No Problem, have you considered adding it to hacs.
Trying now and will report back
Thought about it but limited time, wrote it for my self and found time to document it then life caught up.
I know the feeling.
Looks like it is working now.
By the way How doe the binary sensor for rain work?
Great news, thanks for your help.
I have a rain sensor that connects to a commercial irrigation controller hooked up to my ESP. I got a circuit board printed and build my own controller that runs off 24v ac. I need to build one more iteration of that.
But you can use a template sensor to use any combination of other inputs to determine to water or not. Played with using the weather to act as a sensor.
Peter
Is the program suppose to trigger automatically if the day and time match? I can seem to get the program to trigger
Try resetting the last ran attribute using the developer tools on creation it sets it self to today
Still not starting
I have tried with the ignore rain sensor toggle on and off
Hi Terrence, can you send me your config, for the irrigation component. Cheers Pete
here you go
switch:
- platform: irrigationzone
switches:
pot_plants:
friendly_name: Pot Plants
water: input_number.irrigation_pot_plants_run
wait: input_number.irrigation_pot_plants_wait
repeat: input_number.irrigation_pot_plants_repeat
switch_entity: switch.irrigation_controller_1_zone_1
icon_off: 'mdi:flower'
unique_id: i1
front_lawn:
friendly_name: front Lawn
water: input_number.irrigation_lawn_run
wait: input_number.irrigation_lawn_wait
repeat: input_number.irrigation_lawn_repeat
switch_entity: switch.irrigation_controller_1_zone_2
icon_off: 'mdi:grass'
unique_id: i2
vege_patch:
friendly_name: Vege Patch
water: input_number.irrigation_vege_run
wait: input_number.irrigation_vege_wait
repeat: input_number.irrigation_vege_repeat
icon_off: 'mdi:carrot'
switch_entity: switch.irrigation_controller_1_zone_3
unique_id: i3
- platform: irrigationprogram
switches:
morning:
unique_id: i4
friendly_name: Morning
irrigation_on: input_boolean.irrigation_on
start_time: input_datetime.irrigation_morning_start_time
# run_freq: input_select.irrigation_freq
run_days: input_select.irrigation_run_days
rain_sensor: binary_sensor.ewelink_ds01_e3504322_ias_zone
ignore_rain_sensor: input_boolean.irrigation_ignore_rain_sensor
icon: mdi:fountain
zones:
- zone: switch.pot_plants
- zone: switch.vege_patch
- zone: switch.front_lawn
input_number:
irrigation_pot_plants_run:
min: 1
max: 30
step: 1
icon: mdi:water
unit_of_measurement: min
irrigation_pot_plants_wait:
min: 0
max: 10
step: 1
icon: mdi:timer-sand
irrigation_pot_plants_repeat:
min: 1
max: 10
step: 1
icon: mdi:repeat
unit_of_measurement: iterations
irrigation_lawn_run:
min: 1
max: 30
step: 1
icon: mdi:water
irrigation_lawn_wait:
min: 0
max: 10
step: 1
irrigation_lawn_repeat:
min: 1
max: 10
step: 1
icon: mdi:repeat
irrigation_vege_run:
min: 1
max: 30
step: 1
icon: mdi:water
irrigation_vege_wait:
min: 0
max: 10
step: 1
irrigation_vege_repeat:
min: 1
max: 10
step: 1
icon: mdi:repeat
input_datetime:
irrigation_morning_start_time:
name: Morning Start Time
has_date: false
has_time: true
irrigation_afternoon_start_time:
name: Afternoon Start Time
has_date: false
has_time: true
irrigation_midday_start_time:
name: Midday Start Time
has_date: false
has_time: true
input_select:
# Use either run days of Frequency they are mutually exclusive
irrigation_run_days:
options:
- "['Wed','Sat']"
- "['Sun','Thu']"
- "['Mon','Fri']"
- "['Tue','Sat']"
- "['Sun','Wed']"
- "['Mon','Thu']"
- "['Tue','Fri']"
- "['Mon','Wed','Fri']"
- "['Tue','Thu','Sat']"
irrigation_freq:
options:
- "1"
- "2"
- "3"
- "4"
- "5"
- "6"
- "7"
input_boolean:
irrigation_on:
name: Enable Irrigation
irrigation_config:
name: Show Configuration
irrigation_ignore_rain_sensor:
name: Ignore Rain Sensor
comment out run_days, rain_sensor and ignore_rain_sensor. It should then start at the start_time specified.
Still no joy.
FYI, the ewe link is a binary in my setup, and I had been testing with it in the open state, and the ignore rain sensor on. It I understand the logic, this should mean the program will run?
with ignore rain sensor ‘on’, the rain sensor will not impact the running even if the rain sensor is ‘on’. I will add some logging into the program over the next couple of days and let you know when I have a new version.
Does the program start manually if you turn the ‘program’ switch on?
Thanks, yes the program runs, but not by the time. I guess I could use an automation, but that seems counter intuitive
absolutely, let me add the logging so I can see what the template is internally and how it evaluates.
I’ve loaded a new irrigationprogram switch.py. if you copy it and restart HA you will get the template that is built internally. You can evaluate it in the developer tools template tab if you copy the ‘{{ text… }}’ that is in the logs
Sorry Terence I forgot to commit the change
one more small variation between your config and mine is I don’t have any unique_id values set in my yaml.
Hi Terrence, I have updated the irrigation program switch.py to perform additional validation. It will also output an error to the log with the template that is used to evaluate when to run the program. You can check this in the developer tools to see if anything is stopping it from evaluating to true with your configuration
Peter
still not running, I seem to get the template randomly in the logs
{{ states('sensor.time') + ':00' == states('input_datetime.irrigation_morning_start_time') and is_state('input_boolean.irrigation_on', 'on') and now().strftime('%a') in states('input_select.irrigation_run_days') }}
That’s good, this is the template evaluated to start the program.
Can you:
