I finally was able to get a binary sensor created to reflect in-camera motion detection of my FDT camera. FDT cameras are very similar to Foscam, but they don’t have a corresponding cgi command that I could use to trigger automations in Home Assistant (at least that I could find). Here are the steps in case anyone else could use them. Basically, the binary sensor is “on” when motion was detected within the past 60 seconds.
- Temporarily install the “FDT View” app on your phone.
- Connect to the camera on the app and under settings -> alert, select push notifications.
- Add this to configuration.yaml changing CAMERAIP to your ip address:
- platform: command_line
name: fdt motion raw
command: "curl -s -k http://CAMERAIP/web/tmpfs/push_record.log | tail -1 | cut -c3-"
value_template: "{{ as_timestamp(now()) | float - value | float }}"
binary_sensor:
sensors:
fdt_motion:
friendly_name: "FDT Motion"
value_template: >-
{{ states('sensor.fdt_motion_raw') | float < 60 }}
- Remove app from phone
Also, my motion trigger was too sensitive, and I couldn’t properly set the sensitivity from the webpage configuration so I used the following command. Play with the “s=xx” option to find the right sensitivity for you (0-100):
curl -k "http://CAMERAIP/cgi-bin/hi3510/param.cgi?cmd=setmdattr&-enable=1&-s=10&-name=1&-x=0&-y=0&-w=1920&-h=1080&-usr=admin&-pwd=xxxxxxxx"
