"Internal" time wrong
Yes, this is to be expected, because that attribute (and most others) are expressed in UTC. Try this:
{{ as_timestamp(states.binary_sensor.ytterdorr_las.last_changed)|timestamp_custom('%H:%M') }}
By default timestamp_custom outputs the time in the local time zone.
Aah, thanks alot for the example as well!
Is it possible to update the home assistant documentation? I think this would be great to add somewhere
Can anyone explain why my desktop Chrome browser shows time off of UTC while my phone Chrome browser shows it correctly off of PTC?
Relevant YAML:
input_datetime:
  airbnb_deadbolt_unlocked_by_guest_user_3:
    name: Last Unlocked by Guest (User 3)
    has_date: true
    has_time: true
    icon: mdi:account-key
  sensors:
    deadbolt_last_unlocked_by_guest:
      value_template: >-
        {{ states.input_datetime.airbnb_deadbolt_unlocked_by_guest_user_3.last_updated.strftime('%Y-%m-%dT%H:%M:%S') }}
      friendly_name: 'Last Unlocked by Guest'
      device_class: timestamp
automation:
    platform: state
    entity_id: sensor.airbnb_deadbolt_alarm_level
    to: '3'
  - service: input_datetime.set_datetime
    data_template:
      entity_id: input_datetime.airbnb_deadbolt_unlocked_by_guest_user_3
      date: >
        {{ now().timestamp() | timestamp_custom("%Y-%m-%d", true) }}
      time: >
        {{ now().timestamp() | timestamp_custom("%H:%M:%S", true) }}
Lovelace:
          - entity: sensor.deadbolt_last_unlocked_by_guest
            secondary_info: last-changed
            format: relative
I’m posting this in hopes it will help someone:
Trying these two:
{{ as_timestamp(states.input_datetime.airbnb_deadbolt_unlocked_by_guest_user_3.last_changed)|timestamp_custom('%Y-%m-%dT%H:%M:%S') }}
Gave me:
2019-10-03T16:36:43
2019-10-03T09:36:43
So I updated the template sensor:
      value_template: >-
And it’s solved:
@pnbruckner - Apparently I didn’t check my phone last time but it’s showing -7 hours now (time without applying the timezone) while my laptop is showing the time with the time zone applied (ie - 8 seconds).
Do you have any thoughts on why there could be this discrepancy?
I posted the views above that appear to show both browsers are calculating the same numbers when using the templates dates.
Also looking for this file.
guys i got same issue but i don’t know how to fix it
take a look on this snapshot
What issue? The timestamps in the database are in UTC. That’s not an issue. What problem do you think you have?
all i understand that it Hassio is using UTC while writing in the database as default ,i want to change the writing in database instead of UTC to EET ,do u know to change that? @pnbruckner
No, because you can’t. Why do you want to do this?
the history that i read from database i want to view it but it give me UTC ,and i want in EET ,it will force me to make changes in my query @pnbruckner or if u have another idea
Maybe you need to describe where and how this querying of the database will be done. Are you doing this in Home Assistant (HA), or in something else? If you’re doing it in HA, there might be another way to solve your problem. Again, it would be helpful to understand what you’re ultimately trying to achieve.
@pnbruckner yes i’m using latest version of HA ,i’m trying to get lastest read about Voltage sensor and last datetime and see the history of it ,so i call from database of homeassistant2.db that give me created datetime ,so it give me in UTC which is wrong time ,so i want it in correct time which is EET as 2 hours different .
see the snapshot of my HA 101.2
see the history said correct time is 16:11 but in the Volt date time in the database is 14:11
picture upload
Your last picture does not seem to have worked.
Why aren’t you just using the values available in the entity’s State Object? For example, if you want to know when the state last changed, you do not have to do a complicated database query, you can just use:
{{ states.sensor.sonoff_100054b15e_voltage.last_changed }}
EDIT: And if you want to see this in local time instead of UTC, then:
{{ states.sensor.sonoff_100054b15e_voltage.last_changed.timestamp()|timestamp_local }}
@pnbruckner great i’ll try it now
I tried the same thing for my sensor via template
- platform: sql
  scan_interval: 2
  queries:
    - name: living to garage door last opened
      query: "select last_changed from states where entity_id = 'binary_sensor.0x00158d000275ef5d_contact' and state = 'on' order by last_changed desc;"
      column: 'last_changed'
      value_template: "{{ as_timestamp(value) | timestamp_local }}"
And I still see UTC time. :frowning:
See the answer I provided in your other topic.
Thank you for your answer, problem solved!
@andyng i tried the same but still UTC
i made plus +2 as the time difference is +2
value_template: “{{ as_timestamp(value~’+02:00’) | timestamp_local }}”
can u send your query here?
EDIT : my mistake i should leave it 00:00 and it works ,my mistake
    value_template: "{{ as_timestamp(value~'+00:00') | timestamp_local }}"
Yeah, +00:00 for UTC timestamp.
