Just upgraded to 20230503.1 (didn’t really notice the version number, but this is shown under the about)
My nest protect stopped working. I have tried to re-install it but still no joy, any ideas?
I am following the instructions on HACS/Nest Protect using issue token & cookies.
This error originated from a custom integration.
Source: custom_components/nest_protect/init.py:126
Integration: Nest Protect (documentation, issues)
First occurred: 09:14:59 (1 occurrences)
Last logged: 09:14:59
Error setting up entry Nest Protect for nest_protect
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 387, in async_setup
result = await component.async_setup_entry(hass, self)
File "/config/custom_components/nest_protect/__init__.py", line 126, in async_setup_entry
hass.config_entries.async_setup_platforms(entry, PLATFORMS)
AttributeError: 'ConfigEntries' object has no attribute 'async_setup_platforms'
I get the same, after installing hacs integration huawei solar:
Source: custom_components/hacs/__init__.py:171
Integration: HACS (documentation, issues)
First occurred: 15:56:45 (2 occurrences)
Last logged: 16:05:47
Error setting up entry for hacs
File "/config/custom_components/hacs/__init__.py", line 220, in async_setup_entry
setup_result = await async_initialize_integration(hass=hass, config_entry=config_entry)
File "/config/custom_components/hacs/__init__.py", line 206, in async_initialize_integration
await async_try_startup()
File "/config/custom_components/hacs/__init__.py", line 193, in async_try_startup
startup_result = await async_startup()
File "/config/custom_components/hacs/__init__.py", line 171, in async_startup
The async_setup_platforms function had been marked deprecated a while back, initially set to fail as obsolete in 2023.3. Now it actually fails in 2023.5, as previously announced.
Since all the messages in this thread are about custom integrations (likely from HACS) the developer of those custom integrations will need to update their integration to use to use await async_forward_entry_setups instead of async_setup_platforms.
Briefly looked into the implementation of this particular custom integration and I was surprised to find that it was already migrated to use async_forward_entry_setups in lieu of async_setup_platforms about three months ago (and I’m running that specific version). Also confirmed async_setup_platforms doesn’t even show up in the codebase anymore. So… the plot thickens. Perhaps my HA installation is using a cached version?
Edit: Yep. Fully removing the integration and repo via HACS, then reinstalling seemed to do the trick!
I don’t like installing beta versions, but I have installed version 0.4.0b1 just to try it out. It is working and all the Nest Protect Sensors are online now.
Worth pointing out that this doesn’t work if you have Nest Protect devices. Nest Protect (smoke/CO2) don’t appear as Google devices in Google Home. That’s not a bug, that’s explicitly stated by Google. So using the built-in core nest support won’t work - “Can’t find devices to link”
There appears to have been quite a lot changes regarding the initial configuration workflow that are not yet merged into main.
Edit: I’ve just tried this out myself by deleting the contents of my nest_protect folder (within custom_components) and copying in the contents of the /custom_components/nest_protect/ from the ‘beta’ branch of ha-nest-protect on GitHub.
This has actually solved the problem, but I suspect it’s this comment here that’s stopping iMicknl from merging into the main branch? I’d advise caution if you’re using the old auth-token method for authenticating with Google/Nest.
