Please try reading my response
I didn’t say half a second, I didn’t say the duration of the MP3.
Sorry!
I just asked to understand how HA thinks.
However I set the pause of 1 second using the “delay” command, but the result does not change.
- service: media_player.volume_set
entity_id: media_player.mini_tutti
volume_level: 0.45
- service: media_player.play_media
media_content_id: https://xxxxxxx:xxx/local/airplane-ding-dong.mp3
media_content_type: "audio/mp3"
- delay: 00:00:01
- service: tts.google_translate_say
message: "Il microonde al primo piano ha terminato!"
How long is your ding-dong mp3?
Delay for that long (plus a bit just to confirm it works)
my ding dong lasts about 1 second
So delay for 5 (or even 10) seconds.
Just to prove to yourself that the principle works.
yes it worked.
first i tried it with 10 seconds and it made the sound.
so I went down to 5 seconds, up to 2 seconds which seems to be the minimum time to hear the sound.
I wanted to try 1.5 seconds but I don’t know how to set it with delay.
However, I do not know if it is a coincidence that it has to wait a little more than the duration of the mp3 to run.
You missed the whole wait part
- Wait for the state to become idle
https://www.home-assistant.io/docs/scripts#wait-template
- alias: "Wait until media player is stopped"
wait_template: "{{ is_state('media_player.floor', 'stop') }}"
Replace stop
with idle
or whatever it is for yours
Now that everything seems to work as I wanted, I realized that this function makes me comfortable on all the automations and packages that I have active.
How can I do to recall these lines with a simple command within the active automation?
should i create a script or a separate automation?
the last working code is the following:
volume_level: 0.7
media_content_id: https://xxxxx:xxx/local/dingdong.mp3
- delay: 00:00:03
volume_level: 0.5
to be inserted before my various “tts google translate say” of the respective automations.
I would put it in a script then call the script using
service: script.ding_dong
Calling it this way rather than `script.turn_on’ will cause your automation to stop processing until the script has ended.
This may however slightly affect the timing and cause a longer pause between the ding dong and the TTS (it my not be noticeable though) while the system waits for various states to catch up, you will have to experiment!
As you predicted, with the script I had to increase the delay from 2 seconds to 3 seconds, otherwise it didn’t work.
Not sure if it’s still relevant, but you can use the custom integration Chime TTS to fix the issue of lag between a local mp3 and cloud TTS audio.
