IR blaster with lolin IR Shield
Hello everyone!
I’m having issues while trying to use my Wemos d1 mini with a lolin ir shield attached.
I’m trying to “smartify” my daikin AC that has this remote:
For testing purposes, I’m using a Xiaomi 20000mA powerbank to power the wemos.
This is my yaml:
esphome:
  friendly_name: AC Sala
esp8266:
  board: esp01_1m
# Enable logging
logger:
  level: DEBUG
  baud_rate: 0
# Enable Home Assistant API
api:
  encryption:
    key: "encryptionkey"
ota:
  password: "otapassword"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Ac-Sala Hotspot"
    password: "password"
captive_portal:
remote_receiver:
  pin:
    number: GPIO2
    inverted: true
    mode:
      input: true
      pullup: true
  dump: raw
remote_transmitter:
  pin: GPIO0
  carrier_duty_percent: 50%
climate:
  - platform: daikin
    supports_cool: True
    supports_heat: True
    receiver_id: rcvr
    visual:
      min_temperature: 16
      max_temperature: 30
      temperature_step: 1
While sending signals with daikin remote, I can see in logs the lolin ir receiver part working. But sending signals with this wemos is another story. With my phone camera I can see the IR leds working while I’m sending instructions. But my AC doesn’t get the instructions. And I tried with the wemos just in front of the AC receiver (2cm near), but with no luck.
I tried also the daikin_brc protocol and the arduinoheatpump_ir protocol with all daikin variations, also with no luck.
I had luck with my android phone IR and with a broadlink rm4 mini.
Can someone help me?
Thanks!
It is hard to tell from your pictures, but if you are using the official LOLIN IR Shield and an official LOLIN D1 Mini, (and you have not intentionally changed the pins around) the default pin settings should be D3 and D4.
Try changing your receive pin to D4 and your transmit pin to D3 and see if that helps. This is from a working board on my network, with a lolin d1_mini and ir shield:
remote_receiver:
  pin: D4
  dump: raw
remote_transmitter:
  pin: D3
button:
    on_press:
      - remote_transmitter.transmit_pronto:
          data: "0000 006D 0022 0000 0163 00AD 0017 0016 0017 0040 0017 0016 0017 0016 0017 0016 0017 0016 0017 0016 0017 0016 0017 003F 0017 0016 0017 0040 0017 0040 0017 0040 0017 0040 0017 0040 0017 0040 0017 0016 0017 0016 0017 0016 0017 0016 0017 0016 0017 0016 0017 0016 0017 0016 0017 0040 0017 0040 0017 0040 0017 0040 0017 0040 0017 0040 0017 0040 0017 0040 0017 06C3"
    on_press:
          data: "0000 006D 0022 0000 0163 00AD 0017 0016 0017 0040 0017 0016 0017 0016 0017 0016 0017 0016 0017 0016 0017 0016 0017 0040 0017 0016 0017 0040 0017 0040 0017 0040 0017 0040 0017 0040 0017 0040 0017 0016 0017 0040 0017 0016 0017 0016 0017 0016 0017 0016 0017 0016 0017 0016 0017 0040 0017 0016 0017 0040 0017 0040 0017 0040 0017 0040 0017 0040 0017 0040 0017 06C3"
It doesn’t accept the use of D3 and D4 pins, I don’t know why, but when installing firmware, it only accepts pins in GPIO format.
I tried with a broadlink rm4 mini and the smartir integration with home assistant.
I have the following codes from smartir:
  "manufacturer":"Toyotomi",
  "supportedModels":[
    "AKIRA GAN/GAG-A128 VL"
  "supportedController":"Broadlink",
  "commandsEncoding":"Base64",
  "minTemperature":16,
  "maxTemperature":30,
  "precision":1,
  "operationModes":[
    "heat",
    "cool",
    "fan_only"
  "fanModes":[
    "low",
    "mid",
    "high",
    "auto"
  "commands":{
    "off":"JgCSAAABKZEXNBgQFxEXEBc1FxAYEBcQGDQXERcQGDQXERcQFxEXEBcRFxAYEBcQGBAXNRcQFxEXEBcRFxAYEBc1FxAXNRcQGBAXNRcQFwACjhcQGBAXEBgQFxEXEBcRFxAXERcQGBAXEBgQFzQYEBcRFxAYEBcQGBAXEBgQFxEXEBcRFxAXERcQGBAXNBg0FxEXAA0FAAAAAAAA",
    "heat":{
      "low":{
        "16":"JgCSAAABKZIXEBcRFzQYNBc1FxAYEBcRFxAXERcQFxEXEBcRFxAXERcQGBAXERcQFxEXNBcRFxAXERcQFxEXERc0FxEWNRcRFxEXNBcRFwACjhcQFxEWERYSFhEXERYRFxEWEhYRFxEWERYSFjUXERcQFxEWEhcQFxEWERYSFhEWEhYRFhIWEhYRFhIWERYSFjUWAA0FAAAAAAAA",
        "17":"JgCSAAABJ5QXERUSFTcVNhU3FxEWERUTFTYXERcRFRIWEhUSFRMVEhUTFRIVExUSFRMXNRUSFxEVEhUTFRIVExU3FRIVNxUSFRMXNRUSFQACkBUTFRIVExUSFxEVEhUTFRIVExUTFRIVExUSFTcVEhUTFxEWERcRFRIVExYRFRMVEhUTFRIVExUTFTYVExcQFTcVAA0FAAAAAAAA",
        "18":"JgCSAAABKZEXERcQFzUXNRc0GBAXEBgQFxAXNRcRFxAYEBgPGBAXEBgQFxAYEBcRFxAYNBgPGBAXEBgQGBAXEBc1GA8XNRcRFhEYNBgPGAACjRgQFxAYEBcQGBAXEBcRFxEXEBcRFxAXERcQGDQYDxcRGA8YEBcRFxAXERcQGBAXEBcRFxAXERgQFxAYNBgPFzUXAA0FAAAAAAAA",
        "19":"JgCSAAABKZEXEBcRFzQYNBc1GA8XERgPGDQXNRcQFxEYDxgQGA8YEBcRFxAYEBcQFxEXNBgQFxAYEBcRFxAXERc0FxEYNBcQFxEYMxgQFwACjhcQGBAXEBgQGA8YEBcQFxEXERcQGBAXEBgQGDMYEBgQFxAXERcQGBAYDxcRFxAXERcQGBAYEBcQFzUXNBgQFzUYAA0FAAAAAAAA",
        "20":"JgCSAAABJpQVEhUTFTYVNxU3FRIVExUSFRMVExQ3FRMVEhUTFRIVExUSFRMVEhUTFRMVNhUTFRIVExUSFRMVExU2FRMVNhUTFRMUNxUTFQACjxUTFRMUFBQTFRIVExUSFRMVEhUTFRIVExUTFDcVExUSFRMVEhUTFRIVExUTFRIVExUSFRMVEhUTFRIVExU3FTYVAA0FAAAAAAAA",
        "21":"JgCSAAABKJEXERcRFjUXNRc1FhEXERYRFzUXERY1FxEWERcRFRIXERcQFxEXERUSFRMVNhUTFhEXERUTFBMVExY1FxEWNRcRFRMVNhUTFQACkBUSFRMWERcRFhEXERcQFxEXEBcRFxEWERcRFjUVExYRFxEXERYRFxEWERcRFhEXERcQFxEXERYRFzUWERc1FzUWAA0FAAAAAAAA",
        "22":"JgCSAAABKJEYEBcRFzQXNRc1FxAXERcQFxEXNRc0FxEYDxcRGA8YEBgQFxAXERcQGBAXNBgQGBAWERgQFxAXERgzGBAXNRcQFxEXNBcRGAACjRcQGBAYDxcRFxAYEBgQFxAXERcQGBAYDxcRFzUYEBcQFxEYEBcQFxEXEBcRFxAXERcQGBAYDxgQGA8YNBc1GDMYAA0FAAAAAAAA",
        "23":"JgCSAAABKJIVEhUTFTYVNxU3FRIVExUSFTcVNxU2FRMVExUSFRMVEhUTFRIVExUSFRMVNxUSFRMVEhUTFRIVExU3FRIVNxUSFRQUNhUTFQACkBUSFRMVExQTFRMVEhUTFRIVExUSFRMVExQTFTcVEhUTFRIVExUSFRMVExUSFRMVEhUTFRIVExUSFTcVNxU2FTcVAA0FAAAAAAAA",
        "24":"JgCSAAABKJIXEBcRGDMXNRc1GA8XERgPGBAYDxcRFzUXEBgQFxAYEBcQGBAYDxcRFxEXNBcRFxAYEBcQGBAXERc0GBAXNBgQGA8YNBgQFwACjRcRGBAXEBgQFxAYEBcQFxEXEBcRGA8XERcRFzQYEBgPFxEXEBcRFxEXEBcRFxAYEBcQFxEXEBcRGA8YEBgQFxAYAA0FAAAAAAAA",
        "25":"JgCSAAABJ5MVExUTFDcWNhU2FRMVExYRFTcWERYSFTcWERUTFhEVExYRFhIVEhYSFhIUNxYSFhEVExYRFhIVEhY2FhIVNhUTFhEWNhYSFgACjhcSFRIWEhYRFhIVExQTFhIWERUTFhEWEhYRFTcVExUSFhIWERYSFRIVExUSFhIVExUSFRMVEhUTFTYVExUTFhEWAA0FAAAAAAAA",
        "26":"JgCSAAABJpQVEhUTFTcVNhU3FRMVEhUTFRIVNxUSFTcVExUSFRMVEhUTFRIVExUTFBMVNxUSFRMVEhUTFRMUExU3FRIVNxUTFBMVNxUSFQACkBUTFRMVExQTFRMVEhUTFRIVExYRFRMVEhUTFTcVEhUTFRIVExUSFRMVExQTFRMVEhUTFRIVExUSFRMVNxUSFRMVAA0FAAAAAAAA",
        "27":"JgCSAAABKJMXEBcRFzQYNBc1FxAXERcRFjUXNRcQGDQXERcQFxEXEBcRFxAYEBcQGBAXNRcQFxEXEBcRFxAXERc1FxAXNRcQGBAXNRcQFwACjhcRFxAXERcQFxEXEBcRFxAYEBcQGBAXERcQFzUXEBcRFxAYEBcRFxAXERcQFxEXEBcRFxAXERcQFzUXNRcQFxEXAA0FAAAAAAAA",
        "28":"JgCSAAABKZEXERcQFzUXNRc0FxEXEBgQFxEXEBc1FzQXERcQGBAXERcQFxEXEBcRFxAXNRcRFxAXERcQFxEXEBc1FxAYNBcRFxAXNRcQGAACjRcRFxAXERcQGBAXEBgQFxEXEBcRFxAXERcQFzUXERcQFxEXEBcRFxAXERcQGBAXEBgQFxEXEBcRFxAXERc0GBAXAA0FAAAAAAAA",
        "29":"JgCSAAABKJIXERYSFjUXNRY2FxAWEhYRFjYWEhY1FzUWERcRFxAXERYSFxAXERYRFxEWNRgQFxEXEBcRFhEXERc1FxAXNRcQFxEXNBcRFwACjhcQFxEXEBcRFxEXEBcRFxAWEhcQFxEXEBcSFjUYEBcRFxAXERcQFxEWERcRFxAXERYSFhEXERcQFzUXEBc1FxEXAA0FAAAAAAAA",
        "30":"JgCSAAABKJIWEhYRFjYWNhY1FhIWERYSFhIWNRY2FjUXERYSFhEWEhYRFhIWERYSFxAXNRYSFhEWEhcQFxEWERY2FhIWNRYSFxAXNRcRFwACjRcRFxAXERcRFxAXERcQFxEXEBcRFxAXERcQFzUXERcQFxEXEBcRFxAXERcQGBAXERcQFxEXEBcRFxAXNRc1FxAXAA0FAAAAAAAA"
      "mid":{
        "16":"JgCSAAABKJIXEBcRFzUXNBcRFzUXEBcRFxAXERcQFxEXEBcRFxEWERcRFhEWEhcQFxEXNRYRFxEWERcRFxAXERc1FhEXNRcQFxEXNRYRFwACjhcQFxEXERYRFxEWERcRFxAXERcQFxEXERYRFzUXERcRFhEXERcQFxEXEBcRFxEWERUTFhEXERcQFxEXEBcRFTcWAA0FAAAAAAAA",
        "17":"JgCSAAABJpQVEhcRFTcUNxUTFzQVExUSFTcVExUSFRMVEhYSFRIVExUTFRIVExUSFRMVNhUTFRIVExYSFRIVExU2FRMVNxUSFRMVNhUTFgACjxUSFRMVEhUTFRIVExUSFRMVExUSFRMVEhUTFTYVExUSFRMVExQTFRMVEhUTFRIVExUSFRMVExUSFjYVEhUTFTcVAA0FAAAAAAAA",
        "18":"JgCSAAABJ5MVExUTFTYXNRUSFTcVExUSFRMVNhUTFRMWERcRFRIVExUSFRMXEBUTFRMUNxcRFRIVExYRFRMXERQ3FRMVNhcRFxEUNxUTFQACjxUTFRMVEhUTFRIVExUSFRMVExQTFRMVEhcRFTYVExcRFBMVExUSFRMVEhUTFRIVExUSFRMVExUSFxEVNhUTFTcWAA0FAAAAAAAA",
        "19":"JgCSAAABJ5MXERUTFTYVNxUSFTcVExUSFTcVNxUSFRMVEhcRFxAVExUSFRMVExYRFRMVNhUTFRIVExUTFRIVExU2FRMVNxQTFRMVNhUTFQACkBUSFRMVEhUTFhEVExUSFRMVExUSFRMVEhUTFTYVExUTFRIVExUSFRMVEhUTFRIVExUTFBMVExUSFTcVNhUTFTcVAA0FAAAAAAAA",
        "20":"JgCSAAABJpMWEhUTFTYVNxUTFTYVExUSFRMWERU3FRMVEhUTFRIVExUSFRMVEhYSFRMUNxUTFRIVExUSFRMVEhU3FhIVNhUTFRIWNhUTFQACjxUTFRMVExUSFRMVExQTFRMVEhUTFxAVExUSFTcVExUSFRMVEhUTFRIVExYRFRMVExUSFRMVEhUTFRIVExU3FTYVAA0FAAAAAAAA",
        "21":"JgCSAAABKJQWEhUSFTcVNhYSFTcVEhYSFTYVExU3FRIVExUSFRMVEhUTFRMVEhUTFRIVNxUSFRMVEhYSFRMVEhU3FhEVNxUTFRIVNxYRFQACkBUTFRIVExUSFRMVEhUTFRIVExYSFRIVExUSFTgVEhUTFRIVExUTFRIVExUSFRMVEhUTFRIVExUTFDcVExU2FTcVAA0FAAAAAAAA",
        "22":"JgCSAAABJpQVEhUTFzQVNxcRFjUVExUTFBMVNxU2FRMVExQTFRMVEhcRFRIVExUSFRMVNxYRFxEVEhUTFxAXERU3FRIXNRUSFRMVNxUSFQACkBUSFRMXERUSFxEVEhcRFxAVExUTFBMXERYRFzUXEBUTFRIVExcRFRIXERUSFxEVEhUTFRIVExUTFRIVNxU2FzUVAA0FAAAAAAAA",
        "23":"JgCSAAABJpQVEhUTFzQXNRcRFTYXERUSFTcXNRU2FRMXEBcRFxEWERUTFhEXERUSFRMXNRUSFxEVEhcRFRIVExc1FhEVNxUSFRMXNRUSFQACkBUSFxEVEhcRFxEVEhcRFxAVExUSFxEXERQTFzUVEhcRFxAXERcQFRMXERUSFRMVEhUTFRIXERcQFjYVNxc0FTcVAA0FAAAAAAAA",
        "24":"JgCSAAABJ5QVEhcRFTcWNRcRFTYWEhcRFhEXERUSFTcVEhUTFRMWERUTFRIXERUSFxEVNhUTFRMWERUTFxAVExU2FRMVNxUSFRMVNhUTFQACkBcQFRMXEBcRFxAVExcRFhEVExYRFRMVEhUTFzUUExUTFRIVExYRFRMVEhcRFRIVExUTFRIVExUSFRMXEBUTFxAVAA0FAAAAAAAA",
        "25":"JgCSAAABKJMVExUSFzUVNxYRFzUVEhUTFTcVEhUTFTYXERUSFxEVExUSFRMVEhUTFRIVNxUTFRIVExUSFRMWERc1FRMVNhUTFhEVNxUSFQACkBUUFhEVExUSFRMVEhUTFRIVExUSFxEXERYRFTcVEhcRFRIVExUTFBMVExYRFRMWERUTFRIVExcQFzUVExUSFRMXAA0FAAAAAAAA",
        "26":"JgCSAAABJpQVEhcRFzUWNRUTFTcUExUTFhEXNRcQFTcXERYRFRMVEhUTFxAVExcQFRMXNRUSFxEVEhcRFRIXERc1FhEXNRcQFxEVNxUSFQACkBcQFxEVExUSFxEVEhcRFRIXERUSFxEVExQTFTcWERUTFRIVExcQFxEVExQTFxEWERcRFhEVExUSFRMXNRUSFRMWAA0FAAAAAAAA",
        "27":"JgCSAAABKZEXERcRFjUVNxUTFDcXERUSFTcVNxUSFzUVEhcRFRIVExcRFRIVExUSFRMVNhUTFRMVEhcRFRIVExU3FxEXNBUTFxEVNhUTFQACjxYSFRMWERcRFRIXERUSFRMVEhUTFRMVEhUTFTYXERUSFRMXERUSFRMVEhUTFRIVExUSFxEVExQTFTcVNhcRFRMWAA0FAAAAAAAA",
        "28":"JgCSAAABJ5QWERcRFTYVNxUTFDcVExUSFRMVEhU3FzUXEBUTFxAVExUTFBMXERYRFRMVNhcRFRMUExUTFhEVExU2FxEXNRUSFRMVNhcRFQACkBUSFRMVEhcRFhEXERUTFhEXERYRFxEVEhUTFTcUExcRFRIVExUSFRMVEhUTFxEWERcRFRIXERcQFRMXEBc1FRMVAA0FAAAAAAAA",
        "29":"JgCSAAABKJIVEhcRFTcWNRUTFTYXERUTFjUXERU3FDcVExUSFRMXEBUTFxEWERUTFRIXNRUSFxEXEBUTFxEVEhU4FRIVNxUSFRMVNxUSFwACjhcQFRMVExUSFRMWERUTFRIVExUSFRMXERQTFzUVEhcRFRIVExUTFBMXERUSFRMVEhUTFxAVExcRFTYVExc0FxEVAA0FAAAAAAAA",
        "30":"JgCSAAABJ5QWERUTFTcWNRUTFTYVExcRFRIVNxU3FjUVExUSFRMVExYRFRMVEhcRFRIVNxUSFRMVExYRFRMVEhU3FRIVNxUTFhEXNRUSFQACkBcRFRIVExcQFRMVEhcRFRMVEhUTFRIVExUSFTcXEBcRFRMVEhUTFRIVExUSFRMVEhUUFRIVExUSFRMVNxU2FRMXAA0FAAAAAAAA"
      "high":{
        "16":"JgCSAAABKZIWERcRFzQXNRc1FjUVExcQFRMXERYRFxEWERcRFRIXERUSFRMVExYRFRMVNhcRFxAXERcRFBMVExU2FxEXNBcRFxEVNhcRFQACkBUSFxEVEhUTFRIVExUSFRMVExQTFRMVEhUTFTYXERUSFxEVExUSFRMWERUTFRIVExUSFxEVEhUTFRMVEhUTFTYVAA0FAAAAAAAA",
        "17":"JgCSAAABKZEXERcRFjUXNRc1FjUXERcQFxEXNBcRFxEWERcRFxAXERcQFxEXEBcRFxEWNRcRFxAXERcQFxEXERY1FxEXNBcRFRMWNRcRFgACjhcRFxEWERcRFhEXERcQFxEVEhcRFxAXERcRFjUXERcQFxEXEBcRFxEVEhcRFhEXERcQFxEXEBcRFRMWNRcRFzQXAA0FAAAAAAAA",
        "18":"JgCSAAABKZIWERcRFzQXNRc1FzQXERcRFjUXNRcQFxEXERYRFxEWERcRFRIVExcQFRMXNRYRFxEXEBcRFRIXERc1FhEXNRUSFxEXNRYRFwACjhcQFxEXEBcRFxEWERcRFhEXERYRFxEXEBcRFzUWERUTFRIXERUSFRMXEBUTFxEWERcRFhEXERYRFTcXNRYRFzUXAA0FAAAAAAAA",
        "19":"JgCSAAABKZIWERcRFzQXNRc1FzQXERcRFjUXNRcQFxEXERYRFxEWERcRFRIVExcQFRMXNRYRFxEXEBcRFRIXERc1FhEXNRUSFxEXNRYRFwACjhcQFxEXEBcRFxEWERcRFhEXERYRFxEXEBcRFzUWERUTFRIXERUSFRMXEBUTFxEWERcRFhEXERYRFTcXNRYRFzUXAA0FAAAAAAAA",
        "20":"JgCSAAABKJIWERcRFjUVNxc1FzQVExcQFxEXERY1FxEXEBcRFxAXERcRFRIXERcQFxEXNBcRFxEWERcRFhEVExc0FxEVNxYRFRMXNBcRFQACkBYRFxEXEBcRFxAXERcRFRIXERYRFxEWERcRFzQXERcRFRIXERYRFxEWERcRFxAVExcRFBMXERUSFxEXEBU3FTcWAA0FAAAAAAAA",
        "21":"JgCSAAABJpQXEBcRFzUXNBc1FTcVEhcRFjUXERc1FhEXERcQFRMXEBUTFxEWERcRFRIXNRcQFxEVExYRFxEWERc1FxAXNRUTFxAXNRcQFwACjhcRFRIXERcQFxEXEBcRFxEWERcRFhEXERYRFzUXEBcRFxEWERcRFxAXERUSFRMXERYRFRMWERcRFzQXERc1FjUXAA0FAAAAAAAA",
        "22":"JgCSAAABKZIXERUSFzUXNBc1FzUXEBcRFxEUNxc1FRIXERcRFhEXERYRFRMVEhUTFRIXNRcRFhEXERUSFxEXEBU3FRMWNRcRFRIVNxUTFQACjxUTFRIXERcRFhEXERYRFRMVEhUTFRIVExUTFjUXERYRFxEVEhcRFxEUExUTFhEXERYRFxEWERUTFxAXNRU3FzQXAA0FAAAAAAAA",
        "23":"JgCSAAABJpQXEBcRFzUVNhc1FTcXEBcRFzQXNRc1FxAXERcQFRMXERYRFRMWERcRFxAXNRcRFhEXERYRFxEXEBU3FxEWNRcRFhEXNRcQFwACjhUTFxAXERcRFhEXERYRFxEWERcRFxAVExcQFzUXERYRFxEWERcRFhEXERcQFxEXERYRFxEVEhUTFTYXNRc1FjUXAA0FAAAAAAAA",
        "24":"JgCSAAABJ5QVEhcRFzUWNRc1FzUWERcRFhEXERcQFzUVExYRFxEWERcRFxAXERcQFxEXNRYRFRMVEhcRFxAXERc1FhEXNRcQFRMVNxYRFQACkBYRFxEXEBcRFxEWERcRFhEXERcQFxEXEBUTFTcVEhUTFhEXERcQFxEXEBcRFRMWERcRFRIXERUSFRMVExYRFxEWAA0FAAAAAAAA",
        "25":"JgCSAAABJpQWERUTFTYXNRc1FjUXERcRFjUXERYRFzUXERYRFxEWERcRFxAVExcQFxEXNRYRFxEVEhcRFxAXERU3FhEXNRcQFxEVNxYRFQACkBcQFxEVExYRFxEXEBcRFRIVExcRFhEXERYRFzUXEBcRFRIVExUTFhEXERYRFxEXEBcRFRIXERcQFzUXERUSFxEXAA0FAAAAAAAA",
        "26":"JgCSAAABKJIWERcRFjUXNRc1FTYXERcQFxEXNRYRFTcXEBcRFRMWERcRFhEXERcQFhIXNBcRFxEWERUTFhEXERc0FxEXNRYRFxEXNBcRFQACkBYRFxEVEhUTFxAXERcQFxEXERYRFxEWERcRFzQXERcRFhEXERYRFxEXEBUTFxAXERUTFhEXERYRFxEXNBcRFxAXAA0FAAAAAAAA",
        "27":"JgCSAAABKJIWERUTFjUXNRc1FTYVExcQFzUXNRYRFzUXEBcRFxEWERcRFhEVExYRFxEXNBcRFxEWERcRFRIXERc0FxEXNRYRFxEXNBcRFwACjhYRFxEWERcRFxAXERcQFxEVExYRFxEWERcRFzQVExcRFhEVExYRFxEXEBcRFRIVExcQFxEVExYRFzUXNBcRFxEWAA0FAAAAAAAA",
        "28":"JgCSAAABKJIXERYRFzUVNhc1FzUWERcRFxAXERc1FTYXERcQFxEXEBcRFxEWERcRFhEXNRcQFRMVExYRFxEWERc1FxAXNRcRFhEVNxcQFgACjxcQFxEVExYRFRMXEBcRFxAXERcQFxEXERUSFTcXEBUTFxAXERcQFxEVExYRFxEWERcRFxAXERcQFxEXERY1FxEVAA0FAAAAAAAA",
        "29":"JgCSAAABKZIWERcRFTYXNRU3FzQXERcRFjUXERc0FzUXERYRFxEXEBcRFxAXERcRFhEXNRcQFxEXEBUTFxAXERU3FxAXNRcQFxEWNhcQFwACjhcQFRMVExYRFxEWERcRFxAXERcQFRMXERYRFzUWERUTFxAXERcRFBMXERUSFxEXEBcRFRIXERUSFTcXERY1FxEXAA0FAAAAAAAA",
        "30":"JgCSAAABKZIXEBcRFzQXNRc1FTYXERcRFhEXNRY1FzUXERYRFxEXEBcRFxAVExcRFhEXNRYRFxEXEBcRFxEWERc1FxAXNRcQFxEXNRcQFwACjhcRFhEXERYRFxEXEBUTFxAVExcQFxEXEBcRFzUXEBcRFxAXERcQFxEXERYRFxEXEBUTFxAVExcQFxEXNRc0FxEXAA0FAAAAAAAA"
      "auto":{
        "16":"JgCSAAABKJEXERUTFTYXNRcRFhEVExYRFRMWERUTFRIXERcQFxEXERYRFxEWERcRFhEVNxcRFhEXERYRFxEWERc1FxEWNRcRFhEVNxcQFQACkBYSFxAXERcRFRIVExUSFxEWERUTFxAVExUSFTcXERUSFxEVEhcRFxAXERcQFxEXERYRFRMVEhUTFRIXERcQFzUVAA0FAAAAAAAA",
        "17":"JgCSAAABJ5QVEhUTFTYVNxcRFhEVExUSFzUVExUSFRMVEhUTFRIVExUSFxEVExQTFRMVNhUTFRIVExUSFRMVExQ3FxEVNhUTFRMVNhUTFQACjxUTFRMWERUTFhEVExUSFRMVEhUTFRIVExUTFjUVExcQFxEVEhUTFxEVEhUTFhEXERUSFRMVEhUTFzUWERcRFjUXAA0FAAAAAAAA",
        "18":"JgCSAAABJ5MVExcRFjUVNxcQFRMVExQTFxEWNRUTFRIVExcRFBMVExYRFRMVEhUTFRIVNxcRFhEXERYRFRMXEBU3FxEVNhUTFRIXNRUTFAACkBUTFRIVExUTFBMVExUSFRMVEhUTFRIVExUSFTcVExUSFRMVEhUTFRIVExcRFhEVExUSFRMVEhUTFRIVNxUTFjUVAA0FAAAAAAAA",
        "19":"JgCSAAABJpQXEBcRFTcWNRUTFRIXERUTFjUXNRUSFRMVExQTFRMWERUTFhEXERUSFxEXNBUTFRMWERUTFhEXERc0FRMVNxUSFxEXNBcRFwACjhYRFRQVEhcRFRIXERUSFRMXEBUTFRMVEhUTFTYXERUSFxEVExQTFxEWERUTFhEVExUSFRMXEBcRFTcWNRUTFzUVAA0FAAAAAAAA",
        "20":"JgCSAAABJpQWERUTFTYVNxUTFhEXERUSFRMXEBc1FRMVEhUTFRIVExcQFxEXEBcRFxEUNxUTFhEXERUSFxEXEBU3FRMVNhUTFxAVNxUTFgACjhcRFxAXERUSFhIVExUSFxEVEhUTFRIVExcQFzUXERYRFRMVEhUTFRIVExcRFBMVExUSFRMWERUTFxAXERU3FjUVAA0FAAAAAAAA",
        "21":"JgCSAAABJpQXEBUTFzUWNRUTFRMUExcRFTYVExc0FRMXERUSFRMVEhUTFRIVExcQFxEVNxUSFRMWERUTFRIXERU3FRIXNRUSFRMVNxUSFQACkBcQFhIXERQTFRMVEhUTFRIXERUSFxEVExQTFTcWERcRFRIXERUSFxEVExQTFRMVEhcRFRIVExUSFzUXERU2FTcVAA0FAAAAAAAA",
        "22":"JgCSAAABKJIWERcRFTYXNRcRFhEVExYRFxEXNBc1FRMXEBcRFRIVExcRFBMVExUSFRMWNRUTFRMWERcRFRIXERY1FRQXNBUTFxEVNhUTFQACjxUTFxEVEhUTFRIXERUSFRMVEhcRFhIWERUTFTYVExUSFxEVExUSFxEWERcRFxAXERcQFRMVExUSFRMVNhc1FzUVAA0FAAAAAAAA",
        "23":"JgCSAAABKZIVExUSFzUWNRUTFxEVEhUTFTYVNxU3FRIVExUSFRMVEhUTFRMWERUTFRIVNxUSFRMVExUSFRMVEhU3FRIVNxUTFRIVNxUSFQACkBUTFhEVExcQFhIVExQTFRMVEhUTFhEVExcQFTcXERUSFRMVEhUTFxAVExUSFxEVExYRFxEWERUTFjUVNxU3FTYVAA0FAAAAAAAA",
        "24":"JgCSAAABKJIVEhUTFzUVNhUTFRIXERUTFhEXERYRFTcXEBcRFRIXERcRFhEVExYRFRMWNRUTFxEWERUTFhEVExY1FRMXNRUSFxEWNRcRFQACkBYRFxEWERcRFRIXERcQFxEXERYRFxEWERUTFjUVExcRFhEWEhYRFxEVEhcRFxAVExcQFRMXERYRFRMVEhcRFhEVAA0FAAAAAAAA",
        "25":"JgCSAAABJ5QVEhcRFTcVNhUTFRIXERUTFjUXERUSFTcVEhUTFRMWERUTFRIVExcQFRMXNRUSFRMVEhcRFRIXERU3FRIVNxYRFxEVNhUTFQACkBcQFRMVEhcRFRMWERcRFhEXERUSFxEXEBUTFTcWERUTFhEXERUSFRMVEhUTFxEVEhUTFhEVExUSFzUXERQTFRMWAA0FAAAAAAAA",
        "26":"JgCSAAABJ5MXERcQFTcXNRYRFxEXEBcRFxAVNxUTFjUXERUSFRMXEBUTFxEVEhUTFRIXNRcRFhEXERYRFxEWERc1FxEWNRcRFRIXNRcQFwACjhUTFxAVExcQFxEXERYRFxEVEhUTFhEXERUSFzUXERYRFxEVEhcRFRIXERUSFxEXERYRFRMWERcRFRIXNRcQFxEXAA0FAAAAAAAA",
        "27":"JgCSAAABJpQVExYRFzUVNhcRFRMVEhcRFjUVNxcRFjUXERUSFhIXERYRFRMVEhcRFhEXNRcQFxEVExYRFRMVEhU3FRIXNRUTFhEXNRcQFwACjhcRFhEXERYRFRMXEBcRFxAXERUTFRIXERUSFzUVExYRFRMVEhcRFRIVExcQFRMVEhcRFxEWERcRFjUVNxcRFhEVAA0FAAAAAAAA",
        "28":"JgCSAAABKJIWERUTFjUXNRcRFhEXERcQFxEXEBc1FzUVEhUTFRIXERcQFxEXERYRFxEWNRcRFxAXERcQFxEVExY1FxEWNRcRFxAXNRcRFgACjhcRFxAXERcRFhEXERYRFxEXEBcRFxAVExcRFTYXERYRFxEXEBUTFRIXERcRFRIXERYRFxEXEBcRFxAXERc1FhEXAA0FAAAAAAAA",
        "29":"JgCSAAABKJIVEhcRFzUWNRcRFxAVExUTFjUVExU2FTcVExYRFxEWERUTFRIVExUSFxEXNRUSFxEVEhUTFxAXERU3FhEXNRcQFxEXNRYRFwACjhcQFRMVEhcRFxEVEhcRFhEVExYRFRMVEhcRFzUVEhUTFRIVExUSFxEXERYRFxEWERcRFhEXERYRFzUXERY1FRMVAA0FAAAAAAAA",
        "30":"JgCSAAABJpQWERUTFzQVNxUTFRIVExUSFRMXNRQ3FTcVEhUTFxEVEhcRFRIXERUSFRMVNxUSFRMVEhUTFhEXERU2FhIVNxUSFxEVNxYRFQACkBUSFRMXEBcRFRIVExUTFRIVExUSFRMVEhUTFTcVEhUTFhEVExYRFRMVEhUTFxAVExcRFRIVExUSFRMVNhU3FRMVAA0FAAAAAAAA"
    "cool":{
      "low":{
        "16":"JgCSAAABJ5MVNxUTFBMVNxU2FRQUExQTFRMVEhUTFRIVExUSFRMVEhUTFRMVEhUTFRIVNxUTFBMVExUSFRMVEhU3FRIVNxUTFRIVNxUSFQACkBUTFRIVExUSFRMVExUSFRMVEhUTFRIVExUSFTcVExUSFRMVEhUTFRIVExUTFBMVExUSFRMVEhUTFTYVExU3FRIVAA0FAAAAAAAA",
        "17":"JgCSAAABJpQVNxUSFRMVNhU3FRMVEhUTFTYVExUTFRIVExUSFRMVEhUTFRMUExUTFRIVNxUSFRMVEhUTFRMUExU3FRIVNxUTFRIVNxUSFQACkBUTFRIVExUSFRMVEhUTFRMUExUTFRIVExUSFTcVEhUTFRMUExUTFRIVExUSFRMVEhUTFRMUExUTFRIVNxU2FRMVAA0FAAAAAAAA",
        "18":"JgCSAAABKJMVNxUSFRMVNxU2FRMVEhUTFRIVNxUTFRIVExUSFRMVEhUTFRIVExUTFRIVNxUSFRMVEhUTFRIVExU3FRIVNxUSFRMVNxUSFQACkBUSFRMVExQTFRMVEhUTFRIVExUSFRMVEhUTFTcVEhUTFRIVExUSFRMVExQTFRMVEhUTFRIVFBUSFTcVNhU3FRMVAA0FAAAAAAAA",
        "19":"JgCSAAABJ5MVNxUTFRIVNxU3FRIVExUSFTcVNxUSFRMVEhUTFRIVExUTFBMVExUSFRMVNhUTFRMUExUTFRIVExU2FRMVNhUTFRMVNhUTFQACkBUSFRMVEhUTFRIVExUSFRMVExUSFRMVEhUTFTYVExUSFRMVExUSFRMVEhUTFRIVExUSFRMVExQTFRMVEhUTFTYVAA0FAAAAAAAA",
        "20":"JgCSAAABKJMVNxUSFRMVNxU2FRMVExQTFRMVEhU3FRIVExUSFRMVExQTFRMVEhUTFRIVNxUTFBMVExUSFRMVEhU3FRIVNxUTFRIVNxUSFQACkBUTFRMVExUSFRMVEhUTFRMUExUTFRIVExUSFTcVExQTFRMVEhUTFRIVExUSFRMVEhUTFRMVEhUTFTYVExUSFTcVAA0FAAAAAAAA",
        "21":"JgCSAAABJ5QVNhUTFRMVNhU3FRIVExUTFDcVExU2FRMVExQTFRMVEhUTFRIVExUSFRMVNhUTFRMVEhUTFRIVExU2FRMVNxUSFRMVNhUTFQACkBUSFRMVEhUTFRIVExUTFBMVExUSFRMVEhUTFjUVExUTFRIVExUSFxEWERcRFxAVExcQFRMVExYRFxEWNRcRFzQXAA0FAAAAAAAA",
        "22":"JgCSAAABKJMVNxUTFBMVNxU2FRMVExQTFRMVNhU3FRMUExUTFRIVExUSFRMVEhUTFRIVNxUTFRIVExUSFRMVEhc1FxEVNhcRFxEWNRcRFgACjhcRFxEWERcRFhEXERcQFxEXEBcRFxEWERcRFjUXERcQFxEXERYRFxEWERcRFxAXERcQFxEXERYRFzUXNBcRFzUWAA0FAAAAAAAA",
        "23":"JgCSAAABJ5MVNxUTFBMVNxU2FRMVEhUTFTcVNhU3FRMVEhUTFRIVExUSFRMVExQTFRMVNhUTFRIVExUSFRMVExQ3FRMVNhUTFRMVNhUTFQACjxUTFRMVEhUTFRIVExUSFRMVEhUTFRMUExUTFTYVExUSFRMVEhUTFRMVEhUTFRIVExUSFRMVExQTFRMVEhU3FTYVAA0FAAAAAAAA",
        "24":"JgCSAAABJ5MVNxUTFBMVNxU2FRMVExQTFRMVEhUTFTYVExUSFRMVExQTFRMVEhUTFRIVNxUTFRIVExUSFRMVEhU3FRMUNxUTFRIVNxUTFAACkBUTFRIVExUTFBMVExUSFRMVEhUTFRIVExUSFTcVExUSFRMVEhUTFRIVExUTFBMVExUSFRMVEhUTFTcUExU3FTYVAA0FAAAAAAAA",
        "25":"JgCSAAABKZEXNRcRFxAYNBc0FxEXERcQFzUXEBcRFzUWERcRFxAXERcQFxEXEBcRFxAXNRcRFxAXERcQFxEXEBc1FxEXNBcRFxAVNxcRFwACjRcSFxAXERcQFxEXERcQFxEXEBcRFRIXERcQFzUXERcQFxEXEBcRFxAXERcQFxEXERYRFxEXEBcRFxAXNRc1FzQXAA0FAAAAAAAA",
        "26":"JgCSAAABKZEXNRcRGA8XNRc1FxAYEBcQFxEYMxcRGDQXEBgQGA8XERcQGBAXERcQFxEXNBcRFxAYEBcQGBAYEBc0FxEYMxcRFxEXNBcRGAACjBcRGBAXEBcRFxAXERcQFxEXEBcRFxEXEBcRFzQXERcQGBAXERcQFxEXEBcRFxAYEBgPGBAXERYRFzUXNBc1GDQYAA0FAAAAAAAA",
        "27":"JgCSAAABJ5MVNxUTFRIVNxU3FRIVExUSFTcVNxUSFTcVEhUTFRIVExUSFxEVExUSFRMVNhUTFxAXERcQFxEXERY1FxEWNRcRFxEWNRcRFwACjhYRFxEXEBcRFxAXERgPGBAXERcQFxEXEBcRFzQXERcRFhEXERcQGBAXEBgQFxAYEBgQFxAXERcQFxEYDxgQGA8YAA0FAAAAAAAA",
        "28":"JgCSAAABKJIXNBcRFxAXNRc1FxAXERgPFxEYDxc1FzUYDxgQGA8YEBgQFxAXERcQGBAYMxgQGA8YEBcRFxAYEBgzGBAYNBcQFxEXNBgQFwACjhgPFxEYDxcRGA8YEBcRFxAYEBcQGBAYDxcRFzUXEBcRFxAXERcQGBAXEBcRFxAYEBgQFxAXERcQGDQYDxgQGA8XAA0FAAAAAAAA",
        "29":"JgCSAAABKJIVNxUSFxEWNRc1FRMWERcRFjUXERc1FjUXERcQFxEXEBcRFxEWERcRFxAXNRcRFhEXERcQFxEXEBc2GA8XNRcRFxAXNRcQGAACjRgQFxAXERgPGBAXEBcRFxEXEBcRGA8YEBgPGDQYEBcQGBAXEBgQGA8YEBcQGBAYEBYRGBAWERcRFxAYNBcQGBAXAA0FAAAAAAAA",
        "30":"JgCSAAABKZIXNBcRFxAXNRc1FxAXERcQFxEXNRY1FzUXEBcRGBAXEBcRFxAXERcQFxEYNBcQFxEXEBcRGA8XERgzFxEXNRcQFxEXNBcRFwACjhcQFxEXEBcRFxEWERcRFhEXERcQFxEXERYRFzUVEhcRFhEXERcQFxEXERUSFxEWERcRFhEVExUSFzUXNRUSFxEVAA0FAAAAAAAA"
      "mid":{
        "16":"JgCSAAABJ5MWNRYSFxEWNRYSFzQVExYSFBMVExYRFRMXEBUTFxAXERUSFxEVExYRFxEVNhcRFhEVExcQFxEXERU2FxEVNhUTFxEVNhYSFQACjxUTFxEVEhcRFRIXERUSFRMVEhYSFxEVEhUTFTYVFBUSFRMXEBYSFRIXERcRFRIXERUSFRMXEBYSFTYWEhU3FRIVAA0FAAAAAAAA",
        "17":"JgCSAAABKJMWNhYRFxEVNxUSFjYWERUTFTcVEhUTFRIWEhUSFhIVEhYSFRMVEhUTFRIWNhYRFRMXERUSFRMVEhU3FhEWNhYSFRIVNxYRFgACjxUTFRIWEhcQFRMVEhUTFRIVExcRFRIVExUSFTcWERcRFRMVEhUTFRIVExYRFhIVEhYSFhEWEhUTFRIWNhU2FhIVAA0FAAAAAAAA",
        "18":"JgCSAAABJpQWNhYRFhIVNhYSFTcWERYSFhEVNxYSFRIWEhUSFRMVEhcRFRMVEhYSFRIVNxYRFhIVExUSFRMVEhU3FhEVNxYSFRIWNhYRFgACjxYSFRMWEhUSFRMXEBcRFhEVExUTFRIWEhUSFTcVEhcRFRIWEhUTFRIWEhUSFRMVEhcRFRMVEhYSFTYWNhY2FRIWAA0FAAAAAAAA",
        "19":"JgCSAAABKpAXNRcRFxAYNBcQFzUXERcQFzUYMxgQFxEXEBgQFxAXERcQFxIXDxgQFxEXNBgQFxAXERcQGBAXEBc1GBAXNBcRFxAXNRcRFwACjRgQFxAXERgQFxAYEBcQGBAXEBcRFxAYEBgQFzQYEBcQGBAXEBgQFxAYEBgQFxAYEBcQFxEYDxgQGA8YEBcQGDQYAA0FAAAAAAAA",
        "20":"JgCSAAABJpQVNhcRFRIVNxUTFTYWEhUSFRMVEhc1FhIXEBcRFhEXERUSFxEVExYRFRMVNhUTFxAVExUSFhIXERc0FRMXNBcRFRMVNhYSFQACjxYSFxEVEhUTFxAWEhcQFxEWEhYRFRMVEhcRFTYWEhUTFRIVExUSFhIVEhUTFRIVExUSFxEWEhQTFTcVEhYSFzQVAA0FAAAAAAAA",
        "21":"JgCSAAABJ5MXNRcRFxAXNRYRFzUXERUSFTcXEBc1FRMWERcRFxAVExUSFRMXEBUTFxEUNxUTFxAVExUSFhIVExU2FRMXNBYSFxEWNRYSFQACjxYSFhIVEhcRFRIVExUSFRMWERUTFhIVEhcRFTYWEhUSFxEVEhcRFhIVEhUTFRIVExcQFhIXEBUTFRMVNhUTFzQWAA0FAAAAAAAA",
        "22":"JgCSAAABKJIVNxYRFRMVNhUTFTcWERUTFRIVNxc1FhEVExUSFRMVEhUTFRIVExcRFBMVNxUSFRMXEBUTFxEUExc1FRIVNxUSFRMVNxYRFQACkBcRFRIXERUSFRMVEhcRFRIVExUSFRMVExYRFTgWERcRFRIXERUSFRMVEhcRFxEWERcRFhEVExUSFTcVNxYRFTcVAA0FAAAAAAAA",
        "23":"JgCSAAABJpQWNhYRFxEXNBUTFTcVEhUTFTYWNhU3FhEVExcQFxEVExcQFRMXEBYSFRIVNxYSFxAXERYRFRMVEhY2FRMVNhUTFxAXNRYSFQACjxcRFRIXERUTFhEXERUSFRMXEBUTFxAXERcRFTYXERcQFxEXERUSFRMXEBUTFRIVExYRFRMXERYRFRMVEhc1FTYWAA0FAAAAAAAA",
        "24":"JgCSAAABJ5MWNhUSFRMWNRUTFTcWERUTFRIVExYRFzUWEhUSFRMVEhUTFxAWEhUTFRIVNxUSFhIVEhUTFxEVEhU3FRIVNxYRFRMXNRYRFgACjxYSFRIWEhUSFRMXEBUTFRIWEhcRFRIVExcQFzUVEhUTFhIVEhUTFRIWEhUSFhIVEhUTFRMWERUTFTYWEhU3FTYWAA0FAAAAAAAA",
        "25":"JgCSAAABJ5QWNhcQFxEXNBcRFzUXEBcRFzQXERcRFzQXERcQFxEXEBcRFRMWERcRFxAVNxUSFxEXERYRFxEXEBc1FRIXNRcRFxAXNRYRFwACjhYSFxAWEhcQFRMXEBUTFRMVEhUTFRIXERcQFTcXERQTFRMXEBUTFxAWEhUSFRMXEBYSFRMWEhcRFhEVNxU2FjYWAA0FAAAAAAAA",
        "26":"JgCSAAABKJIXNBcRFxAXNRcRFzQXERcQFxEXNRcQFzUXEBcRFxAXERcQFxEXERcQFRMXNBcRFxEWERcRFxAXERc0FxEXNBcRFxEVNhUTFwACjhcQFxEXEBcRFxAXERcQFxEXERYRFxEXEBcRFzQXERcRFhEXERcQFxEXEBcRFxAXERcRFhEVExcQFTcXNBc1FzUVAA0FAAAAAAAA",
        "27":"JgCSAAABJpQVNhcRFRIXNRUTFTYXERcQFzUVNxUSFzUXEBUTFhIXEBcRFRIVExcQFRMXNRUSFxEXEBUTFRIWEhY2FRIXNRYRFxEVNxUSFQACkBYRFRMXERUSFxEVEhUTFxAVExUSFhIVEhcRFTcVEhYSFhEWEhUSFRMVExUSFRMVEhYSFRIWEhUSFRMVEhcRFRMVAA0FAAAAAAAA",
        "28":"JgCSAAABKJIXNBcRFxEXNBcRFzQXERcRFhEXERc0FzUXEBcRFxEXEBcRFxAXERcQFxEXNRcQFxEXEBcRFxAXERc1FRIXNRcQFxEXNRYRFwACjhYRFRMVEhcRFxEVEhYSFRIVExcQFxEXEBcRFTcVEhcRFxAXERUSFhIXERYRFRMXEBcRFRIWEhcQFzUWEhcQFRMXAA0FAAAAAAAA",
        "29":"JgCSAAABKJMWNhUSFRMWNhYRFTcXEBcRFTcVEhU3FjYVEhcRFxAXERcQFRMWERUTFRMVNhUTFhEXERcQFRMVEhc1FRMVNhYSFRIXNRUTFQACjxYSFRMWERUTFxAVExYRFRMXEBcRFRIVExUTFTYWEhcQFxEWERYSFxEWERcRFhEXERcQFxEXEBcRFxAWNhYSFRIXAA0FAAAAAAAA",
        "30":"JgCSAAABKZIWNhUSFhIVNhYSFjYVEhUTFxAXNRc1FTYWEhUSFxEVEhUTFxEXEBUTFhEVNxYSFRIWEhUSFRMVEhc1FRIWNhYSFhEVNxUSFgACjxYSFxAVExYRFhIWEhUSFRMWERUTFRIWEhUSFjYWEhUSFRMVEhYSFRIXERYRFRMWEhUSFxEVEhcRFTYVNxYSFRIWAA0FAAAAAAAA"
      "high":{
        "16":"JgCSAAABJ5QWNhUSFxEXNBc1FjYXEBUTFRIVExYSFRIXERUSFxEWERUTFxAXERcQFRMXNRUSFxEXEBcRFxAXERc1FRIVNxUSFhIWNhUSFQACkBYRFxEVEhcRFRMWERcRFRIVExUSFxEVEhcSFDcVEhUTFhEWEhcQFRMVExQTFxEVEhUTFxAXERUSFzUWEhU2FhIVAA0FAAAAAAAA",
        "17":"JgCSAAABKJIXNBcRFxEWNRU3FzUWERcRFzQXERcQFxEXEBcRFxEXEBcRFxAXERcQFxEVNxUSFxEXEBcRFxAVExc1FRIXNRcQFxEXNRUSFwACjhYRFRMXERYRFxEXEBcRFxAXERUSFxEXEBUTFzUVEhcRFxAVExcQFxEXERUSFxEXEBcRFxAXERcQFxEXNRY1FhIXAA0FAAAAAAAA",
        "18":"JgCSAAABKJIVNhYSFxAXNRY2FjUWEhUSFRMXNRUSFxEWERcRFRIWEhcQFhIXERYRFxEXNBcRFxAXERYSFRIWEhc0FRMXNRUSFRMWNRcRFwACjRUTFRMVEhUTFxAWEhcQFxEWERcRFxEWERcRFzQXERYRFxEXERYRFhIXEBUTFxAXERcQFxEVExUSFzUWNRU3FhIVAA0FAAAAAAAA",
        "19":"JgCSAAABJpQVNhYSFxAXNRY2FTYWEhcRFTYWNhUSFhIXERUSFRMXEBUTFhEVExUSFRMXNRUSFxEVEhcRFRIXERY2FRIWNhYRFhIXNRUSFgACjxYSFRIVExUSFRMXEBcRFRIWEhcRFBMWEhYRFzUWERYSFRMWERUTFxAVExYRFxEWERUTFxAVExYSFRIVExUSFTcVAA0FAAAAAAAA",
        "20":"JgCSAAABKJMWNhYRFhIWNhU2FjYVExUSFhIVEhU3FRIWEhYRFhIXERcQFhIWERUTFRIWNhYSFRIWEhYRFhIWERU3FhIWNRYSFhEVNxYSFQACjxYSFRMUExUTFRIWEhUSFRMVEhYSFhEVExYSFTYWEhYRFRMXEBUTFxEVEhYSFRIVExYRFhIVExUSFjYWERcRFjUWAA0FAAAAAAAA",
        "21":"JgCSAAABKJIWNhYSFRIXNRU2FjYXERcQFzUVEhU3FRMXEBcRFxAXERYRFxEVEhcRFxEVNhYSFRIXERUSFhIVExY1FRMXNBYSFxEVNhYSFQACjxYSFhIVEhUTFxAVExUSFhIWEhYRFxEXEBcRFzQWEhcQFxEWEhUSFRMXEBcRFhEXERcQFxEWEhUSFRMXNBYSFzQWAA0FAAAAAAAA",
        "22":"JgCSAAABJpQWNhYRFRMWNRY2FjYWERcRFRMWNRY2FhEVExYSFhEVExUSFRMVEhcRFRIWNhYSFhEWEhcQFRMWERY2FhIWNRYSFRIWNhYSFQACjxYSFRIXERcRFBMWEhUSFxEVEhcRFxAWEhUSFTcWEhcQFxEWERYSFxAWEhcRFhEVExcQFxEXEBcRFzQWNhYSFTYXAA0FAAAAAAAA",
        "23":"JgCSAAABJ5QVNhYSFxAWNhY2FTcVEhUTFzQWNhY2FRIWEhYRFhIVEhYSFRIWEhUTFRIWNhYRFRMWEhQTFxEWERY2FRIVNxYSFRIXNRUSFgACjxUTFxAWEhUSFRMVEhYSFRMVEhUTFRIWEhcQFTcVExUSFxEVEhUTFxAVExcQFRMVExUSFhIVEhYSFhEWEhc0FjYWAA0FAAAAAAAA",
        "24":"JgCSAAABKZEXNRYSFhEXNRc0FTcWEhcQFxEXEBcRFzQWEhcRFxAXERYRFxEXEBcRFxEWNRcRFxAXERcQFxEXEBc1FRMVNhUTFxAXNRYSFgACjhcRFxAXERcRFRIXERcQFxEXEBcRFxAXERcQFzUXERcQFxEXEBcRFxAXERcRFRIXERcQFxEXEBcRFzQWEhc1FzQWAA0FAAAAAAAA",
        "25":"JgCSAAABKZIWNhUSFhIXNBU3FzUXEBYSFTYWEhYSFzQVExUSFhIVEhUTFRMWERUTFhEXNRUSFxEXEBcRFxEXEBc1FRIVNxUTFhEWNhYRFQACkBYSFRIXERcQFhIXEBUTFRMVEhcRFxAXERUSFjYWEhUSFxEXEBcRFxAXERcQFxEVExYRFxEVEhcRFhEXNRU3FTYXAA0FAAAAAAAA",
        "26":"JgCSAAABJpQWNRUTFxAWNhY2FTYWEhUTFhEXNRYRFzUWEhYRFxEVEhUUFhEWEhUSFRMVNhcRFRMVEhcRFxAWEhc0FhIXNRYRFxEVNhYSFQACkBYSFhEXERUSFRMVEhcRFRIXERcQFRMVEhYSFTcWERUTFxAXERYRFxEXERcQFRMWERYSFxAXERcRFDcWNhU2FjYWAA0FAAAAAAAA",
        "27":"JgCSAAABJ5MWNhYSFRIWNhY2FTYWEhYRFTcWNhYRFjYVExYRFRMVEhYSFRIVExUSFhIVNhYSFhIXEBUTFxAXERY2FRIWNhYRFhIXNRUSFgACjxYRFxEVExUSFxEVEhUTFhEVExYRFhIVExQTFzUVEhcRFhEVExcQFRMXERUSFhIVEhYSFxAWEhUSFxEVExUSFRMVAA0FAAAAAAAA",
        "28":"JgCSAAABKZEXNRcRFxAWNhY2FTYXERUSFhIVEhc1FjYWERcRFhEVExUTFRIXERcQFRMXNBYSFhIVEhcRFRIWEhc0FxEXNRUSFRMVNhUTFQACkBUSFhIVEhUTFxEVEhYSFhEXERcQFxEWERYSFzUVEhcRFxAVExUSFRMXEBcRFRMVEhcRFxAXERUSFTcWEhUSFRMXAA0FAAAAAAAA",
        "29":"JgCSAAABJ5MWNhUSFRMXNRU2FTcWERcRFTcVEhc1FjYVEhYSFhEXERcQFxEVEhcRFRMWNRYSFxAXERYRFxEXERU2FhIXNBYSFhIXNBYSFgACjxUSFxEXEBcRFxAXERYRFxEVExcQFxEXEBcRFTYWEhcRFxAXERcQFxEXEBcRFxAXERcRFhEXERcQFxEXNBUTFxAXAA0FAAAAAAAA",
        "30":"JgCSAAABJ5QVNhYSFxAXNRY2FjYVEhcRFRIVNxU2FjYWEhcQFhIXEBcRFxAVExcRFRIWNhYRFhIXEBUTFxEUExc1FRIVNxUSFxEWNhUSFQACkBYSFRIWEhUSFxEXEBcRFRMVEhUTFRIVExUSFTcVEhcRFhIVEhUTFRIXERUSFRMXEBcRFxAXERUTFjUWNhYRFhIXAA0FAAAAAAAA"
      "auto":{
        "16":"JgCSAAABKpEWNhcRFRIXNRcQFxEXEBcRFxEWERcRFxAXERcQFxEXEBcRFxAXERcRFhEXNRcQFxEXEBcRFxEXEBc1FRIVNxcRFxAXNRcQFwACjhcRFxAXERcQFxEXEBcRFxEWERcRFxAXERcQFzUXERcQFxEXEBcRFxAXERcQFxEXERcQFxEXEBcRFzQXERc1FhEXAA0FAAAAAAAA",
        "17":"JgCSAAABJ5QWNRYSFxEVNhYSFxAVExYRFjYWEhcQFhIVEhYSFxAWEhYSFhEXERUSFxEVNhYSFhIVEhYSFxAXERc0FxEXNRUSFxEXNBUTFQACkBUSFRMXEBUTFRIWEhcRFRIXERYRFhIWERUTFjUWExYSFBMWEhYRFRMVEhUTFRIXERYRFhIVExYRFxEWNRY2FhEWAA0FAAAAAAAA",
        "18":"JgCSAAABJpQWNhUSFxEXNBYSFxAXERcRFhEXNRYRFRMWERcRFRIXERcRFxAVExUSFRMVNhYSFhIWERcRFRIWEhU2FRMWNhYRFhIVNhYSFgACjxYRFRMXEBcRFxEWERcRFxAXERcQFhIXEBUTFzUVEhcRFRIXERUSFxEWERcRFxEWERcRFxAXERcQFzUWNhU2FhIXAA0FAAAAAAAA",
        "19":"JgCSAAABJ5QVNhYSFxAVNxUTFhEVExcQFjYWNhUSFhIVEhUTFxAWEhcQFhIVExUSFRMVNhYSFRMWERUTFRIXERU2FhIVNxUSFhIWNRYSFgACjxYRFRMVEhUTFhEXERUTFRIWEhcQFhIVEhUTFTcVEhUTFRIVExUSFRMVEhYSFRMVEhUTFRIVExYRFRMVEhYSFzUVAA0FAAAAAAAA",
        "20":"JgCSAAABJ5MVNxUTFRIWNhYRFxEXEBcRFhIXEBc1FxAXERcRFhEXERcQFxEXEBcRFxAVNxcRFhEVExcQFxEXEBU3FhIWNRYSFxAXNRUTFQACjxYSFxEWERcRFRIXERcQFxEVEhcRFxEVEhUTFzQWEhcQFRMVExYRFRMVEhcRFhEXERUSFRMXEBYSFTcVEhcRFzQWAA0FAAAAAAAA",
        "21":"JgCSAAABJ5QVNhYSFRMVNhYSFRIWEhYRFTcWEhU2FRMVEhUTFRIWEhYSFRIWEhUSFRMXNBYSFRMWERUTFRIVExY1FhIVNxUSFxEWNRYSFgACjxUSFxEXEBYSFxAXERUTFhEXERUSFhIVEhYSFjUWEhUTFhEVFBYQFxEVEhUTFhEVExcRFRIVExUSFRMVNhcRFTcVAA0FAAAAAAAA",
        "22":"JgCSAAABKZIWNhUSFxEVNhcRFxAWEhcRFhEXNRU2FxEXERYRFRMXEBUTFxAXERUSFhIXNRYRFxEXEBcRFRIWEhc1FxAXNRUSFxEXNRUSFQACkBcQFxEVExYRFxEXEBcRFxAXERcQFRMVExUSFTcWERcRFxAXERUSFRMXERYRFxEXEBcRFxAXERUSFzUVNxcQFzUXAA0FAAAAAAAA",
        "23":"JgCSAAABJpQWNhUSFxEVNhUTFxEWERcRFTYWNhU3FRIVExUSFxEWERcRFRMUExYSFxAVNxYRFxEXEBcRFhIVEhY2FRIXNRcRFxAVNxcQFwACjhcRFxAXERcQFxEXEBcRFxEXEBcRFxAXERcQFzUXERQTFxEXEBcRFxAXERcQFxEXEBcRFxEXEBcRFxAXERc0FzUWAA0FAAAAAAAA",
        "24":"JgCSAAABKJIWNRYSFxEWNRYSFxAVExcQFxEXEBUTFzUVEhcRFxAVExcQFxEXERcQFRMWNRYSFhEXERcRFhEXERU2FhIXNBUTFxEXNBcRFwACjhUSFxEXEBcRFxAXERcQFxEXERYRFxEXEBcRFzQXERcQFxEXERcQFRMXEBcRFxAXERcQFxEXEBcRFzUXEBc1FzUXAA0FAAAAAAAA",
        "25":"JgCSAAABKJIXNRcQFxEXNBcRFxAXERcRFzQXERcQFzUXERcQFxEXEBcRFxAXERcRFhEXNRcQFxEXEBcRFxAXERc1FxAXNRcQFxEXNRcQFwACjhcQGBAXERcQFxEXEBcRFxAXERcQFxEXERYRFzUXEBcRFxAXERcQFxEXERcQFxEXEBcRFxAXERcRFhEXNRc0FzUXAA0FAAAAAAAA",
        "26":"JgCSAAABKZIXNRcQFxEXNBcRFxAXERcRFxAXNRcQFzUXERcQFxEXEBcRFxAXERcQFxEXNRcQFxEXEBcRFxAXERg0FxAXNRcQFxEXNRcQFwACjhcRFxAXERcQFxEXEBcRFxAXERgQFhEXEhYQFzUYDxgQFxEXEBgQFxAXERgPFxEXEBcRFxAXERcRFzQXNRg0FzQXAA0FAAAAAAAA",
        "27":"JgCSAAABKZIXNBcRGA8XNRcRFxAXERcQFzUXNRcQFzUXEBgQFxEWERcRFxAXERcQFxEXNBcRFxEXEBcRFxAXERc0FxEYNBcQFxEXNBgQFwACjhcQFxEXEBgQFxAXERcRFxAXERcQFxEXEBcRFzQYEBcRFxAXERcQFxEXEBcRFxEWERcRFxAXERcQFxEXEBcRFxAXAA0FAAAAAAAA",
        "28":"JgCSAAABKZEXNRcRFxAXNRcQFxEXERYRGBAXEBc1GDMXERcRFxAXERcQFxEYDxcRFxAXNRcRFxAXERcQFxEXEBc1GBAXNBcRFxAXNRgQFwACjRgQFxEXEBgQFxAXERcQFxEXEBcRFxAXERcRFzQXERcQFxEXEBcRFxAYEBcRFxAXERcQFxEXEBcRFzUXEBcRFxAXAA0FAAAAAAAA",
        "29":"JgCSAAABKZEYNBgQFxAXNRgPGBAXERcQFzUYDxc1GDQXEBgQFxAYEBcQFxEYDxgQFxEXNBcRFxAYEBcQFxEXERY1GBAYMxcRFxAYNBgQGAACjBgQFxEXEBgQFxAXERcQFxEYDxcRFxAXERcRFzQYEBcQFxEXEBcRFxAXERcRFxAXERgPFxEXEBcRGBAWNRcRFxAXAA0FAAAAAAAA",
        "30":"JgCSAAABKZIXNRgPGBAYMxgQFxEXEBcRFxAXNRg0FzQXERgPFxEYDxcRFxEXEBcRFxAXNRcQGBAXERYRFxEXEBc1FxEXNBcQGBAXNRcQGAACjRgQFxAYEBgPFxEXEBcRFxAXERcRFxAXERcQFzUXEBcRFxAYEBcRFxAXERcQFxEXEBcRGA8XERcRFzQXNRcQFxEXAA0FAAAAAAAA"
    "fan_only":{
      "low":{
        "16":"JgCSAAABJpMWNhU3FhEVNxY2FRIVExUSFRMVExQTFRMVEhUTFRIVExUSFRMVEhUTFRIVNxYSFRIWEhUSFRMWERY2FRMVNhUTFhEVNxYSFgACjRcSFjYVNhUTFRIVExYRFRMVExQTFRMVEhUTFTYWEhUTFBMVExUSFRMVEhYSFRIVExUSFhIVExQTFTcWNRY2FRMVAA0FAAAAAAAA",
        "17":"JgCSAAABJpQVNhU3FRMVNhU3FRMUExUTFTYVExUSFRMVExUSFRMVEhUTFRIVExUSFRMVNxQTFRMVEhUTFRIVExU2FRMVNxUSFRMVNhUTFQACkBUSFTcVNxUSFRMVEhUTFhEVExUSFRMVExUSFjYVEhUTFhEVExUTFBMVExUSFRMVEhUTFRIVExUSFRMVExQTFTcVAA0FAAAAAAAA",
        "18":"JgCSAAABKZIUNxU3FRIVNxU3FxAVExcQFxEVNxYRFxEVEhUTFhEXERUSFRMVExYRFxEVNhcRFRIVExcQFxEXERQ3FRMVNhcRFRMUNxUTFwACjRcRFzUVNhUTFRMUExcRFRIVExUSFRMVEhUTFzQVExUTFhEVExUSFRMVEhUTFRIVExUTFhEVExUSFzUVEhUTFTcVAA0FAAAAAAAA",
        "19":"JgCSAAABJ5QVNhU3FxEVNhc1FRMUExUTFjUVNxUSFRMVExUSFRMVEhUTFRIVExUSFRMVNxUSFRMXEBUTFRIVExU3FRIVNxcQFRMVNxUSFQACkBUTFDcVNxUSFRMVEhUTFRMUExUTFRIVExUSFTcVExQTFRMVEhUTFRIVExUSFRMVEhUTFRMUExUTFRIVNxUSFTcVAA0FAAAAAAAA",
        "20":"JgCSAAABJpQVNhU3FRMUNxU3FxAVExcQFRMVExU2FRMVEhcRFRIVExUTFhEVExYRFRMVNhUTFRMUExUTFRIVExU2FxEXNRQTFRMVNhUTFQACkBUSFTcVNhUTFxEVEhUTFRIVExcQFRMVEhUTFTcVEhUTFRIXERUSFRMVEhUTFRMVEhYSFhEVExUSFzUVNxUSFTcXAA0FAAAAAAAA",
        "21":"JgCSAAABJpQWNhU2FRMVNxU2FRMVEhUTFTcVEhU3FRIVExUSFRMVExUSFRMVEhUTFRIVNxUTFBMVExUSFRMWERU3FhIUNxUTFRIVNxUTFAACkBUTFTYVNxYSFBMVExUSFRMVEhUTFRIVExUSFTcVExUSFRMVEhUTFRIVExUTFBMVExUSFRMVEhUTFRIVExU3FTYVAA0FAAAAAAAA",
        "22":"JgCSAAABKJMWNhU3FRIVNxU3FBMVExUSFRMVNhU3FRMVEhUTFRIVExUSFRMVExQTFRMVNhUTFRIVExUSFRMVExQ3FRMVNhUTFRMUNxUTFQACjxUTFTcVNhUTFRMUExUTFRIVExUSFRMVEhUTFTcUExUTFRIVExUSFRMVEhUTFRIVExYSFBMVExUSFTcWERU3FTcVAA0FAAAAAAAA",
        "23":"JgCSAAABJ5MVNxU3FRIVNxU3FRIVExUSFTcVNxU2FRMVEhUTFRIVExUTFBMVExUSFRMVNhYSFRMVEhUTFRIVExU2FRMVNxUSFRMVNhUTFQACkBcQFTcVNxUSFRMVEhUTFRIVExUTFBMWEhUSFTcVEhUTFRIVExUTFBMVExUSFRMVEhUTFRIVExYSFBMVNxU2FTcVAA0FAAAAAAAA",
        "24":"JgCSAAABJ5QVNhU3FRMVNhU3FRIVExUTFRIWEhUSFTcVEhUTFRMVEhYSFRIVExUSFRMVNhUTFRMUExUTFRIVExU2FRMVNxUSFRMVNhUTFQACkBUSFTcVNxUSFRMVEhUTFRIVExUTFBMVExUSFTcVEhUTFRMUExUTFRIVExUSFRMVEhUTFRIVExUTFDcVNxU2FTcVAA0FAAAAAAAA",
        "25":"JgCSAAABJ5MVNxU3FRIVNxU3FRIVExUSFTcVEhUTFTcVEhUTFRIVExUSFRMVEhUTFRMUNxUTFRIVExYRFRMVExU2FRMVNhUTFRMUNxUTFQACjxcRFjYVNhYSFRMUExUTFRIVExYRFRMVEhUTFTcVEhUTFRIVExUSFRMWEhQTFRMVEhYSFRIVExUSFRMVExQTFRMVAA0FAAAAAAAA",
        "26":"JgCSAAABJpMWNhU3FRIVNxU3FRIVExUSFRMVNxQTFTcVEhYSFRIVExUTFBMVExUSFRMVNhUTFhIUExUTFRIVExU2FRMVNxUSFRMVNhYSFQACkBUSFTcVNxUSFRMVEhUTFRIVExUSFRMVExQTFTcVEhUTFRIVExUTFBMVExUSFRMVEhUTFhEWEhUSFTcVExUSFRMVAA0FAAAAAAAA",
        "27":"JgCSAAABKJMVNxU3FRIVNxU2FRMVExUSFTcVNhUTFTcVEhUTFRIVExUSFRMWEhUSFhIVNhUTFRIVExUSFRMVExQ3FRMVNhUTFRMUNxUTFQACkBQTFTcVNhUTFRMUExUTFRIVExUSFRMVEhUTFTcVEhUTFRIWEhUSFRMVEhUTFRMUExUTFRIVExUSFRMVNxUSFRMVAA0FAAAAAAAA",
        "28":"JgCSAAABJpMWNhU3FRIVNxU3FRIVExUSFRMVEhY2FTcVEhUTFRIVExUTFBMWEhUSFRMVNhUTFRIWEhUTFRIVExU2FRMVNhYSFRMVNhYSFQACkBUSFTcVNhUTFhIUExUTFRIVExYRFRMWERUTFTcVEhUTFRIVExUSFRMVExQTFRMVEhUTFRIVExUSFTcVNxUSFhIVAA0FAAAAAAAA",
        "29":"JgCSAAABJ5QVNhU3FRMVNhU3FhIVEhUTFjUWEhU3FTYVExUSFRMVEhUTFRMVEhUTFRIVNxUSFRMVExQTFRMVEhU3FRIVNxUTFRIVNxUSFQACkBUTFTYVNxUTFBMWEhUSFhIVEhUTFRIVExUSFTcWEhUSFRMVEhUTFRIWEhUSFRMVExUSFRMVEhUTFRIVExU3FRIVAA0FAAAAAAAA",
        "30":"JgCSAAABJpQVNxU2FhIWNRU3FRMVEhUTFRIVNxU3FTYWEhUSFhIVExUSFRMVEhUTFhEVNxUTFBMVExUSFRMVEhU3FRMVNhUTFRIVNxUSFQACkBUTFTYVNxUTFRIVExUSFRMWERYSFRIVExUTFTYVExUSFRMVEhUTFRIVExYSFBMVExUSFRMVEhUTFTYVExU3FRIVAA0FAAAAAAAA"
Is this helpful? This isn’t the full code, for fan only I have mid and high settings.
Stuck on the same here :frowning: . You got any luck yet?
Yes. I left esphome and changed to Tasmota. It has an integration that works with my Daikin unit.
With esphome I could catch IR codes as usable pronto codes (could catch raw codes but weren’t usable), could turn on/off the unit, but to get codes for every single comand would be a nightmare.
Ohh nice!.
Do you have a link to that?. Maybe i have to switch to :wink:
I’m surprised nobody mentioned this, yet. If you’re using a D1 Mini or other D1 mini clone, change the board type, and the D3/D4/etc pin assignments should be valid. The esp01_1m is pretty much the most minimal board type.
esp8266:
  board: d1_mini
Found a topic online (not here) where they were showing some examples.
Noticed the board type, changed it and just as you posted it my Wemos started to work as it should.
Happy days :slight_smile:
I’ll try that, but that was the way esphome automatically made the setup to my esp board. Yes, I’m using a D1 Mini clone.
esp8266:
board: d1_mini
Doesn’t work. It send signal, receive, but I think the issue is the used protocol with Daikin. It doesn’t suit my machines. Neither Daikin_brc works. Tasmota just work!
Hi, how is the range for the lolin ir led and do they perform the same as normal sized IR led?
I have it inside the aircon device, and it works. But when I was testing it, it worked 5m away without issues and with obstacles between.
Yes, beside the tiny size they perform like the big brothers. They have “only” 4 emitters but each comes with a lens that looks like to be 180° so it shoots 360° like other products.
While it it possible to do it the hard/manual way it might be better just to use the existing component for this task which supports daikin AC’s according to the docs :point_down:
It doesn’t work with my machines.
Did you try all possible combinations (like daikin, daikin_brc as well as the heatpumpir protocols daikin_arc417, daikin_arc480, daikin) like described in the docs? If yes - did you add a feature request for your model so it can be added? :page_with_curl:
If your unit is not listed below you should submit a feature request (see FAQ).
Thanks, sounds good enough
digiblur’s website mentioned that it has short range, and I was a bit doubtful because of the really tiny led
And despite it’s inside the aircon shield, it receives the original remote signal from 3 to 4m away.
daikin can be controlled directly with esp with real time status update and full control through wifi and HA
Need Daikin Wifi? Use the Open-Source Faikin ESP32 Hardware instead of the official wifi Modules - Third party integrations - Home Assistant Community (home-assistant.io)
