Is it possible to disable the new loginscreen
You can understand that whoever updates to this latest release-202312 automatically have all their users exposed in their LAN and you can assume that most (if not all) people use a proxy, they automatically get all their users exposed to the outside world.
It seems that something might have been done about this here yesterday: Add option for exposing users on local networks by edenhaus · Pull Request #105545 · home-assistant/core · GitHub
But then again they made this option to default TRUE (which should logically from a security standpoint be defaulted to FALSE). Ridiculous.
Wait, this is good news. Ok, they will add an option to disable the public user list.
So in your view almost everyone is using a reverse proxy, and the majority of those have it configured in a way that does not pass the origin ip through to Home Assistant correctly, likely ignoring the inclusion of the X-Forwarded-For header and possibly other headers. They connect from outside their network, and they appear to HA to be connecting from a device inside their network.
Ignoring the local login page, how could that best be addressed?
Maybe a repair could be added?
HA could detect suspicious patterns in X-Real-IP and inform the user with a repair.
Typical patterns would be:
  • always the same X-Real-IP
  • always one from a local network
Most of users haven’t ever heard about reverse proxy and the X-Forwarded-For header and possibly other headers. They surf WWW and repeat as shown. As for me, I’m not a super-puper IT-specialist, so I found several ways to expose my HA to WWW. The most suitable for me is SSH-tunnel between HA and VPS (I suppose it works as reverse proxy). The Nginx on VPS forwards requests on VPS to necessary port on HA. And when I log in from outside my home network my HA detects it as local login. So default security settings for most users must be the Highest Security!
I think you underestimate most users. Yes, there are users who only use Home Assistant on private network, and ofcourse a lot of users use Home Assistant Cloud.
Then there are the tech savvy users. They read the changelog, can Identify the problem and (if possible) implement a fix.
Everything in between are users that copy paste every possible solution on Stack Overflow untill it works for them. I think this is the vast majority.
Feature has been disabled:
