Irrigation Unlimited Integration
Is it possible to disable the irrigation only for the next run?
use disable service targeted to the controller you want to disable. See documentation chapter 7
But is the controller enabled again after the next schedule? I just want to skip the next irrigation.
You have to setup an automation, not very hard to achieve if your are acquainted to it
Ok. i thought/hoped there would be an implemented way to do so.
Thank you!
I would like to split configuration.yaml.
Added this in configuration.yaml
irrigation: !include irrigation.yaml
I am getting in “Check Configuration” in developer tools:
Integration error: irrigation - Integration ‘irrigation’ not found.
I obviously created file /config/irrigation.yaml
i created automation for Rain sensor but is not working correctly - could somebody please help?
I am getting data from aquare sensor connected to Hunter Rain sensor - wet or dry status. When the status is wet i want to disable to 0% the irrigation. But is not working…
I have also in operation the Smart irrigation system but i think both can run independently…
Traces:
Executed: May 23, 2023 at 20:38:04
Result:
params:
domain: irrigation_unlimited
service: adjust_time
service_data:
entity_id: binary_sensor.irrigation_unlimited_c1_z2
percentage: 100
target: {}
running_script: false
limit: 10
- id: '1684865711980'
  alias: Rain_senzor
  description: off for whole Controller
  - platform: state
    entity_id:
    - binary_sensor.lumi_lumi_sensor_wleak_aq1_iaszone
  condition: []
  - service: irrigation_unlimited.adjust_time
      percentage: "{% if states('binary_sensor.lumi_lumi_sensor_wleak_aq1_iaszone')
        == 'wet' %}\n    {{ 0 }}\n  {% else %}\n    {{ 100 }}\n  {% endif %}\n"
      entity_id: binary_sensor.irrigation_unlimited_c1_z1
      entity_id: binary_sensor.irrigation_unlimited_c1_z3
      entity_id: binary_sensor.irrigation_unlimited_c1_z4
  mode: single
Correct code is:
irrigation_unlimited: !include irrigation.yaml
As a general rule, when something does work not I use Developers/Template renderer to troubleshoot.
Since there is one rain sensor, instead of acting separately on each zone you could disable/enable the controller itself.
  alias: Rain_senzor
  - platform: state
    entity_id:
  condition: []
  - service: irrigation_unlimited.{{ iif(trigger.to_state.state == "wet", "disable",
        "enable") }}
I think that opening and closing braces around 0 and 100 are not needed.
Please correct me if I’m wrong, I wrote this without being able to test it. Please double check that “binary_sensor.lumi_lumi_sensor_wleak_aq1_iaszone” returns exactly what you are looking for, that is “wet” (Developers/States)
Hope this helps
Thanks I make mistake state of the sensor is on or off even in UI is showing wet or dry . I check it through states in developer tools . Now it is functional
How do i make a repeating sequence (every hour) for two zones that are switched on one after another?
sequences:
  - name: "Neusaat"
    duration: "00:06"
    delay: "00:54"
    repeat: 12
    schedules:
      - time: "07:00"
    zones:
      - zone_id: beet
        duration: "00:03"
      - zone_id: terasse
        duration: "00:03"
What i am getting is a schedule that runs zone 1 for 3 minutes, delays for 54 minutes, runs zone 2 for 3 minutes, waits 54 minutes …
Try using the cron mode scheduler.
sequences:
  - name: "Neusaat"
    duration: "00:03"
    schedules:
      - time:
        cron: "0 7-21 * * *"
    zones:
      - zone_id: beet
      - zone_id: terasse
Heaps of information about cron available on the internet. Try searching for cron expression
Thank you for that!
Hi there,
just started with “Irrigation Unlimited”, I am using version 2023.2.1.
My setup contains one controller, one sequence, four zones and a scheduler for two of the zones, as said, just starting.
controllers:
  enabled: true
  controller_id: bewasserung_restra
  zones:
    - name: Garten
      zone_id: bewasserung_garten
      entity_id: "switch.bewasserung_garten_1z_switch"
      show:
        timeline: true
      schedules:
        - name: "Sonnenaufgang"
          time:
            sun: "sunrise"
            after: "00:00"
          duration: "00:15"
    - name: Rasen
      zone_id: bewasserung_rasen
      entity_id: "switch.bewasserung_rasen_2z_switch"
      schedules:
        - name: "Nach Sonnenaufgang"
          time:
            sun: "sunrise"
            after: "00:30"
          duration: "00:15"
      show:
        timeline: true
    - name: Balkon
      zone_id: bewasserung_balkon
      entity_id: "switch.bewasserung_balkon_3z_switch"
      show:
        timeline: true
    - name: Vorgarten
      zone_id: bewasserung_vorgarten
      entity_id: "switch.bewasserung_vorgarten_4z_switch"
      show:
        timeline: true
  sequences:
    - name: "Eco"
      delay: "00:02"
      repeat: 3
      zones:
        - zone_id: bewasserung_garten
        - zone_id: bewasserung_rasen
Today I decided to change the schedulers a bit, to start a little later after sunrise.
I tried to activate the changes via YAML reload in the developer section, and via service call: irrigation_unlimited_reload.
But the changes are not shown in the attributes of entities of irrigation unlimited nor in the card.
In the standard logs there isn’t any message regarding irrigation unlimited.
What do I need to refresh the schedules?
Thanks a million in advance
Restart HomeAssistant.
The only solution i found :wink:
@StefanHabel
you were right, after a restart the new settings are active.
@rgc99
is there a more convenient option?
Hmm, it should work via the reload. Maybe need to look at this further.
Thanks a lot.
please let me know which information you need from my end.
Cheers
I found that disabling / enabling the controller makes the trick, no need to restart
Thanks @kolia
tried it in the card and via calling the services (disable / enable) directly, but it had no effect.
