Hope this is not to OT, but since installing the ZBDongle-E, my logs indicate several coordinators in ZHA (see log below)…
The “vid”: “1CF1”, “pid”: “0030”, “description”: “conbee”, “known_devices”: [“Conbee II”] is no longer in use.
As for the “slae.sh cc2652rb stick”, “sonoff zigbee dongle plus v2”, “sonoff zigbee dongle plus”, “Nortek HUSBZB-1”, “Bitron Video AV2010/10”, I dont’t know why they are in the list.
I have two Tubesz routers (usb-powered).
Is the config ready for a clean-up, or does this look normal?
Finally, is it good pactice to connect the cosest tubesz router directly as a child of the ZBDongle-E coordinator?
Thanks!
"home_assistant": {
"installation_type": "Home Assistant OS",
"version": "2022.9.6",
"dev": false,
"hassio": true,
"virtualenv": false,
"python_version": "3.10.5",
"docker": true,
"arch": "aarch64",
"timezone": "Europe/Oslo",
"os_name": "Linux",
"os_version": "5.15.61-v8",
"supervisor": "2022.09.1",
"host_os": "Home Assistant OS 9.0",
"docker_version": "20.10.17",
"chassis": "embedded",
"run_as_root": true
"custom_components": {
"spotcast": {
"version": "v3.6.30",
"requirements": [
"spotify_token==1.0.0"
"xiaomi_miio_airpurifier": {
"version": "2022.8.0.0",
"requirements": [
"construct==2.10.56",
"python-miio>=0.5.12"
"dwains_dashboard": {
"version": "3.3.0",
"requirements": []
"hacs": {
"version": "1.27.2",
"requirements": [
"aiogithubapi>=22.2.4"
"fontawesome": {
"version": "2.1.5",
"requirements": []
"zha_toolkit": {
"version": "v0.8.16",
"requirements": []
"reolink_dev": {
"version": "0.57",
"requirements": [
"reolink==0.0.62"
"rpi_gpio": {
"version": "2022.7.0",
"requirements": [
"RPi.GPIO==0.7.1"
"xiaomi_gateway3": {
"version": "2.1.1",
"requirements": [
"zigpy>=0.33.0"
"integration_manifest": {
"domain": "zha",
"name": "Zigbee Home Automation",
"config_flow": true,
"documentation": "https://www.home-assistant.io/integrations/zha",
"requirements": [
"bellows==0.33.1",
"pyserial==3.5",
"pyserial-asyncio==0.6",
"zha-quirks==0.0.79",
"zigpy-deconz==0.18.1",
"zigpy==0.50.3",
"zigpy-xbee==0.15.0",
"zigpy-zigate==0.9.2",
"zigpy-znp==0.8.2"
"usb": [
"vid": "10C4",
"pid": "EA60",
"description": "*2652*",
"known_devices": [
"slae.sh cc2652rb stick"
"vid": "1A86",
"pid": "55D4",
"description": "*sonoff*plus*",
"known_devices": [
"sonoff zigbee dongle plus v2"
"vid": "10C4",
"pid": "EA60",
"known_devices": [
"sonoff zigbee dongle plus"
"vid": "10C4",
"pid": "EA60",
"description": "*tubeszb*",
"known_devices": [
"TubesZB Coordinator"
"vid": "1A86",
"pid": "7523",
"known_devices": [
"vid": "1A86",
"pid": "7523",
"description": "*zigstar*",
"known_devices": [
"ZigStar Coordinators"
"vid": "1CF1",
"pid": "0030",
"description": "*conbee*",
"known_devices": [
"Conbee II"
"vid": "10C4",
"pid": "8A2A",
"description": "*zigbee*",
"known_devices": [
"Nortek HUSBZB-1"
"vid": "0403",
"pid": "6015",
"description": "*zigate*",
"known_devices": [
"ZiGate+"
"vid": "10C4",
"pid": "EA60",
"known_devices": [
"ZiGate"
"vid": "10C4",
"pid": "8B34",
"description": "*bv 2010/10*",
"known_devices": [
"Bitron Video AV2010/10"
"codeowners": [
"@dmulcahey",
"@adminiuga",
"@puddly"
"zeroconf": [
"type": "_esphomelib._tcp.local.",
"name": "tube*"
"type": "_zigate-zigbee-gateway._tcp.local.",
"name": "*zigate*"
"dependencies": [
"file_upload"
"after_dependencies": [
"onboarding",
"usb",
"zeroconf"
"iot_class": "local_polling",
"loggers": [
"aiosqlite",
"bellows",
"crccheck",
"pure_pcapy3",
"zhaquirks",
"zigpy",
"zigpy_deconz",
"zigpy_xbee",
"zigpy_zigate",
"zigpy_znp"
"is_built_in": true
"data": {
"ieee": "**REDACTED**",
"nwk": 43555,
"manufacturer": "TubesZB",
"model": "tubeszb.router",
"name": "TubesZB tubeszb.router",
"quirk_applied": false,
"quirk_class": "zigpy.device.Device",
"manufacturer_code": 0,
"power_source": "Mains",
"lqi": 188,
"rssi": -53,
"last_seen": "2022-09-24T12:54:41",
"available": true,
"device_type": "Router",
"signature": {
"node_descriptor": "NodeDescriptor(logical_type=<LogicalType.Router: 1>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress|RxOnWhenIdle|MainsPowered|FullFunctionDevice: 142>, manufacturer_code=0, maximum_buffer_size=80, maximum_incoming_transfer_size=160, server_mask=11264, maximum_outgoing_transfer_size=160, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=False, *is_full_function_device=True, *is_mains_powered=True, *is_receiver_on_when_idle=True, *is_router=True, *is_security_capable=False)",
"endpoints": {
"8": {
"profile_id": 260,
"device_type": "0x00ff",
"in_clusters": [
"0x0000",
"0x0003"
"out_clusters": [
"0x0000"
"242": {
"profile_id": 41440,
"device_type": "0x0061",
"in_clusters": [],
"out_clusters": [
"0x0021"
"active_coordinator": false,
"entities": [
"entity_id": "button.tubeszb_tubeszb_router_identifybutton",
"entity_id": "sensor.tubeszb_tubeszb_router_rssi",
"entity_id": "sensor.tubeszb_tubeszb_router_lqi",
"neighbors": [
"rx_on_when_idle": "Unknown",
"relationship": "Sibling",
"extended_pan_id": "**REDACTED**",
"nwk": "0x84C5",
"permit_joining": "Unknown",
"depth": "255",
"lqi": "40"
"nwk": "0x856D",
"depth": "255",
"lqi": "69"
"nwk": "0x1319",
"depth": "255",
"lqi": "1"
"nwk": "0x2384",
"depth": "255",
"lqi": "159"
"nwk": "0x8D07",
"depth": "255",
"lqi": "16"
"nwk": "0x776B",
"depth": "255",
"lqi": "35"
"device_type": "Coordinator",
"nwk": "0x0000",
"depth": "255",
"lqi": "91"
"nwk": "0xBBD2",
"depth": "255",
"lqi": "28"
"nwk": "0x80CE",
"depth": "255",
"lqi": "1"
"nwk": "0xB752",
"depth": "255",
"lqi": "77"
"nwk": "0xBBFC",
"depth": "255",
"lqi": "73"
"nwk": "0xB102",
"depth": "255",
"lqi": "1"
"nwk": "0x4EA4",
"depth": "255",
"lqi": "39"
"nwk": "0xD061",
"depth": "255",
"lqi": "48"
"nwk": "0x68EF",
"depth": "255",
"lqi": "36"
"nwk": "0xBA2D",
"depth": "255",
"lqi": "194"
"nwk": "0x7ED1",
"depth": "255",
"lqi": "17"
"endpoint_names": [
"name": "unknown 97 device_type of 0xa1e0 profile id"
"name": "undefined_0x00ff"
"user_given_name": "TubesZB tubeszb.router_kjok",
"device_reg_id": "28a97d4a9aef06d9f831e58a07edc471",
"area_id": "621e840fc24f485c98237c819528da63",
"cluster_details": {
"242": {
"device_type": {
"name": "unknown",
"id": 97
"in_clusters": {},
"out_clusters": {
"0x0021": {
"endpoint_attribute": "green_power",
"attributes": {},
"unsupported_attributes": {}
"8": {
"device_type": {
"name": "undefined_0x00ff",
"id": 255
"profile_id": 260,
"in_clusters": {
"0x0000": {
"endpoint_attribute": "basic",
"attributes": {
"0x0004": {
"attribute_name": "manufacturer",
"value": "TubesZB"
"0x0005": {
"attribute_name": "model",
"value": "tubeszb.router"
"0x0003": {
"endpoint_attribute": "identify",
"attributes": {},
"out_clusters": {
"0x0000": {
"attributes": {},
Not sure if it is of relevance, but in the ‘Devices’ under The ZHA-integration, the coordinator shows up as Silicon Labs EZSP (s image).
In the integration overview, however, it shows as a SONOFF Zigbee 3.0 USB Dongle Plus V2. See image.
