That is a script, wite it into a file and make it executable, then execute it
And it certainly isn’t finished.
I assume this isn’t on the internet, and I won’t be able to try it out?
It is actually is online at a remote location.
perhaps PM me the details, that requires you to trust me. I will NOT be offended if you don’t PM me.
Sure, I was actually able to create a vbs script which writes the output to a file, but have no idea how to bring that info into HA.
Edit: Sent
If you have that file visible to HA, (exactly as the output above) then the command is reasonably simple, to get the first line it’s something like
grep READING1 filename |cut -b 17-20
I had a short play but then it was bed time
no worries
If you can do it in Python, then you can use telnetlib. The following is what I use to login to a router and get some data. By no means saying its well written, but it does work
I run it via cron periodically, and the results are output in JSON, which I decode in HA to create sensors. I am sure you could tailor it to achieve what you do above.
try:
# print("Opening Telnet connection")
telnet = telnetlib.Telnet('192.168.xxx.xxx')
# print("Created new Telnet instance")
telnet.read_until(b'Username : ', 20)
# print("Found username")
telnet.write(('xxxxxx' + '\r\n').encode('ascii'))
# print("Sending username")
telnet.read_until(b'Password : ', 20)
# print("Found password")
# print("Sending password")
telnet.read_until(b'=>', 20)
# print("Found prompt")
telnet.write(('hostmgr list\r\n').encode('ascii'))
# print("Calling hostmgr")
devices_result = telnet.read_until(b'=>').split(b'\r\n', 60)
# print("Command complete")
telnet.write(('exit' + '\r\n').encode('ascii'))
# print("Sent exit command")
exit
except EOFError:
print("Unexpected response from router")
return
except ConnectionRefusedError:
print("Connection refused by router. Telnet enabled?")
return
except:
print("Error")
return
Hope that helps get you started.
OK so you have a script that gets the text that the telnet generates. Lets call that text file scirpttest.
I assume that there are always the same line lengths, ie the data you want starts at byte 32 and finishes on 35.
grep searches a file and outputs the line that contains the text searched for.
cut finds characters from that line. In this case by bytecount from the start of the line.
grep READING1 scripttest
outputs
1 READING1 1578 22.25 0.0 78.5 4422
After cut is applied
grep READING1 scripttest|cut -b 32-35
outputs
1578
So your commandline sensor
- platform: command_line
command: "grep READING1 scripttest|cut -b 32-35"
unit_of_measurement: "gal"
upload_interval: #this will depend how often you want it to update
Looks promising, I’ll give it a shot, not so great with python or scripting, thanks.
Looks simple enough, but one issue, the script I ran is on a Windows Laptop and not automated, as it’s not always on or in one place, I guess I just need to figure out a python script to run on my Raspberry Pi, which could then be used as advised.
Either a python script or an expect script
Meanwhile I seem to have broken it, the server is rejecting my connections now
(Sorry)
Yeah, happened a few times for me as well while using scheduled task, issue was in windows group policy, just rebooted, should be fine now.
I’m doing something very similar to this, did you ever get this working?
Yes it works.
@nickrout I have stumbled across this post. Your data and connection seems very familiar to a Veeder Root Tank Monitor. I am to working on this. Would you mind sharing any scripts or tutorials?
Thank you,
Alex
They are shared above.
I know this is a lot to ask for but I looking for a step by step tutorial. I am a complete novice with home assistant and im trying to learn. I am getting lost on what the procedure is to actually create this sensor. @nickrout
Thank you for you help!
Alex
This approach doesn’t seem to work from within HA (HomeAssistantOS install) because Python scripts, while exposed as services via the Python Script integration Python Scripts - Home Assistant , run in a sandbox environment where one gets no telnetlib:
NameError: name ‘telnetlib’ is not defined
Code:
command = data.get("command")
logger.info("telnet {} at {}".format(command, time.time()))
try:
telnet = telnetlib.Telnet('10.X.Y.Z', 23, 90)
output = telnet.read_until(b'login: ', 20)
telnet.write(('abcxyz' + '\r\n').encode('ascii'))
output = telnet.read_until(b'connection established : ', 20)
telnet.write((':G\r\n').encode('ascii'))
current_scene = telnet.read_until(b' OK')
logger.info('Telnet: current scene: ' + current_scene)
Telnet.close()
except EOFError:
logger.error('Telnet: unexpected output from server: ' + output)
except Exception as e:
logger.error('Telnet error :' + e)
