I originally copied the text as is from the manual, but the server failed to load after restarting it. Only when I removed the content of the automation.yaml file I managed to start the service again.
I changed the way the code is presented in the message, if help looking at it.
Anyway, I will do it all again today to make sure nothing is missed.
You need to check you have the 2 recipes in IFTTT to work this.
You will be using ‘Receive a Web Request’ with the event ID of sonoff-2-off for one of them with a ‘that’ set to eWelink which will pick up the channel switch and you set the action to on or off.
This worked 100% for me and I documented how I did it in case I ever wanted to use that again. I flashed the switch with Tasmota so I’m using MQTT now but this works perfectly albeit with a slight delay using eWeLink and IFTTT. Make sure you have your IFTTT API key set up correctly in configuration.yaml as well.
try https://shelly.cloud/ - they are esp8266 based, by their fw has option to use MQTT locally (with completely disabled cloud) and form factor is awesome. I use several of them (single and double relays) and very happy with it. no more tasmota )
