[email protected]:~ $ systemctl list-units --type=service
UNIT LOAD ACTIVE SUB DESCRIPTION
alsa-restore.service loaded active exited Save/Restore Sound Card S
avahi-daemon.service loaded active running Avahi mDNS/DNS-SD Stack
console-setup.service loaded active exited Set console font and keym
cron.service loaded active running Regular background progra
dbus.service loaded active running D-Bus System Message Bus
dhcpcd.service loaded active running dhcpcd on all interfaces
dphys-swapfile.service loaded active exited LSB: Autogenerate and use
fake-hwclock.service loaded active exited Restore / save the curren
[email protected] loaded active running Getty on tty1
keyboard-setup.service loaded active exited Set the console keyboard
kmod-static-nodes.service loaded active exited Create list of required s
networking.service loaded active exited Raise network interfaces
raspi-config.service loaded active exited LSB: Switch to ondemand c
rc-local.service loaded active exited /etc/rc.local Compatibili
rsyslog.service loaded active running System Logging Service
[email protected] loaded active running Serial Getty on ttyAMA0
ssh.service loaded active running OpenBSD Secure Shell serv
systemd-fsck-root.service loaded active exited File System Check on Root
[email protected]\x2dpartuuid-762b43d6\x2d01.service loaded active exited File System Check on /dev
systemd-journal-flush.service loaded active exited Flush Journal to Persiste
systemd-journald.service loaded active running Journal Service
systemd-logind.service loaded active running Login Service
systemd-modules-load.service loaded active exited Load Kernel Modules
systemd-random-seed.service loaded active exited Load/Save Random Seed
systemd-remount-fs.service loaded active exited Remount Root and Kernel F
systemd-sysctl.service loaded active exited Apply Kernel Variables
systemd-timesyncd.service loaded active running Network Time Synchronizat
systemd-tmpfiles-setup-dev.service loaded active exited Create Static Device Node
systemd-tmpfiles-setup.service loaded active exited Create Volatile Files and
systemd-udev-trigger.service loaded active exited udev Coldplug all Devices
systemd-udevd.service loaded active running udev Kernel Device Manage
systemd-update-utmp.service loaded active exited Update UTMP about System
systemd-user-sessions.service loaded active exited Permit User Sessions
triggerhappy.service loaded active running triggerhappy global hotke
[email protected] loaded active running User Manager for UID 1000
LOAD = Reflects whether the unit definition was properly loaded.
ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
SUB = The low-level unit activation state, values depend on unit type.
35 loaded units listed. Pass --all to see loaded but inactive units, too.
nothing in there that resembles home assistant. maybe i missed a step during setup?
im starting over!
