Juke Audio Juke-8 (Development)
@paulk1 - Juke Support fixed my issues. The Integration would not install on;
Home Assistant 2023.10.5
Supervisor 2023.11.3
Operating System 11.1
Frontend 20231005.0 - latest
just stalls
Also they moved to APIv2?
Alright, many changes to the install and the integration now loads, and
WOW
wonderful work.
Do you know if this will work with the juke+
Nothing comes up when i search the integrations for Juke… did they get rid of it?
how are you guys liking the Juke? I’ve been considering getting one… though, I only have 2 house zones I need it for (Living Room, and outside Deck). Can you control the music and stations using Alexa or Google Home? We really like being able to ask Alexa to play Spotify. Thx for the feedback
LOVE the JUKE!
The integration helps control Juke’s Zones (which input to output) and the Inputs What is being sent.
The ‘Control the music and station’ depends on what you are listening to.
As an example, ‘Spotify’ if you can control it today via a smart speaker, and you can send it to Juke, they YES you can.
This integration is so that you can turn off the outside deck via a smart speaker (if you built the integration in to HASS), or at 9pm every night, make sure the outside speakers are off, even if you are listening to something inside.
“Alexa, turn on Spotify Deck”
  • Helper I/O named “Spotify Deck” that was exposed to Amazon via Nabu
  • Automation set to trigger on Helper turning off to on
    — Tell Spotify to turn on to channel, X {I have never done this or know if it is possible}
    — Tell Juke to switch output “Deck” to Input “Spotify {this is what this integration is for}
If HASS can not control Spotify, then the Amazon Alexa might be able to, so you could just do two commands or set a scene that
“Alexa turn on Spotify Deck”
  • triggers a Amazon Scene
    — does what ever to turn on Spotify
    — turn on Helper exposed to Alexa from HASS that does the above.
Hope that helps
I’m working to get Juke setup on my new HA system. I can get the integration set up and populate my zones but I’m missing how to send Spotify to a zone or multiple zones. Is there a step by step guide on how to do that?
