hello,
I will try to schedule the irrigation but if I put weekday after sun and delay the program reply with this error.
Is not possible to do like this?
hello,
In the future, please use ```yaml syntax for the code. among other things it will permit cut/paste.
Correct syntax, as per documentation is:
schedules:
- time:
sun: "sunrise"
before: "01:00"
schedule_id: "xxxx"
weekday: [sun,mon]
Thank you!
Sorry iām a novice of Home assistant and yaml code!
Thanks. I saw that github issue after I posted here and realized this was about using an external sensor to turn off a valve after some volume of water was used. Iām trying to calculate volume based on the time a valve is on (as Iām sure you saw).
On a related note, I did try the AI-on-the-edge-device to read my meter with a camera, which kind of worked (and a fun project) but my ESP32 was probably at the end of the Wifi range so had some problems reading. I might try a reflective optical sensor as a pulse counter. I could not get a proximity sensor to work anywhere on the meter.
Thank you so much again for your response. I was able to follow much of what you provided and I think I have successfully set up the adjustment of irrigation time based on the Smart Irrigation calculations. However, I am facing 2 issues -
UPDATE - Indeed the Rainbird integrationās default irrigation time was overriding IU times for the switches. I have simply increased the default time and I let IU control how long to run irrigation.
I may have solved the 2nd problem I described. It appears that the Rainbird integration has a default irrigation time (which happens to be 6 minutes). So maybe the actual switches were being overridden using this limit no matter what I set in Irrigation unlimited. I will test this tomorrow and see how long the irrigation actually takes place.
Hello @rgc99 ,
Im trying to install your custom component, but Iām not able to load the Irrigation Unlimited Card. Even installing all via HACS, as soon Iām trying to add the card, itās not in list. There is a custom card which stays always on loading state but Iām not sure itās the irrigation card or not:
Suggestions?
ā solution ā
Iāve tried to add the irrigation-unlimited-card.js even via settings - dashboard - resources - add /hacsfiles/irrigation-unlimited-card/irrigation-unlimited-card.js as javascript module, now I can see itā¦ sorry.
Thanks,
Simon
Dear @rgc99 Iām still playing with your integration and in a basic way, it works well. Great!!
Now Iāve two questions:
Is possible to schedule one zone that starts on sunrise only with +1hour offset only on monday, tuesday and friday?
Can you help me to introduce a check that if a binary sensor is triggered, the scheduler is disabled? Iāts a soil moisture sensor that gets triggered and stay triggered until its enough dry, so Iāll skip the scheduler until is false.
Thanks all for the help!
Simon
I have been using this integration for some time and very happy. I was looking to leverage more from what the integration has to offer, and one of the things I would like to get is the total water consumption I have for my lawn as a function of time. Ideally, this would be a utility meter. I see that some users have managed to achieve that. I also see that each irrigation_unlimited_zone in my setup has an attribute āflow_rateā and āvolumeā, which I am assuming is what I would need. However, I havenāt found how to set the flow_rate information up in my configuration (I am guessing the volume is calculated by flow_rate * total_run_time).
There is a major revamp of the frontend card in the works. One new feature is support for languages. If you would like to contribute some translations then head over to the discussion page on GitHub here. There really isnāt that much to do but will make all the difference.
This is still under development and it goes a little further. Irrigation Unlimited monitors an external water consumption sensor and shuts off the valve when a limit is reached. The sensor is much like other energy sensors in HA whose state is ever increasing as it is consumed. The idea is you can schedule by time or volume. Great for unreliable water pressure where you want to deliver a certain amount of water. You can follow the discussion or get involved here.
I had my first major failure:
in some of my zones I am using a zigbee valve that has no on/off functionallity, but a number entity to open the valve between 0 (closed) and 100 (open).
because of this i am using a virtual switch to turn it on and off with an automation.
Now because of the simple virtual switch the check_back function only checks the virtual switch. Last night the zigbee valve did not respond to the virtual switch and so has been left open for hours, while i was asleep.
How can i prevent this in the future?
check_back:
state_on: "100"
state_off: "0"
entity_id: "number.irrigatie_bomen_valve_state"
The integration was recently updated to natively support valve
and cover
domain types in addition to light
and switch
(Note to self - update documentation).The number domain is something new but it sounds like a type of valve where a value of 50 is half way.
Please post the automation or just the action part so I can see how you operate it.
I have been trying to make this work. However, I keep getting error Custom element doesn't exist: hui-markdown-card
. I have installed the hui-element through HACS. Do I need something else?
Hello
I use this integration with two controllers. I would like to display on my dashboards only one controller but I canāt filter with the card āirrigation-unlimited-cardā.
Is this a syntax problem or a naming problem of the entity?
Thanks for your help.
YAML āirrigation_unlimited:ā
refresh_interval: 1
controllers:
- name: "Rain Bird RC2"
all_zones_config:
show:
timeline: true
config: true
zones:
- name: "Massifs Nord"
entity_id: switch.rain_bird_sprinkler_1
- name: "Massifs Ouest"
entity_id: switch.rain_bird_sprinkler_2
- name: "Massifs Sud-Est"
entity_id: switch.rain_bird_sprinkler_3
- name: "Massifs Sud"
entity_id: switch.rain_bird_sprinkler_4
- name: "Potager"
entity_id: switch.rain_bird_sprinkler_5
- name: "<non affectƩ>"
entity_id: switch.rain_bird_sprinkler_6
enabled: false
sequences:
name: "Arrosage des Massifs"
schedules:
- name: "Massifs tous les 2 jrs"
time: "20:00"
day:
every_n_days: 2
start_n_days: 2024-08-10
zones:
- zone_id: 1
duration: "03:00"
- zone_id: 2
duration: "02:00"
- zone_id: 3
duration: "03:00"
- zone_id: 4
duration: "02:00"
- name: "Piscine"
all_zones_config:
show:
timeline: true
config: true
zones:
- name: "Filtration"
YAML ācustom:irrigation-unlimited-cardā, ko controller filter
type: custom:irrigation-unlimited-card
always_show_zones: false
always_show_sequences: true
controllers: binary_sensor.irrigation_unlimited_c1_m
It should be just the controller number
controllers: 1
Also the refresh_interval: 1
consumes considerable resources. The updated card (version 2024.8.0) doesnāt require this for one second count down timers.
Thank you for responding. I did look through the documentation there a little bit but didnāt find a fix. However, after lurking on the discord channel, I found a cause for why this happens, and how to fix it. The fix apparently is to simply add another markdown card. It is explained here in this response on discord - Discord
What is the best way to simply program a sequence to repeat āforeverā? My setup is for sequentially misting several aeroponic buckets for 5 seconds every minute. Presently the script does not contain a Schedule, since I do not want to defer the start time. I have tried multiple attempts using a While statement without success (I am not really a programmer). I am ok with using the Irrigation Unlimited card to stop the sequence when necessary. This may not be the most elegant solution, but I am looking for something easy. Any assistance is appreciated.
Ron
Hey All,
Just updated to latest HA and received the following. Any thoughts on how to address?
Setup failed for custom integration āirrigation_unlimitedā: Unable to import component: cannot import name āDATA_INSTANCEā from āhomeassistant.components.recorder.constā (/usr/src/homeassistant/homeassistant/components/recorder/const.py)
