Is it posible to have 'Boost' in generic_thermostat?
You need to add the input number to your configuration.yaml as well.
input_number:
  boost_time:
    min: 1
    max: 90 # or whatever max and min minutes you want
    step: 1
    unit_of_measurement: Min
    icon: mdi:update
Then add that to your front end too.
Thanks again tom_l, I now have a reasonable understanding of input boolean in HA, which will hopefully help guide me through it when I need to use it again.
Not sure if author or @tom_l is still here?
I was looking for same solution, i’ve got it working ‘nearly’ well, except of few things…
I’ve got Thermostat and TRV, which i want to change both, so i’ve just added 2nd entity to store in scene, then revert it, but for some reason it is not storing or reverting my TRV values. I’ve tried it as 2nd entity in same scene and i’ve tried to add 2nd scene with different name to store only TRV value, but no joy so far…
2nd thing is, it is not switching my input_boolean.boost button off, i think a few things has changed in automation in last year, but i can’t solve that mystery…
- id: '1605910816208'
  alias: Turn on boost
  description: ''
  - platform: state
    entity_id: input_boolean.boost
    to: 'on'
  condition: []
  - service: scene.create
      scene_id: before_boost
      snapshot_entities:
      - climate.thermostat
      - climate.thermostat_3
  - service: climate.set_temperature
      temperature: 25
    entity_id: climate.thermostat
      temperature: 25
    entity_id: climate.thermostat_3
  mode: single
- id: '1605911655169'
  alias: Turn off boost
  description: ''
  - platform: state
    to: 'off'
  - platform: state
    to: 'on'
    for: '5'
  condition: []
  - service: scene.turn_on
    data: {}
    entity_id: scene.before_boost
  - service: input_boolean.turn_off
    data: {}
  mode: single
I’ve sorted helper button state, but it does not save or restore state of my TRV, however when i use call service to set temp via same method it does work…Any clues?
