Hello, i’ve bought Xiaomi Dafang 1080p camera and i want to configure it with Home Assistant, is it possible?
Someone has tried this integration? is it working?
Thanks a lot
SDK here for the devs - https://github.com/dim08/Ingenic-T10_20
Not sure if this is the correct place to post it, if not, please let me know.
I think it’s not possible yet, someone’s working on hacks, but seems there’s no good news
Hi, I have… works good.
Use this hack…https://github.com/EliasKotlyar/Xiaomi-Dafang-Hacks/
The Image is great!!!
I flashed the hack, and now it seems to be online…how can i try if RTSP works?
Which parameters must i use?
Someone is able to create a custom ui for this camera ?
for example by adding the keys for controlling the motor or leds
You can add like this
- platform: command_line
switches:
led:
command_on: ‘curl -k “http://CAMERAIP/cgi-bin/action.cgi?cmd=blue_led_on”’
command_off: ‘curl -k “http://CAMERAIP/cgi-bin/action.cgi?cmd=blue_led_off”’
@olskar the problem is not the individual commands but have them in a single interface with the camera image. New firmware versione support Mqtt commands also
do you have other commands i.e. for movements too that you can share please?
Have you seen that thread Hacking the XiaomiFang Wifi camera? You can control almost everything via mqtt now.
Hello.
How can I use Xiaomi Dafang 1080p camera with Alexa and google home ? Xiaomi Dafang 1080p camera and Wyze Pan Cam both are same. It is possible to purchase China Xiaomi Dafang 1080p camera and some how through CFW enable the ALEXA or Google Home integration.
