Here the same. My iphone 14 with ios17 freeze all time. Not my Android device.
Same here. Stuck at History graph. iOS 17.0.3. Latest version of the Companion app.
No issues when using HA without the app with Safari
Has anyone found a workaround the get out of the history graph page or is the complete reinstall needed for the app?
Edit. I found a way to nagivate out of the frozen view; kill the app and restart. Quickly (within the first second) tap the menu item top left and navigate away to a working view. The window the do this is very short. If you miss it, the app will remain frozen. But luckily doable and no reinstall needed.
Exactly the same error here. Last night I installed IPadOS 17. Now on this device the HA UI also gets blocked/frozen, like on the IPhone with IOS17.
Before the upgrade, on the IPad with OS 16 HA worked just fine.
I found no way to downgrade back to IpadOS/IOS 16.
Same problem with me: I had history graphs on the default dashboard.
I moved the History card to a different dashboard. The problem disappeared from the default db, it occurs now on the other db.
So the problem is connected to IOS17 + History card
I also experience the freeze problem. Installed IOS 17.1.1 today and noticed the problem straight after the upgrade. I removed and re-installed HA app and after the first load it initially looked better, but after the first screen lockscreen the problem is back.
I also have busy dashboards with graphs. Never had any issues before IOS17.
Anybody found a permanent fix other than to downgrade to IOS16?
I posted my workaround to the issue here: App and WebUI freeze in iOS 17 · Issue #17967 · home-assistant/frontend · GitHub
Hello, looks like the problem with iOS17.2 and Mac OS14.2 is solved. Hallo, sieht so aus als wäre das Problem mit iOS17.2 und Mac OS14.2 behoben.
