Hi everybody,
I just wanted to share a find regarding aqara cube and home assistant.
I have set a sort of “per room” automation, involving cube movements, and it works as follow (by now):
cube’s movements used are:
flip 90 degrees
flip 180 degrees
shake on air
move
rotate
double tap on table
Automations per room are set as:
- studio
- living room (with tv settings)
configuration is:
Flip 90 degrees:
- disables the “living room” scenes
- enables the “studio” scenes
Flip 180 degrees:
- enables the “living room” scenes
- disables the “studio” scenes
Studio scenes:
- move: toggle ceiling light
- rotate: dim light
- shake: toggle wall light
- double tap: turns heater on
Living room scenes:
- rotate: toggle night light
- shake: enter tv settings
Tv settings (via RM-Mini -ir hub-)
- move: volume up
- rotate: volume down
- flip 90: channel up
- flip 180: ok button
- double tap: exit tv settings (back to “living room” settings)
- shake: turn off tv
Example:
I am in the studio, turn the cube 90 degrees:
- move and turn on/off the light
want to move to the living room: - turn the cube 180 degrees:
now i want to turn tv on: - shake it to turn on tv and enter tv mode
- move to raise volume
- double tap to exit tv mode
- move to turn off living room light
What do you think about it?
