I went on with the integration, and am currently implementing the climate entity:
It’s working, and… it can be installed from HACS ! First, add the custom repository URL, as you won’t find it yet in the repositories known by HACS.
This is still Work In Progress. Namely, simultaneous requests lead to an exception (quite bad) and has to be investigated.
Thanks, i have installed it few minutes ago
I credited you as I used many parts of your work ! Thanks @elkropac !
Would you add your own options to this dashboard configuration discussion, please ?
status is an IntexSpaStatus, or an exception is raised.
So I did not implement error detection there, but we should assert that all errors eventually proceeds to an exception
Created an account to say thanks.
This stuff is awesome and works perfectly here.
Nice!
Thanks @CyrilP, I used your extracted code to implement an error code sensor
If you are using the integration, be careful as the climate entity_id has changed from climate.spa_climate to climate.spa
Have it installed and working but each time i shutdown/restart my access point, the integration become unable to reconnect (No problem with intex app on the same smartphone, same conditions).
I set up a ping sensor to check if SPA_DEVICE.lan is reachable on the network.
The only workaround i found is…restart HA
and then it works again until next wifi off/on cycle (i shutdown Wifi during the night).
Any idea ?
Thanks,
Eddy
Hi, i have finally managed to connect spa outside and i have already encoutered this behaviour too. I will have to investigate. Now, my spa says it’s online, but i cannot send any commands to it (errno 104)
Reloading the intergration helps to unstuck it, no need to restart HA
Hi @ecou2508 , I just updated the integration and the python package following up with the issue posted by elkropac. I hope it solves your issue !
If not, could you log it on the integration issue board, please ?
Hi Mathieu-mp.
Just a quick message to thank you , elkropac and everyone involved for this integration. It works pretty well right now, on a 2022.7 HA.
Best regards,
Julien.
Hi @Djes and @JulienT-FL , is your spa model on this page? and which one is it exactly ? (no of people, round/square, color)
https://www.intex.fr/shop/34-spa-gonflable
I’m trying to find a mapping between data retrieved from a “type 3” info and the commercial model or reference.
Hey,
My model is the Greywood 6 persons 28442EX. Or Baltik 6p for France.
Hi, do you know, if it’s possible to create entitites in disabled state when adding spa to HA?
You could probably disable some switches for known models.
For example I have Greywood deluxe for 4 people and there are no jets and no sanitizer (i believe - what does it do?) - these controls are not shown in intex app, but you can still call the on/off commands using your library and the spa control unit responds to it and renders state in response
Of course, nice suggestion.
I’ve just created the corresponding feature request
Most challenging part is to assert that our interpretation of the spa info message is accurate, so that the spa model is correct. And to map the corresponding features (easy).
@mathieu-mp Hi, i’m trying to upgrade to version 2b69d0c , but I’m unable to open upgrade dialog in hacs. What can be wrong?
my spa is Intex Carbone 6 places. : 28462EX
