Journal issues with supervised install after updating to 2022.11
This is definitely new as I’ve been watching system-health quite a lot. For me, I started getting a systemd_journal with beta 7, beta 6 did not have this unhealthy situation. It may have started at a previous beta, but it certainly did not exist prior to any betas.
They was around since month, you just did not saw it anymore as this information got removed from UI at one point and now its back :slight_smile:
:+1:
I fixed it pretty quickly by re-installing systemd-journal-remote & rerunning the .deb script. Running an addblocker though, so it took longer than I expected because it killed my dns server and I had to temporarily use another one for the script to succeed.
True that one is really new. Most don’t see that one yet as it comes from this pr which has currently only in the beta release of supervisor.
But I guess my point was that none of the unhealthy/unsupported reasons were added by core. Supervisor still manages that. The only new thing here is that core asks supervisor if it is unhealthy/unsupported and shows a repair per reason.
Thanks for this new fine release! :thanks:
After updating I noticed a Supervisor update. That prompted an error and Repair entry saying…
Unsupported system - Systemd Journal issues
System is unsupported because Systemd Journal and/or the gateway service is missing, inactive or misconfigured . Use the link to learn more and how to fix this.
I’m running a Supervised Debian install (I’m not a Linux pro) for 2 years, rock solid, but following the link in the message, doesn’t help me. The commands aren’t recognized.
What should I do to fix this?
The commands work, you only need to install the last one anyways. But running all the commands will fix that issue.
apt-get install systemd-journal-remote -y
wget https://github.com/home-assistant/supervised-installer/releases/latest/download/homeassistant-supervised.deb
dpkg -i homeassistant-supervised.deb
I have exactly the same issue.
I followed the docs - re-run the supervised installer on the host to set up this service and reboot.
This did not help to resolve the issue.
Supervisor log says:
WARNING (MainThread) [supervisor.resolution.evaluations.base] Systemd journal is not working correctly or inaccessible
Host log can’t be loaded because of this issue:
No systemd-journal-gatewayd Unix socket available
Never had such problem before this release. HA, supervisor, OS-agent and Debian al are updated to todays latest versions.
I’m running out of idea’s…
Maybe I installed systemd-journal-gatewayd and then ran the script, either way, install then turn the service on. I used the script to turn the service on in case there were extra options I didn’t know about.
Then of course, I rebooted
root@ShuttleDomotica:~# apt-get install systemd-journal-remote -y
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
systemd-journal-remote is already the newest version (247.3-7+deb11u1).
The following packages were automatically installed and are no longer required:
  libbotan-2-17 libtspi1 linux-image-5.10.0-17-amd64
Use 'apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
The second two commands did work fine.
After restart, the issue is not solved, I get one more issue with network manager.
The reinstall of HA supervised removes the connectivity check. I know how to solve that.
So I repaired that, restart the host. Still unsupported because the systemd journal.
Knocking my head against the table. Again a issue, that never has been there and is introduced by an HA update… …there goes my lazy evening :slight_smile:
Have the same issue, tried reinstalling and rebooting many times, but the error remains.
I have the same problem *System is unsupported because Systemd Journal and/or the gateway service is missing, inactive or misconfigured * I’m using Debian 11 supervised install
I did
sudo apt install systemd-journal-remote
when I run
sudo systemctl status systemd-journal-gatewayd.service
I get this
● systemd-journal-gatewayd.service - Journal Gateway Service
     Loaded: loaded (/lib/systemd/system/systemd-journal-gatewayd.service; indirect; vendor preset: disabled)
     Active: active (running) since Thu 2022-11-03 19:16:50 CET; 8min ago
TriggeredBy: ● systemd-journal-gatewayd.socket
       Docs: man:systemd-journal-gatewayd(8)
   Main PID: 18663 (systemd-journal)
      Tasks: 2 (limit: 9334)
     Memory: 3.9M
     CGroup: /system.slice/systemd-journal-gatewayd.service
             └─18663 /lib/systemd/systemd-journal-gatewayd
Nov 03 19:16:50 homeassistant systemd[1]: Started Journal Gateway Service
but error in home doesnt go away. In supervisor I have this
22-11-03 19:20:54 ERROR (MainThread) [supervisor.host.logs] No systemd-journal-gatewayd Unix socket available
From the instructions in the link:
If using Home Assistant Supervised, re-run the supervised installer on the host to set up this service and reboot.
I mean you’re welcome to add the service manually like you did but you can’t skip the reboot step.
I just done step 4. a reinstall homeassistant-supervised.deb. Got a hassio error in logs.
Going for reboot.
Re installing docker did the trick for me :slight_smile:
I did this, see my message above. It does not help and even breaks the network manager as a side effect.
I installed debian-supervised and rebooted. Message went away but I still see lot of errors in my logs.
Should I reinstall docker?
Oh. Supervised installer has installing the gateway as a pre-req step. Ok going to update the doc then. Do what Daniel showed above instead:
When I rebooted I got this
     Active: inactive (dead)
Ok, didn’t know about. I was re-running the installer script, and - as it (now obviously!) didn’t help, I installed the systemd gateway service. Shoud I re-run again the installer script? Meanwhile my server hates me…
Thanks! Following these steps resolved the issue for me! :smiley:
I’m on Debian GNU/Linux 11 (bullseye) and supervisor-2022.10.2
