Is there are any ready solutions for simple battery powered display, for simple information
So, I tried to make e-ink display with ESPhome.
The problem is: if I don’t use deep_sleep, battery will die in one day. But if I use deep sleep, system is not receiving updates from Home Assistant, because they happen when ESP32 sleeps.
Do you have any advice on that?
Example code with deep_sleep:
esphome:
  platform: ESP32
  board: esp32dev
wifi:
  ssid: "COVID-19"
  password: "---"
  ap:
    ssid: "Display Eink Fallback Hotspot"
    password: "-"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
  password: "-"
ota:
  password: "-"
web_server:
  port: 80
deep_sleep:
  run_duration: 10s
  sleep_duration: 10min
time:
  - platform: homeassistant
    name: "Outside Temperature"
    entity_id: sensor.outside_temperature
    internal: true
    name: "Living Room Temperature"
    entity_id: sensor.living_room_temperature
    internal: true
    name: "Living Room Humidity"
    entity_id: sensor.living_room_humidity
    internal: true
    name: "Kitchen Temperature"
    entity_id: sensor.kitchen_temperature
    internal: true
    name: "Kitchen Humidity"
    entity_id: sensor.kitchen_humidity
    internal: true
    name: "Bedroom Temperature"
    entity_id: sensor.bedroom_temperature
    internal: true
    name: "Bedroom Humidity"
    entity_id: sensor.bedroom_humidity
    internal: true
    entity_id: input_number.living_room_amount_of_lights
    force_update: true
    internal: true
font:
  - file: "OpenSans-SemiBold.ttf"
spi:
  clk_pin: 13
  mosi_pin: 14
display:
  - platform: waveshare_epaper
    cs_pin: 15
    busy_pin: 25
    reset_pin: 26
    dc_pin: 27
    model: 4.20in
    #model: 7.50inV2
    #update_interval: 10min
    update_interval: 7s
    #update_interval: 20s
    rotation: 270°
    lambda: |-
      it.printf(300, -20, id(outside_font), TextAlign::TOP_RIGHT,  "%.1f°C", id(outside_temperature).state);
      it.strftime(0, 0, id(date_font), "%Y-%m-%d", id(homeassistant_time).now());
      it.strftime(0, 15, id(date_font), "%A", id(homeassistant_time).now());
      it.line(0, 74, 300, 74);
      it.line(0, 75, 300, 75);
      it.line(0, 76, 300, 76);
      it.line(0, 77, 300, 77);
      it.print(0, 170, id(text_font), TextAlign::BOTTOM_LEFT, "Living R.");
      it.printf(300, 80, id(big_font), TextAlign::TOP_RIGHT, "%.1f°C", id(living_room_temperature).state);
      it.printf(300, 125, id(humidity_font), TextAlign::TOP_RIGHT, "%.0f%%", id(living_room_humidity).state);
      it.line(0, 170, 300, 170);
      it.print(0, 260, id(text_font), TextAlign::BOTTOM_LEFT,  "Kitchen");
      it.printf(300, 170, id(big_font), TextAlign::TOP_RIGHT, "%.1f°C", id(kitchen_temperature).state);
      it.printf(300, 215, id(humidity_font), TextAlign::TOP_RIGHT, "%.0f%%", id(kitchen_humidity).state);
      it.line(0, 260, 300, 260);
      it.print(0, 350, id(text_font), TextAlign::BOTTOM_LEFT, "Bedroom");
      it.printf(300, 260, id(big_font), TextAlign::TOP_RIGHT, "%.1f°C", id(bedroom_temperature).state);
      it.printf(300, 305, id(humidity_font), TextAlign::TOP_RIGHT, "%.0f%%", id(bedroom_humidity).state);
      it.line(0, 350, 300, 350);
      it.printf(100, 400, id(humidity_font), TextAlign::BOTTOM_LEFT, "%.1f", id(test_test).state);
