[WORKGROUP\WINDOWS_10_VM][2019-06-21 16:27:48 +03:00][INFO][IOTLinkService.Service.Engine.ServiceAddonManager]: Addon Commands has subscribed to topic commands/volume/mute
[WORKGROUP\WINDOWS_10_VM][2019-06-21 16:27:48 +03:00][INFO][IOTLinkService.Service.Engine.ServiceAddonManager]: Loading addon: commands
[WORKGROUP\WINDOWS_10_VM][2019-06-21 16:27:49 +03:00][INFO][IOTLinkService.Service.Engine.ServiceAddonManager]: System monitor is activated.
[WORKGROUP\WINDOWS_10_VM][2019-06-21 16:27:49 +03:00][INFO][IOTLinkService.Service.Engine.ServiceAddonManager]: Loading addon: windowsmonitor
[WORKGROUP\WINDOWS_10_VM][2019-06-21 16:27:49 +03:00][INFO][MQTTnet.Client.MqttClient]: Connection established successfully.
It seems to have connected without a problem.
Remember to replace the iotlink/workgroup/my-computer
topic prefix accordingly with your configurations.
What I understand is - WORKGROUP\WINDOWS_10_VM
And so I did:
platform: mqtt
name: âWinDows 10 VM - Connectedâ
state_topic: âiotlink/workgroup/windows_10_VM/lwtâ
value_template: â{{ value }}â
payload_on: âONâ
payload_off: âOFFâ
device_class: âconnectivityâ
qos: 1
But I get an error:
what am I missing?
Schneider
(Antonio Schneider)
June 21, 2019, 2:30pm
22
Hello!
Have you tried to debug it with MQTT Explorer? It is a great app to monitor MQTT messages. You can check if your VM is connected to the broker and sending messages.
https://www.microsoft.com/store/productId/9PP8SFM082WD
This is my connected binary sensor:
- platform: mqtt
name: "Desktop - Conectado"
state_topic: "iotlink/workgroup/desktop/lwt"
value_template: "{{ value }}"
payload_on: "ON"
payload_off: "OFF"
device_class: "connectivity"
qos: 1
Can you check if messages are being sent?
Thanks.
I do not understand, you can show me your log file like mine. This name from where was taken?
alexslx
(Alexandre Leites)
June 21, 2019, 3:35pm
24
Hey,
MQTT is case-sensetive, I saw you put iotlink/workgroup/windows_10_VM/lwt
instead of iotlink/workgroup/windows_10_vm/lwt
. May it be the case?
The name is get from here: https://gitlab.com/iotlink/iotlink/wikis/FAQ#wiki-where-do-i-find-my-domainname-and-machinename
Give it a try.
binary_sensor:
- platform: mqtt
name: "WinDows 10 VM - Connected"
state_topic: "iotlink/workgroup/windows_10_vm/lwt"
payload_on: "ON"
payload_off: "OFF"
qos: 1
- platform: mqtt
name: "WinDows 10 VM - Charging"
state_topic: "iotlink/workgroup/windows_10_vm/lwt/windows-monitor/stats/power/status"
payload_on: "Online"
payload_off: "Offline"
device_class: "plug"
availability_topic: "iotlink/workgroup/windows_10_vm/lwt"
payload_available: "ON"
payload_not_available: "OFF"
qos: 1
- platform: mqtt
name: "WinDows 10 VM - Battery Status"
state_topic: "iotlink/workgroup/windows_10_vm/lwt/windows-monitor/stats/battery/status"
qos: 1
- platform: mqtt
name: "WinDows 10 VM - Idle Time"
state_topic: "iotlink/workgroup/windows_10_vm/lwt/windows-monitor/stats/idle-time/my_user"
unit_of_measurement: 'seconds'
icon: mdi:timer
qos: 1
- platform: mqtt
name: "WinDows 10 VM - CPU Usage"
state_topic: "iotlink/workgroup/windows_10_vm/lwt/windows-monitor/stats/cpu"
unit_of_measurement: '%'
icon: mdi:speedometer
qos: 1
- platform: mqtt
name: "WinDows 10 VM - RAM Usage"
state_topic: "iotlink/workgroup/windows_10_vm/lwt/windows-monitor/stats/memory/usage"
icon: mdi:memory
qos: 1
- platform: mqtt
name: "WinDows 10 VM - RAM Available"
state_topic: "iotlink/workgroup/windows_10_vm/lwt/windows-monitor/stats/memory/available"
unit_of_measurement: 'MB'
icon: mdi:memory
qos: 1
- platform: mqtt
name: "WinDows 10 VM - RAM Used"
state_topic: "iotlink/workgroup/windows_10_vm/lwt/windows-monitor/stats/memory/used"
icon: mdi:memory
qos: 1
- platform: mqtt
name: "WinDows 10 VM - RAM Total"
state_topic: "iotlink/workgroup/windows_10_vm/lwt/windows-monitor/stats/memory/total"
icon: mdi:memory
qos: 1
- platform: mqtt
name: "WinDows 10 VM - Remaining Battery"
state_topic: "iotlink/workgroup/windows_10_vm/lwt/windows-monitor/stats/battery/remaining-percent"
device_class: battery
qos: 1
- platform: mqtt
name: "WinDows 10 VM - Remaining Battery Time"
state_topic: "iotlink/workgroup/windows_10_vm/lwt/windows-monitor/stats/battery/remaining-time"
unit_of_measurement: 'minutes'
icon: mdi:timer
value_template: "{{ ( value | float / 60 ) | int }}"
qos: 1
- platform: mqtt
name: "WinDows 10 VM - Predicted Lifetime"
state_topic: "iotlink/workgroup/windows_10_vm/lwt/windows-monitor/stats/battery/full-lifetime"
icon: mdi:timer
qos: 1
- platform: mqtt
name: "WinDows 10 VM - HDD Usage (C)"
state_topic: "iotlink/workgroup/windows_10_vm/lwt/windows-monitor/stats/hard-drive/c/drive-usage"
icon: mdi:chart-donut
qos: 1
- platform: mqtt
name: "WinDows 10 VM - HDD Total Size (C)"
state_topic: "iotlink/workgroup/windows_10_vm/lwt/windows-monitor/stats/hard-drive/c/total-size"
icon: mdi:harddisk
qos: 1
- platform: mqtt
name: "WinDows 10 VM - HDD Total Free Space (C)"
state_topic: "iotlink/workgroup/windows_10_vm/lwt/windows-monitor/stats/hard-drive/c/total-free-space"
icon: mdi:harddisk
qos: 1
- platform: mqtt
name: "WinDows 10 VM - HDD Free Space (C)"
state_topic: "iotlink/workgroup/windows_10_vm/lwt/windows-monitor/stats/hard-drive/c/available-free-space"
icon: mdi:harddisk
qos: 1
- platform: mqtt
name: "WinDows 10 VM - HDD Used Space (C)"
state_topic: "iotlink/workgroup/windows_10_vm/lwt/windows-monitor/stats/hard-drive/c/used-space"
icon: mdi:harddisk
qos: 1
- platform: mqtt
name: "WinDows 10 VM - HDD Format (C)"
state_topic: "iotlink/workgroup/windows_10_vm/lwt/windows-monitor/stats/hard-drive/c/drive-format"
unit_of_measurement: ''
icon: mdi:harddisk
qos: 1
- platform: mqtt
name: "WinDows 10 VM - HDD Label (C)"
state_topic: "iotlink/workgroup/windows_10_vm/lwt/windows-monitor/stats/hard-drive/c/volume-label"
icon: mdi:harddisk
qos: 1
alexslx
(Alexandre Leites)
June 21, 2019, 3:53pm
27
just the first one needs the â/lwtâ part, the other ones you need to strip it off the state_topic and keep on the availability_topic, eg:
- platform: mqtt
state_topic: "iotlink/workgroup/windows_10_vm/windows-monitor/stats/power/status"
qos: 1
WinDows 10 Vm - HDD Used Space Š
Can you change the code that it will display in gb? For example 39.5 gb
theDiver
(Søren Reinke)
June 22, 2019, 8:36pm
31
Hi there
I have a strange problem.
When i run mosquitto_sub -v -h 10.0.0.130 -p 1883 -t '#'
on my raspberry pi to see what messages are being send i keep getting:
iotlink/workgroup/server/lwt ON
Immediately followed by:
iotlink/workgroup/server/lwt OFF
I get information about harddrives, cpu and all that, but HA does not show anything because it thinks the system is off
Any clue what i can do?
I am running 1.1.3
alexslx
(Alexandre Leites)
June 23, 2019, 2:00am
32
Have you changed retain settings?
This is probably because you have one retained message in the same topic.
You can try cleaning it by shutting off IOTLink and then using home assistant mqtt.publish service with the following data
"topic": "iotlink/workgroup/server/lwt",
"payload": "",
"qos": 1,
"retain": true
theDiver
(Søren Reinke)
June 23, 2019, 5:21am
33
Hi Alexandre, thanks for the quick answer.
I donât think i changed the retain setting. It pretty much just the examples from your website.
No i just get OFF followed by ON, and now it keeps repeating?
I have the following configuration.yaml on the server being monitored:
mqtt:
tcp:
enabled: true
hostname: 10.0.0.130
port: 1883
secure: false
websocket:
enabled: false
uri:
secure: false
qos: 1
retain: false
lwt:
enabled: true
qos: 1
retain: true
connectMsg: "ON"
disconnectMsg: "OFF"
clientId: server
prefix: iotlink
cleanSession: true
logging:
enabled: true
level: 4
addons:
enabled: true
globalTopics:
- homeassistant/#
On the HA server i have this configuration.yaml, i removed all not MQTT things to make it shorter, and also only showed a few of the sensors, I have 6 harddrives in my server so itâs quite big.
mqtt:
client_id: Server
broker: 10.0.0.130
port: 1883
binary_sensor:
- platform: mqtt
name: "My Computer - Connected"
state_topic: "iotlink/workgroup/server/lwt"
payload_on: "ON"
payload_off: "OFF"
qos: 1
- platform: yr
- platform: mqtt
name: "Server - Idle Time"
state_topic: "iotlink/workgroup/server/windows-monitor/stats/idle-time/my_user"
icon: mdi:timer
availability_topic: "iotlink/workgroup/server/lwt"
qos: 1
- platform: mqtt
name: "Server - CPU Usage"
state_topic: "iotlink/workgroup/server/windows-monitor/stats/cpu"
qos: 1
alexslx
(Alexandre Leites)
June 24, 2019, 2:05am
34
I canât see anything wrong with your configuration.
Only what might be an issue is that you removed the credentials part of mqtt configuration. If you donât use, just leave it blank
mqtt:
credentials:
username:
password:
Can you check your logs and see if there is anything there?
theDiver
(Søren Reinke)
June 24, 2019, 7:42am
35
Hi Alexandre
Thanks again, that actually did the trick
Everything seems to be working now.
Hi @alexslx and @Schneider ,
Thanks for the Great Work (made me abendon my own MqttClient).
Iâm Trying to add my own Addon and for some reason can find The interface to impliment (yes,
working with Dot.Net 4.7.2 and add the referrence needed to IOTLinkApi).
My goal is to add little Mqtt Monitor that allows me to to monitor all the Mqtt messages,
and one more is to create TTS service that can be used to Send alerts to my pc Speakers.
Can you help me with it?
theDiver
(Søren Reinke)
June 24, 2019, 10:04am
37
Hi Abeksis
Would you please share how you made that good looking design?
I specially like the way you show disk/ram/cpu data
theDiver
(Søren Reinke)
June 24, 2019, 12:09pm
39
Hi @alexslx
How often does your system send the information?
The WindowsMonitor config.yaml is the standard one like this:
monitors:
CPU:
enabled: true
interval: 10
cacheable: false
Memory:
enabled: true
interval: 10
cacheable: false
(removed some to shorten it)
But i can see now MQTT messages are being received by the broker, and the numbers donât change.
Is the âinterval in secondsâ ?
