purchased a rainforest EMU 2? This seems to the be superior device to the eagle and has the most support on here.
However I cannot seem to find any for sale in the obvious places.
Thank you,
For those interested in getting the tariffs from SCE
- sensor:
- name: "TOU Season"
unique_id: 14d92f63-ddcd-4f0f-b527-4991c4793468
state: "{{ ['Winter', 'Summer'][now().month >= 6 and now().month < 10] }}"
icon: mdi:weather-cloudy-clock
- sensor:
- name: "TOU Peak"
unique_id: 04f44c76-13a6-46c7-b360-b3c8a1cdd2ab
icon: mdi:calendar-clock
state: >
{% set is_weekend = now().strftime("%w") == 0 or now().strftime("%w") == 6 %}
{% if states('sensor.tou_season') == "Summer" %}
{% if now().hour >= 16 and now().hour < 21 %}
{% if is_weekend %}
{{ "Mid-Peak" }}
{% else %}
{{ "On-Peak" }}
{% endif %}
{% else %}
{{ "Off-Peak" }}
{% endif %}
{% else %}
{{ "Mid-Peak" }}
{% elif now().hour >= 21 or now().hour < 8 %}
{{ "Off-Peak" }}
{% else %}
{{ "Super Off-Peak" }}
{% endif %}
{% endif %}
- sensor:
- name: "TOU Cost"
unique_id: 569d41e9-95dc-480a-830e-c00bcd03bef3
icon: mdi:currency-usd
device_class: monetary
unit_of_measurement: "$/kWh"
state: >
{{ {"Off-Peak": 0.23, "On-Peak": 0.54, "Mid-Peak": 0.23}[states('sensor.tou_peak')] }}
{% else %}
{{ {"Super Off-Peak": 0.22, "Off-Peak": 0.22, "Mid-Peak": 0.50}[states('sensor.tou_peak')] }}
{% endif %}
- sensor:
- name: "Today's Energy Cost"
unique_id: 89fae27e-d7cb-436e-b123-7afc8706922f
unit_of_measurement: "$"
state: "{{ (
(states('sensor.energy_used_today') | round(2))
* (states('sensor.tou_cost') | round(2))
) | round(2) }}"
Just placed an order for the emporia Vue.
I was trying to get the rate structure in preparation for when I configure the sensor, but I am new to Home Assistant.
Not sure where I would add this code.
Can someone point me to an article or describe how to / where to set up these new sensors?
Appreciate the help!
These are templates that will create sensor in your Home Assistant instance. Those sensor will report some values depending on the settings and the data source you will provide.
You can use these sensor to show the data in any cards you want (more or less).
A few quick notes as we move into 2024.
For Southern California Edison, I ordered the Emporia Vue. This specific model:
https://www.amazon.com/dp/B084T6HGNR
I registered it with SCE’s HAN website and within ~1 business day it’s now up and working. The Home Assistant integration for Vue works just fine, I can see power.
I’m on the tiered rate plan, otherwise called the “DOMESTIC” rate on the bill. That generally corresponds to this:
My next step will be to figure out how to pull in those rates. The templates above are all around season and costs at different times of the day, my rate plan changes after I hit my max in tier 1.
Not sure how to do this yet. I do know what my baseline allocation is, perhaps storing that as a static variable/helper and then scraping the tiered pricing down?
Related but not - in many communities in SoCal SCE delivers the power but does not actually generate it. My generation comes from the Clean Power Alliance, which has its own rates that vary depending upon how clean your power is. Their 100% green power is the default option which is higher than SCE’s rates or even their other options, so just knowing that and making a phone call to select a different plan might result in a per month savings.
While it doesn’t entirely solve the original poster’s problem and it’s been 3 years, I have created a custom integration that uses data from the California energy regulator’s prices API to provide your current and near-future electricity prices.
So long as you have a “RIN” QR code on your electric bill, which should have been showing up since April, you can get a price entity for use in automations and the energy dashboard:
I found some of SCE’s rates while developing: USCA-SCSC-0400-0000 is TOU-D-4-9PM and USCA-SCSC-0500-0000 is TOU-D-5-8PM.
As for energy usage, there isn’t a public API available for that, especially in realtime. Installing an energy monitor in your electric panel or enrolling some end device in SCE’s HAN service can get you better usage insights.
I personally went with the monitor-in-the-electric-panel option since there are options that keep everything local. With all that said there are some interesting filings making their way through the California Energy Commision that could be bringing a standardized energy usage API our way soon…
I have no idea why my emporia vue can`t connect since I move last year. I lost all the electricity track record since then…
And Im working on a new approch that directly pull data from SCE.com using uivision-automation running in docker.
And I successfully extracted data from the webpage:
Initial data be like:
| Time | Total Net Usage | Mid-Peak Net Usage | Off-Peak Net Usage | Super Off-Peak Net Usage | |
| 12 AM | 0.44 | 0.00 | 0.44 | 0.00 | |
| 1 AM | 0.57 | 0.00 | 0.57 | 0.00 | |
| 2 AM | 0.47 | 0.00 | 0.47 | 0.00 | |
| 3 AM | 0.45 | 0.00 | 0.45 | 0.00 | |
| 4 AM | 0.44 | 0.00 | 0.44 | 0.00 | |
| 5 AM | 0.43 | 0.00 | 0.43 | 0.00 | |
| 6 AM | 0.43 | 0.00 | 0.43 | 0.00 | |
| 7 AM | -0.26 | 0.00 | -0.26 | 0.00 | |
| 8 AM | -1.60 | 0.00 | 0.00 | -1.60 | |
| 9 AM | -3.14 | 0.00 | 0.00 | -3.14 | |
| 10 AM | -4.06 | 0.00 | 0.00 | -4.06 | |
| 11 AM | -4.58 | 0.00 | 0.00 | -4.58 | |
| 12 PM | -4.75 | 0.00 | 0.00 | -4.75 | |
| 1 PM | -4.58 | 0.00 | 0.00 | -4.58 | |
| 2 PM | -3.78 | 0.00 | 0.00 | -3.78 | |
| 3 PM | -2.49 | 0.00 | 0.00 | -2.49 | |
| 4 PM | -0.89 | -0.89 | 0.00 | 0.00 | |
| 5 PM | 0.86 | 0.86 | 0.00 | 0.00 | |
| 6 PM | 0.90 | 0.90 | 0.00 | 0.00 | |
| 7 PM | 0.76 | 0.76 | 0.00 | 0.00 | |
| 8 PM | 0.96 | 0.96 | 0.00 | 0.00 | |
| 9 PM | 1.28 | 0.00 | 1.28 | 0.00 | |
| 10 PM | 1.21 | 0.00 | 1.21 | 0.00 | |
| 11 PM | 1.04 | 0.00 | 1.04 | 0.00 |
But there were limitations:
next step is trying to get the data into HA, hope I could get everything done this weekend…
Also Im a bit confused to SCE`s data. Does 12 AM/0.44kwh meaning 12AM-1AM net usage 0.44kwh? or 11PM to 12AM?
Does anyone have an update? I did some digging on the SCE website and it looks like they use Zigbee with the Smart Energy Profile 1.0/1.1 specification
So… That being said, could we use a zigbee gateway or an esp32 with Zigbee tuned to those specs to DYI?
Is there a way to query the price the utility pays for energy generated? The cost for useage works great, thanks for the plugin.
Some utilities have put their wholesale prices in MIDAS as independent RINs, but I haven’t found any for SCE. If you are a CCA customer, that portion of the generation will have its own RIN on your bill which should be the price for that generation.
the USB Vue Smart Home Energy Monitor doesn’t on the HAN list anymore and mine broke. I’m now looking at another solution. Any recommendations?
This also looks interesting. Home Assistant Energy Dashboard with Southern California Edison (SCE) Home Assistant Energy Dashboard with Southern California Edison (SCE) - Interesthingly
Talked with Edison HAN support. They still support the USB Vue Smart Home Energy Montior however I went with Rainforest Automation Eagle. Works great with Edison, Wallbox and my SolarEdge inverter.
Got it working btwn SCE <> Emporia Vue Connect. Need to flash ESPHome next
Why do you need ESPhome if you have got Vue connected ? BTW does Vue still work with SCE ? I am planning to get one for energy monitoring.
Hi, Did you make further progress with this ? I would be interested in trying out your solution.
how did you get it working ? I installed Emporia Vue utility connect (USB Dongle) and submitted the HAN enrollment form on Friday but still not getting any data. Any idea how long it takes to get the device registered or is there a phone number i can call to provision my device ? TIA.
