after adding the above code and restarting i am getting this error… any ideas where to start?
root@bb8:/usr/share/hassio/homeassistant/custom_components/vesync# cat /usr/share/hassio/homeassistant/home-assistant.log | grep vesync
2019-08-27 14:38:59 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for vesync which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2019-08-27 14:38:59 INFO (MainThread) [homeassistant.setup] Setting up vesync
2019-08-27 14:39:00 ERROR (MainThread) [homeassistant.setup] Error during setup of component vesync
File "/config/custom_components/vesync/__init__.py", line 26, in setup
KeyError: 'vesync'
2019-08-27 14:39:01 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform vesync.switch: Unable to set up component.
