Is webhooks the right answer for multi-garage door automation?
You still haven’t said what you see in the traces. That’s what they are for, to help debug automations. Most, if not all, of the details you need to figure out how your automation is working, or not, should be there.
It never triggered, the traces showed nothing, i forget to post that.
So this version is what triggers and works without issue to get back to a known good:
alias: Garage - Save last door used v1.11
description: ""
triggers:
  - trigger: state
    entity_id:
      - device_tracker.life360_person1
      - device_tracker.life360_person2
    to: not_home
    for:
      hours: 0
      minutes: 0
      seconds: 45
actions:
  - action: input_text.set_value
      entity_id: "{{ helper }}"
      value: >
        {% set doors = [
            states.cover.ratgdov25i_1be829_door,
            states.cover.ratgdov25i_1be83c_door
        %} {% set last_door = (doors|sort(attribute="last_changed"))[-1] %} {{
        last_door.entity_id }}
variables:
  helper: >-
    input_text.door_{{ trigger.entity_id.removeprefix('device_tracker.life360_')
so the thought was to add “last changed” in the previous 30 minutes as the way to cover any random ghost triggers
