Hello all,
Since the last update i got my zigbee pen not working:
The HA can find it since when i reset the integration and remake it again it detectes it and the sensors.
But have no data all the devices are disconected, even the coordinator.
Can anyone help me out?
The log info is:
2023-10-05 00:09:32.848 INFO (MainThread) [zigpy.device] [0x0000] Requesting 'Node Descriptor'
2023-10-05 00:09:32.967 INFO (MainThread) [zigpy.device] [0x0000] Got Node Descriptor: NodeDescriptor(logical_type=<LogicalType.Coordinator: 0>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AlternatePanCoordinator|FullFunctionDevice|MainsPowered|RxOnWhenIdle|AllocateAddress: 143>, manufacturer_code=0, maximum_buffer_size=80, maximum_incoming_transfer_size=160, server_mask=11265, maximum_outgoing_transfer_size=160, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=True, *is_coordinator=True, *is_end_device=False, *is_full_function_device=True, *is_mains_powered=True, *is_receiver_on_when_idle=True, *is_router=False, *is_security_capable=False)
2023-10-05 00:09:32.969 INFO (MainThread) [zigpy.device] [0x0000] Discovering endpoints
2023-10-05 00:09:32.994 INFO (MainThread) [zigpy.device] [0x0000] Discovered endpoints: [2, 1]
2023-10-05 00:09:32.995 INFO (MainThread) [zigpy.device] [0x0000] Initializing endpoints [<Endpoint id=2 in=[] out=[] status=<Status.NEW: 0>>, <Endpoint id=1 in=[] out=[] status=<Status.NEW: 0>>]
2023-10-05 00:09:32.997 INFO (MainThread) [zigpy.endpoint] [0x0000:2] Discovering endpoint information
2023-10-05 00:09:33.026 INFO (MainThread) [zigpy.endpoint] [0x0000:2] Discovered endpoint information: SizePrefixedSimpleDescriptor(endpoint=2, profile=49246, device_type=2080, device_version=0, input_clusters=[0], output_clusters=[])
2023-10-05 00:09:33.027 INFO (MainThread) [zigpy.endpoint] [0x0000:1] Discovering endpoint information
2023-10-05 00:09:33.058 INFO (MainThread) [zigpy.endpoint] [0x0000:1] Discovered endpoint information: SizePrefixedSimpleDescriptor(endpoint=1, profile=260, device_type=1024, device_version=0, input_clusters=[0, 6, 10, 25, 1281], output_clusters=[1, 32, 1280, 1282])
2023-10-05 00:09:33.061 INFO (MainThread) [zigpy.device] [0x0000] Already have model and manufacturer info
2023-10-05 00:09:33.061 INFO (MainThread) [zigpy.device] [0x0000] Discovered basic device information for <ZNPCoordinator model='CC1352/CC2652, Z-Stack 3.30+ (build 20210708)' manuf='Texas Instruments' nwk=0x0000 ieee=00:12:4b:00:2a:2e:8a:3f is_initialized=True>
2023-10-05 00:09:33.073 INFO (MainThread) [zigpy_znp.zigbee.application] Permitting joins for 0 seconds
2023-10-05 00:09:37.986 INFO (MainThread) [homeassistant.components.zha.core.endpoint] Creating cluster handler for cluster id: 0 class: <class 'homeassistant.components.zha.core.cluster_handlers.general.BasicClusterHandler'>
2023-10-05 00:09:37.996 INFO (MainThread) [homeassistant.components.zha.core.endpoint] Creating cluster handler for cluster id: 0 class: <class 'homeassistant.components.zha.core.cluster_handlers.general.BasicClusterHandler'>
2023-10-05 00:09:37.998 INFO (MainThread) [homeassistant.components.zha.core.endpoint] Creating cluster handler for cluster id: 6 class: <class 'homeassistant.components.zha.core.cluster_handlers.general.OnOffClusterHandler'>
2023-10-05 00:09:38.001 INFO (MainThread) [homeassistant.components.zha.core.endpoint] Creating cluster handler for cluster id: 10 class: <class 'homeassistant.components.zha.core.cluster_handlers.general.Time'>
2023-10-05 00:09:38.002 INFO (MainThread) [homeassistant.components.zha.core.endpoint] Creating cluster handler for cluster id: 25 class: <class 'homeassistant.components.zha.core.cluster_handlers.general.Ota'>
2023-10-05 00:09:38.005 INFO (MainThread) [homeassistant.components.zha.core.endpoint] Creating cluster handler for cluster id: 1281 class: <class 'homeassistant.components.zha.core.cluster_handlers.security.IasAce'>
2023-10-05 00:09:38.015 INFO (MainThread) [homeassistant.components.zha.core.endpoint] Creating cluster handler for cluster id: 0 class: <class 'homeassistant.components.zha.core.cluster_handlers.general.BasicClusterHandler'>
2023-10-05 00:09:38.016 INFO (MainThread) [homeassistant.components.zha.core.endpoint] Creating cluster handler for cluster id: 3 class: <class 'homeassistant.components.zha.core.cluster_handlers.general.Identify'>
2023-10-05 00:09:38.017 INFO (MainThread) [homeassistant.components.zha.core.endpoint] Creating cluster handler for cluster id: 1 class: <class 'homeassistant.components.zha.core.cluster_handlers.general.PowerConfigurationClusterHandler'>
2023-10-05 00:09:38.022 INFO (MainThread) [homeassistant.components.zha.core.endpoint] Creating cluster handler for cluster id: 2 class: <class 'homeassistant.components.zha.core.cluster_handlers.general.DeviceTemperature'>
2023-10-05 00:09:38.023 INFO (MainThread) [homeassistant.components.zha.core.endpoint] Creating cluster handler for cluster id: 65535 class: <class 'homeassistant.components.zha.core.cluster_handlers.ClusterHandler'>
2023-10-05 00:09:38.100 INFO (MainThread) [homeassistant.components.zha.core.endpoint] Creating cluster handler for cluster id: 0 class: <class 'homeassistant.components.zha.core.cluster_handlers.general.BasicClusterHandler'>
2023-10-05 00:09:38.102 INFO (MainThread) [homeassistant.components.zha.core.endpoint] Creating cluster handler for cluster id: 1 class: <class 'homeassistant.components.zha.core.cluster_handlers.general.PowerConfigurationClusterHandler'>
2023-10-05 00:09:38.103 INFO (MainThread) [homeassistant.components.zha.core.endpoint] Creating cluster handler for cluster id: 3 class: <class 'homeassistant.components.zha.core.cluster_handlers.general.Identify'>
2023-10-05 00:09:38.104 INFO (MainThread) [homeassistant.components.zha.core.endpoint] Creating cluster handler for cluster id: 1026 class: <class 'homeassistant.components.zha.core.cluster_handlers.measurement.TemperatureMeasurement'>
2023-10-05 00:09:38.108 INFO (MainThread) [homeassistant.components.zha.core.endpoint] Creating cluster handler for cluster id: 1027 class: <class 'homeassistant.components.zha.core.cluster_handlers.measurement.PressureMeasurement'>
2023-10-05 00:09:38.110 INFO (MainThread) [homeassistant.components.zha.core.endpoint] Creating cluster handler for cluster id: 1029 class: <class 'homeassistant.components.zha.core.cluster_handlers.measurement.RelativeHumidity'>
2023-10-05 00:09:38.111 INFO (MainThread) [homeassistant.components.zha.core.endpoint] Creating cluster handler for cluster id: 65535 class: <class 'homeassistant.components.zha.core.cluster_handlers.ClusterHandler'>
Logger: homeassistant.helpers.integration_platform
Source: helpers/integration_platform.py:61
First occurred: 21:51:38 (1 occurrences)
Last logged: 21:51:38
Error processing platform zha.repairs
File "/usr/src/homeassistant/homeassistant/helpers/integration_platform.py", line 61, in _async_process_single_integration_platform_component
await integration_platform.process_platform(hass, component_name, platform)
File "/usr/src/homeassistant/homeassistant/components/repairs/issue_handler.py", line 113, in _register_repairs_platform
raise HomeAssistantError(f"Invalid repairs platform {platform}")
homeassistant.exceptions.HomeAssistantError: Invalid repairs platform <module 'homeassistant.components.zha.repairs' from '/usr/src/homeassistant/homeassistant/components/zha/repairs.py'>
Thank
