Thanks for the reply! Once I set it, I am not sure how to change this parameter throughout the services available, or are you suggesting to use the season approach as this option is not available?
You should be able to manipulate this setting with the load_schedule
service call. Just be aware that currently changes made this way are not permanent and will revert to the yaml on a HA restart.
So I get this:
> Invalid config for [irrigation_unlimited]: [every_n_days] is an invalid option for [irrigation_unlimited]. Check: irrigation_unlimited->irrigation_unlimited->controllers->0->sequences->0->schedules->0->every_n_days. (See /config/configuration.yaml, line 276).
If I try to set
every_n_days: 2
Complete conf:
- name: "Nord"
all_zones_config:
show:
timeline: true
zones:
- name: "Valvola4"
entity_id: "light.irrigazione_1_4_light_4"
- name: "Valvola6"
entity_id: "light.irrigazione_5_8_light_2"
sequences:
- schedules:
- time: "21:00"
schedule_id: "nord_time"
every_n_days: 1
delay: "00:00:05"
zones:
- zone_id: 1
duration: "00:06:30"
- zone_id: 2
duration: "00:01"`Preformatted text`
I tried to add also month as it was in your reply.
Try this.
irrigation_unlimited:
controllers:
- name: "Nord"
all_zones_config:
show:
timeline: true
zones:
- name: "Valvola4"
- name: "Valvola6"
sequences:
- schedules:
- time: "21:00"
day:
every_n_days: 1
start_n_days: 2023-09-20
delay: "00:00:05"
zones:
- zone_id: 1
- zone_id: 2
duration: "00:01"
Is it possible in any way to stablish from/until what day a schedule will run, instead of complete months?
For instance, if I want it to run from april 15th - september 15th.
Thanks!
So itās working as suggest, still I donāt see how to change the ān daysā throughout the āload scheduleā service.
I tested the service without the ādayā parameter, as soon as I add it it fails.
This is the controller
- name: "Nord"
all_zones_config:
show:
timeline: true
zones:
- name: "Valvola4"
- name: "Valvola6"
sequences:
- schedules:
- time: "21:00"
day:
every_n_days: 1
start_n_days: 2023-09-18
delay: "00:00:05"
zones:
- zone_id: 1
- zone_id: 2
duration: "00:01"
and this is the service call:
service: irrigation_unlimited.load_schedule
schedule_id: nord_time
day:
every_n_days: 2
If I remove the day parameter the call is successful, otherwise it returns:
Failed to call service irrigation_unlimited.load_schedule. Could not parse date for dictionary value @ data['day']['start_n_days']. Got None
I also tried removing āstart_n_daysā but no way.
I donāt understand where is my mistake.
I donāt know why but if you put quotes around the date in the service call it works.
day:
every_n_days: 2
start_n_days: "2023-09-18"
Itās a good suggestion. It needs a from:
and until:
in the schedule.
Yes, that would be a good solution, because usually irrigation is done from one day during spring until one day at the end of summer or beginning of autum.
Thank you!
That made the trick! Honestly I didnāt try it, thx.
The āspanā filter enhancement is in the repository. Please manually install and check it out. Two new parameters for the schedule object from:
and until:
. Both are inclusive which means you canāt have one without the other. The format is dd mmm
. Will handle a year wrap around as in the second example.
- schedules:
- time: "06:05"
duration: "00:10"
until: 15 Sep
- time: "07:05"
duration: "00:10"
until: 15 Feb
Have fun.
Thanks!
Iāll try tomorrow and back report to you.
Iāve updated the next files in custom_components/irrigation_unlimited:
- const.py
- irrigation_unlimited.py
- schema.py
- services.yaml
The relevant part of my configuration:
sequences:
- name: 'Secuencia Pinar'
duration: '00:11'
delay: '-00:00:10'
schedules:
- name: 'Noche'
time: '00:00'
until: 15 Sep
- name: 'MaƱana'
time: '09:30'
until: 15 Sep
zones:
- zone_id: [2,3]
duration: 00:06
- zone_id: 1
duration: 00:05
- zone_id: 4
duration: 00:04
- zone_id: [2,3]
duration: 00:06
- zone_id: 1
duration: 00:05
- zone_id: 4
duration: 00:04
When I reload irrigation_unlimited, the next error is given:
āservice irrigation_unlimited/reload could not be called. ācontrollersāā.
Have I missed anything?
The configuration is fine and loads. Did you restart HA after updating the modules?
I didnāt restart. I only reloaded YAML configuration of the module in Depeloper tools.
After a restart, it works everything well.
What Iām seeing is that reloading irrigation unlimited YAML configuration in Depeloper tools doesnāt work completely well in all the cases.
Try to reproduce this:
0: Initial yaml:
until: 15 Sep
1: I change Sep
to Oct
(any date after today).
2: I reload YAML configuration and the sequence is scheduled for tomorrow.
3: I change back Oct
to Sep
(any date before today).
4: I reload YAML configuration and the sequence is still scheduled for tomorrow.
5: I restart HA and scheduled is deleted for tomorrow, as it should be.
This is a display problem in the card. When there is no forward schedule it is converting a null
to a date which ends up at 1 Jan 1970 which happens to be a Thursday. It should actually be blank in this situation.
Iām having trouble to understand how check_back works. Here is my set-up. Each time a switch is actioned it publishes the relevant data to an IP relay box using MQTT. A a matter of fact, sometimes, quite barely I must admit, there is a discrepancy between the logical state of the switch and its physical state, full moon effect ?
I have currently set-up the relay box to send the relay state to an input_boolean whenever it changes. Iām wondering how check_back objet could be used then. Since there no direct integration between HA and the relay box, Iām afraid check_back is of no use. What is your feeling? If not, may be a future RFI?
Hi, i found it today, but i didnāt come very clear.
What kind of hardware does it controls? Only valves? A list of compatible?
Thx in advance!
Hi there,
Iām struggling with the duration being set at 5 minutes for each zone; however, with five zones in the sequence, Iām only getting a duration of 1:07 for each zone. Iāve included just the relevant sequence config to keep the size down.
Regs,
Paul
#irrigation_unlimited:
granularity: 10
refresh_interval: 10
controllers:
- name: Controller 1
enabled: true
all_zones_config:
allow_manual: true
duration: '00:05'
zones:
- zone_id: '1'
entity_id:
- switch.irrigation_master_under_house
- switch.irrigation_solenoid_1
- zone_id: '2'
entity_id:
- switch.irrigation_solenoid_2
- zone_id: '3'
entity_id:
- switch.irrigation_solenoid_3
- zone_id: '4'
entity_id:
- switch.irrigation_solenoid_4
- zone_id: '5'
entity_id:
- switch.irrigation_master_shed
- switch.irrigation_solenoid_5
- zone_id: '6'
name: 'Grass Area 1'
entity_id:
- switch.irrigation_solenoid_6
- zone_id: '7'
name: 'Grass Area 2'
entity_id:
- switch.irrigation_solenoid_7
- zone_id: '8'
entity_id:
- switch.irrigation_solenoid_8
- zone_id: '9'
name: 'Rear Retaining'
entity_id:
- switch.irrigation_solenoid_9
- zone_id: '10'
entity_id:
- switch.greenhouse_bucket_irrigation
sequences:
- name: 'Annual - Group 1'
schedules:
- name: 'Summer'
month: [dec, jan, feb]
time: '07:00'
- name: 'Winter'
month: [jun, jul, aug]
weekday: [mon, thu, sun]
time: '07:00'
- name: 'Spring/autumn'
month: [mar, apr, may, sep, oct, nov]
time: '12:25'
zones:
- zone_id: 2
duration: "00:05"
- zone_id: 4
duration: "00:05"
- zone_id: 5
duration: "00:05"
- zone_id: 8
duration: "00:05"
- zone_id: 9
duration: "00:05"
Check back assumes the switch entity is read/write. In your case the switch is write only and the state is accessed via another read only entity.
One solution without any code changes might be to make the input_boolean the āswitchā. Irrigation Unlimited will still happily turn it on and off. When it changes the appropriate MQTT commands are sent but it still responds to the relay state changes. The input_boolean would reflect the physical state of the relay.
Other than that an entity_id:
parameter under the check_back
object which would be used to read the switch state.
