On which machines are you running Ubuntu? I am thinking to move from Raspbian on RP4 4BG to Ubuntu on the same pi.
I am running “supervised” in Ubuntu 18.10. Is there a guide for updating to Ubuntu 20.04? I am not super fluent in this stuff but I can follow a guide.
Having same issue where do you add the qemux86-64?
No, it works fine.
I’m also thinking about upgrading 18.04 to 20.04. I’m running supervised (old hassio) on esxi. Did you encounter any problems with home assistant after the upgrade?
sudo snap install home-assistant-snap
per: Install Home Assistant on Ubuntu using the Snap Store | Snapcraft
To be clear, that command installs Home Assistant Core.
Reference: Compare Installation Methods
EDIT
Correction. Fixed link to Home Assistant’s documentation for installation methods.
The Reference link points to: 'snapcraft.io/home-assistant-snap
I would like to read this source for the chart. Please post?
Link in original post is now fixed. It leads to the first page of Home Assistant’s installation documentation.
Discord users convinced me to remove the HA Snap and reinstall with Container (Docker). Not difficult, but Snap was significantly easier. The chart provided by 123Taras would seem to favor HA-OS. Is it HA-OS Debian?
HAOS is Alpine Linux
