For all fans, my complete yaml with power measurement and the whole shabang
substitutions:
device_name: shelly_rgbw_01
esphome:
platform: ESP8266
board: esp01_1m
esp8266_restore_from_flash: true
wifi:
ssid: "ssid"
password: !secret ssid_wifi_key
domain: !secret domain
#use_address: 192.168.6.70
ap:
ssid: "${device_name} Fallback Hotspot"
password: !secret Fallback_Hotspot
#fast_connect: true
captive_portal:
# Enable logging
logger:
level: DEBUG
# Enable Home Assistant API
api:
ota:
web_server:
port: 80
time:
- platform: homeassistant
- platform: wifi_signal
name: "${device_name} - WiFi Signal"
update_interval: 60s
- platform: uptime
name: "${device_name} - Uptime"
icon: mdi:clock-outline
- platform: uptime
name: "${device_name} - Uptime Seconds"
on_raw_value:
then:
- text_sensor.template.publish:
state: !lambda |-
int seconds = round(id(uptime_sensor).raw_state);
int days = seconds / (24 * 3600);
seconds = seconds % (24 * 3600);
int hours = seconds / 3600;
seconds = seconds % 3600;
int minutes = seconds / 60;
seconds = seconds % 60;
return (
(days ? String(days) + "d " : "") +
(hours ? String(hours) + "h " : "") +
(minutes ? String(minutes) + "m " : "") +
(String(seconds) + "s")
).c_str();
- platform: adc
pin: A0
name: "${device_name} - adc"
update_interval: 1s
accuracy_decimals: 4
internal: true
name: "${device_name} - Power"
unit_of_measurement: W
accuracy_decimals: 1
device_class: power
update_interval: 30s
lambda: return id(current_raw).state;
filters:
- calibrate_linear:
- 0.4000 -> 0.0
- 0.4043 -> 0.14
- 0.4053 -> 0.20
- multiply: 12 # 12V lamp
- platform: total_daily_energy
name: "${device_name} - Total Daily Energy"
power_id: my_power
filters:
# Multiplication factor from W to kW is 0.001
- multiply: 0.001
unit_of_measurement: kW
light:
- platform: monochromatic
output: ${device_name}_out_R
restore_mode: RESTORE_DEFAULT_OFF
output: ${device_name}_out_G
output: ${device_name}_out_B
output: ${device_name}_out_W
restore_mode: RESTORE_DEFAULT_ON
output:
- platform: esp8266_pwm
pin: GPIO12
frequency: 1000 Hz
pin: GPIO15
frequency: 1000 Hz
pin: GPIO14
frequency: 1000 Hz
pin: GPIO4
frequency: 1000 Hz
text_sensor:
icon: mdi:clock-start
- platform: version
name: "${device_name} - ESPHome Version"
- platform: wifi_info
ip_address:
name: "${device_name} - IP"
switch:
- platform: restart
name: "${device_name} - Restart"
