KeyMaster Z-Wave lock manager and scheduler
Okay, did some digging and found it under:
/config/packages/lock-manager/frontdoor/frontdoor_lock_manager_common.yaml
Is that the right one?
Looks like it. This discussion was had just a few posts before yours. Click on the link in my quote.
Get it working?
Thanks for following up @mcoleman001. Unfortunately it didn’t work. I updated the file, restarted HA, and used a code to unlock the door but still no notifications. When I have some more time, I’ll dig into the logs.
So here is what’s coming up in the log:
2020-04-21 15:57:35 ERROR (MainThread) [homeassistant.components.automation] FrontDoor Notifications: Error executing script. Service not found for call_service at pos 1: Unable to find service script/conditional_notify
Here is what’s in /config/packages/lock-manager/frontdoor/frontdoor_lock_manager_common.yaml
################  COMMON ENTITIES  ###############
###############  input_boolean:  #################
input_boolean:
  frontdoor_lock_notifications:
    name: "Lock Notifications"
  frontdoor_dooraccess_notifications:
    name: "Door Notifications"
  frontdoor_garageacess_notifications:
    name: "Garage Notifications"
  frontdoor_reset_lock:
    name: "frontdoor reset lock"
############## binary_sensor:  ####################
binary_sensor:
  sensors:
    dummy_sensor_factory_access_control_dummy_sensor:
      value_template: "{{ is_state('sensor.dummy_sensor_factory_access_control_dummy_sensor', '22') }}"
      friendly_name: "dummy_sensor"
      device_class: door
    dummy_sensor_factory_burglar_dummy_sensor:
      value_template: "{{ is_state('sensor.dummy_sensor_factory_burglar_dummy_sensor', '3') }}"
      friendly_name: "dummy_sensor Sensor Tamper"
      device_class: safety
###################  sensor:  ####################
- platform: time_date
  display_options:
    - 'time'
    - 'date'
    - 'date_time'
    - 'date_time_iso'
    - 'time_date'
    - 'time_utc'
    - 'beat'
  sensors:
    frontdoor_statusreport:
      friendly_name: 'frontdoor Status Report'
      value_template: >
          {% set number = states('sensor.schlage_allegion_be468_touchscreen_deadbolt_alarm_level_frontdoor') %}
          {% set alarm_type_value = states('sensor.schlage_allegion_be468_touchscreen_deadbolt_alarm_type_frontdoor') %}
          {% if ((as_timestamp(now())-as_timestamp(states.lock.schlage_allegion_be468_touchscreen_deadbolt_locked_frontdoor.last_changed)) < 15 and (as_timestamp(now())-as_timestamp(states.sensor.schlage_allegion_be468_touchscreen_deadbolt_alarm_type_frontdoor.last_changed)) > 15) %}
          {%    if (states.lock.schlage_allegion_be468_touchscreen_deadbolt_locked_frontdoor.state) == 'locked' %}
          {%       set alarm_type_value = '24' %}
          {%    elif (states.lock.schlage_allegion_be468_touchscreen_deadbolt_locked_frontdoor.state) == 'unlocked' %}
          {%       set alarm_type_value = '25' %}
          {%    endif %}
          {% endif %}
          {% set alarm_type_general_actions = {
            '0':'No Status Reported',
            '9':'Lock Jammed',
            '17':'Keypad Lock Jammed',
            '21':'Manual Lock',
            '22':'Manual Unlock',
            '23':'HA Lock Jammed',
            '24':'HA Lock',
            '25':'HA Unlock',
            '26':'Auto Lock Jammed',
            '27':'Auto Lock',
            '32':'All Codes Deleted',
            '161':'Bad Code Entered',
            '167':'Battery Low',
            '168':'Battery Critical',
            '169':'Battery Too Low To Operate Lock' } %}
          {% set alarm_type_lock_actions = {
            '18':'Keypad Lock',
            '19':'Keypad Unlock',
            '162':'Lock Code Attempt Outside of Schedule' } %}
          {% set alarm_type_code_actions = {
            '33':'Code Deleted',
            '112':'Code Changed',
            '113':'Duplicate Code' } %}
          {% if alarm_type_value in alarm_type_code_actions %}
            {{alarm_type_value}};{{ alarm_type_code_actions[alarm_type_value] }};{{number}}
          {% elif alarm_type_value in alarm_type_lock_actions  %}
            {{alarm_type_value}};{{ alarm_type_lock_actions[alarm_type_value] }};{{number}}
          {% elif alarm_type_value in alarm_type_general_actions %}
            {{alarm_type_value}};{{ alarm_type_general_actions[alarm_type_value] }}
          {% else %}
            {{-1}};Unknown Alarm Type Value {{ states('sensor.schlage_allegion_be468_touchscreen_deadbolt_alarm_type_frontdoor') }}
          {% endif %}
###################  script    :  ####################
script:
    sequence:
      - service: script.frontdoor_manual_notify
        data_template:
          title: "reset"
          message: "frontdoor"
  frontdoor_conditional_notify:
    sequence:
      - condition: template
        value_template: >-
          {% set inputbool = boolean %}
          {% if states(inputbool) == 'on'%}
            true
          {% else %}
            false
          {% endif %}
        data_template:
          title: "{{title}}"
          message: "{{message}}"
  frontdoor_manual_notify:
    sequence:
      - service: notify.notify
        data_template:
          title: "{{title}}"
###################  automation:  ####################
automation:
    - alias: FrontDoor Notifications
        platform: state
        entity_id: sensor.frontdoor_statusreport
      condition:
        - condition: state
          entity_id: 'binary_sensor.allow_automation'
          state: 'on'
          value_template: >-
            {% set report = states.sensor.frontdoor_statusreport.state %}
            {% set a = report.split(';') %}
            {% if (a|length) != 3 or (a[2] == "0") %}
              {{ true }}
            {% else %}
              {{ true }}
            {% endif %}
        - service: script.conditional_notify
          data_template:
            boolean: input_boolean.frontdoor_lock_notifications
            title: "Sensor Status Report"
            message: >-
              {% set msg = "ID:" + a[0] + " MSG:" + a[1] %}
              {% if (a|length) == 3 %}
              {%   set msg = msg + " SLOT:" + a[2] %}
              {% endif %}
              {{ a[1] }}
    - alias: FrontDoor User Notifications
        platform: state
      condition:
        - condition: state
          state: 'on'
          value_template: >-
            {% if (a|length) == 3 and (a[2] | int > 0) %}
              {{ true }}
            {% else %}
              {{ false }}
            {% endif %}
          value_template: >-
            {% set entity_id = 'notify_frontdoor_' + a[2] %}
            {% set notify = states['input_boolean'][entity_id].state %}
            {{ notify == "on" }}
        - service: script.manual_notify
          data_template:
            title: >-
              {{ a[1] }}
            message: >-
              {% set entity_id = 'input_text.frontdoor_name_' + a[2] %}
              {% set user = states(entity_id) %}
              {{ user }}
    - alias: dummy_sensor Sensor Close
      condition:
        - condition: state
          state: 'on'
        entity_id: binary_sensor.dummy_sensor_factory_access_control_dummy_sensor
        platform: state
        to: 'off'
          data_template:
            boolean: input_boolean.frontdoor_dooraccess_notifications
            title: "dummy_sensor"
            message: "Closed"
    - alias: dummy_sensor Sensor Opened
      condition:
        - condition: state
          state: 'on'
        platform: state
        to: 'on'
          data_template:
            message: "Opened"
    - alias: FrontDoor Add Code
      condition:
        - condition: state
          state: 'on'
        entity_id: binary_sensor.active_frontdoor_1, binary_sensor.active_frontdoor_2, binary_sensor.active_frontdoor_3, binary_sensor.active_frontdoor_4, binary_sensor.active_frontdoor_5, binary_sensor.active_frontdoor_6
        platform: state
        to: 'on'
        - service: lock.set_usercode
          data_template:
            node_id: >-
                {{states.lock.schlage_allegion_be468_touchscreen_deadbolt_locked_frontdoor.attributes.node_id}}
            code_slot: >-
                {% set object_id = trigger.to_state.object_id %}
                {% set index = 17 %}
                {% set code_slot = object_id[index:] %}
                {{ code_slot  }}
            usercode: >-
                {% set codetext = 'frontdoor_pin_' + code_slot | string %}
                {% set code = states['input_text'][codetext].state %}
                {{ code | string }}
    - alias: FrontDoor Update Code
        entity_id: input_text.frontdoor_pin_1, input_text.frontdoor_pin_2, input_text.frontdoor_pin_3, input_text.frontdoor_pin_4, input_text.frontdoor_pin_5, input_text.frontdoor_pin_6
        platform: state
      condition:
        - condition: state
          state: 'on'
          value_template: >-
            {% set index = 14 %}
            {% set b = 'input_boolean.enabled_frontdoor_' + code_slot | string %}
            {{ is_state(b, 'on') and (trigger.from_state.state != trigger.to_state.state)}}
        - service: persistent_notification.create
          data_template:
            title: "frontdoor LOCK MANAGER"
            message: >-
              {{ 'You changed the PIN for code  ' + code_slot | string + '. Please enable it in order to make it active.'}}
        - service: input_boolean.turn_off
          data_template:
            entity_id: >-
              {{ 'input_boolean.enabled_frontdoor_' + code_slot | string }}
    - alias: Reset FrontDoor
      condition:
        - condition: state
          state: 'on'
        entity_id: input_boolean.frontdoor_reset_lock
        platform: state
        to: 'on'
        - service: script.frontdoor_reset_lock
    - alias: FrontDoor Clear Code
      condition:
        - condition: state
          state: 'on'
        platform: state
        to: 'off'
        # - service: lock.clear_usercode
        #   data_template:
        #     node_id: >-
        #         {{states.lock.schlage_allegion_be468_touchscreen_deadbolt_locked_frontdoor.attributes.node_id}}
        #     code_slot: >-
        #         {% set object_id = trigger.to_state.object_id %}
        #         {% set index = 17 %}
        #         {% set code_slot = object_id[inex:] %}
        #         {{ code_slot  }}
          data_template:
            node_id: >-
            code_slot: >-
              {{ code_slot  }}
            usercode: >-
              {{ range(1000, 9999) | random | int }}
    - alias: FrontDoor Decrement Access Count
        platform: state
      condition:
        - condition: state
          state: 'on'
          value_template: >-
               {{ (a[0] | int == 19) }}
            {% else %}
              {{ false }}
            {% endif %}
        - service: input_number.decrement
          data_template:
            entity_id: >-
              {{ 'input_number.accesscount_frontdoor_' + a[2] }}
Now if I go to developer tools and manually call script.frontdoor_manual_notify it works, but script.frontdoor_conditional_notify does not.
Any ideas how to fix, this or further narrow it down?
Did you ever get this working? I am having the exact same issue.
automation:
        platform: state
      condition:
        - condition: state
          state: 'on'
          value_template: >-
              {{ true }}
            {% else %}
              {{ true }}
            {% endif %}
          data_template:
            message: >-
              {% endif %}
              {{ a[1] }}
You need to adjust the service after the action like so:
        - service: script.frontdoor_conditional_notify
          data_template:
            message: >-
              {% endif %}
              {{ a[1] }}
Also:
        platform: state
      condition:
        - condition: state
          state: 'on'
          value_template: >-
              {{ true }}
            {% else %}
              {{ false }}
            {% endif %}
          value_template: >-
          data_template:
            title: >-
              {{ a[1] }}
            message: >-
              {{ user }}
Needs a modification to:
          data_template:
            title: >-
              {{ a[1] }}
            message: >-
              {{ user }}
Post your packages/lock-manager/frontdoor/frontdoor_lock_manager_common.yaml file for help.
Thank you @firstof9. I made the changes and will give it a test when I get home this afternoon. The script.sh may need to be updated, to prevent this from happening for others.
Yes, that did the trick, thank you. I’m very excited that I got it working. If possible I would suggest that the notifications include who locked/unlocked the door.
Based on what I’m reading from the script, it should notify you of who unlocked/locked the door.
Strange, I went back to do it again so I could send you a screenshot but this time it did send the User. Thanks anyway.
No, unfortunately – I ended up re-installing hassio to fix everything. Also, even with just 3 lock widgets it dramatically slowed things down, so I’ll probably look for other options for right now…
Think I am getting closer to having this working. I attempted to set a user code in slot one through the gui and here is the error messages in the logs:
Adding a code:
BackDoor Add Code: Error executing script. Unexpected error for call_service at pos 1: Error rendering data template: str: Invalid entity ID ‘input_text.backdoor_pin_’
Trying to clear a code:
BackDoor Clear Code: Error executing script. Invalid data for call_service at pos 1: expected int for dictionary value @ data[‘code_slot’]
Using lock.set_usercode in states works fine. No errors there.
Post your backdoor.yaml
Hopefully this is what you are looking for
input_boolean:
  backdoor_lock_notifications:
  backdoor_dooraccess_notifications:
  backdoor_garageacess_notifications:
  backdoor_reset_lock:
    name: "backdoor reset lock"
binary_sensor:
  sensors:
    schlage_allegion_be469_touchscreen_deadbolt_access_control_backdoor:
      value_template: "{{ is_state('sensor.schlage_allegion_be469_touchscreen_deadbolt_access_control_backdoor', '22') }}"
      friendly_name: "BackDoor"
      device_class: door
    schlage_allegion_be469_touchscreen_deadbolt_burglar_backdoor:
      value_template: "{{ is_state('sensor.schlage_allegion_be469_touchscreen_deadbolt_burglar_backdoor', '3') }}"
      friendly_name: "BackDoor Sensor Tamper"
  display_options:
    - 'time'
    - 'date'
    - 'date_time'
    - 'date_time_iso'
    - 'time_date'
    - 'time_utc'
    - 'beat'
  sensors:
    backdoor_statusreport:
      friendly_name: 'backdoor Status Report'
      value_template: >
          {% set number = states('sensor.schlage_allegion_be469_touchscreen_deadbolt_alarm_level_backdoor') %}
          {% set alarm_type_value = states('sensor.schlage_allegion_be469_touchscreen_deadbolt_alarm_type_backdoor') %}
          {% if ((as_timestamp(now())-as_timestamp(states.lock.schlage_allegion_be469_touchscreen_deadbolt_backdoor.last_changed)) < 15 and (as_timestamp(now())-as_timestamp(states.sensor.schlage_allegion_be469_touchscreen_deadbolt_alarm_type_backdoor.last_changed)) > 15) %}
          {%    if (states.lock.schlage_allegion_be469_touchscreen_deadbolt_locked_backdoor.state) == 'locked' %}
          {%    elif (states.lock.schlage_allegion_be469_touchscreen_deadbolt_locked_backdoor.state) == 'unlocked' %}
          {%    endif %}
          {% endif %}
            '9':'Lock Jammed',
            '21':'Manual Lock',
            '24':'HA Lock',
            '25':'HA Unlock',
            '27':'Auto Lock',
            '18':'Keypad Lock',
          {% else %}
            {{-1}};Unknown Alarm Type Value {{ states('sensor.schlage_allegion_be469_touchscreen_deadbolt_alarm_type_backdoor') }}
          {% endif %}
script:
    sequence:
      - service: script.backdoor_manual_notify
        data_template:
          title: "reset"
          message: "backdoor"
  backdoor_conditional_notify:
    sequence:
        value_template: >-
            true
          {% else %}
            false
          {% endif %}
        data_template:
          title: "{{title}}"
  backdoor_manual_notify:
    sequence:
      - service: notify.my_devices
        data_template:
          title: "{{title}}"
automation:
    - alias: BackDoor Notifications
        platform: state
        entity_id: sensor.backdoor_statusreport
      condition:
        - condition: state
          state: 'on'
          value_template: >-
            {% set report = states.sensor.backdoor_statusreport.state %}
              {{ true }}
            {% else %}
              {{ true }}
            {% endif %}
          data_template:
            boolean: input_boolean.backdoor_lock_notifications
            message: >-
              {% endif %}
              {{ a[1] }}
    - alias: BackDoor User Notifications
        platform: state
      condition:
        - condition: state
          state: 'on'
          value_template: >-
              {{ true }}
            {% else %}
              {{ false }}
            {% endif %}
          value_template: >-
            {% set entity_id = 'notify_backdoor_' + a[2] %}
          data_template:
            title: >-
              {{ a[1] }}
            message: >-
              {% set entity_id = 'input_text.backdoor_name_' + a[2] %}
              {{ user }}
    - alias: BackDoor Sensor Close
      condition:
        - condition: state
          state: 'on'
        entity_id: binary_sensor.schlage_allegion_be469_touchscreen_deadbolt_access_control_backdoor
        platform: state
        to: 'off'
          data_template:
            boolean: input_boolean.backdoor_dooraccess_notifications
            title: "BackDoor"
            message: "Closed"
    - alias: BackDoor Sensor Opened
      condition:
        - condition: state
          state: 'on'
        platform: state
        to: 'on'
          data_template:
            title: "BackDoor"
            message: "Opened"
    - alias: BackDoor Add Code
      condition:
        - condition: state
          state: 'on'
        entity_id: binary_sensor.active_backdoor_1, binary_sensor.active_backdoor_2
        platform: state
        to: 'on'
          data_template:
            node_id: >-
                {{states.lock.schlage_allegion_be469_touchscreen_deadbolt_backdoor.attributes.node_id}}
            code_slot: >-
                {{ code_slot  }}
            usercode: >-
                {% set codetext = 'backdoor_pin_' + code_slot | string %}
                {{ code | string }}
    - alias: BackDoor Update Code
        entity_id: input_text.backdoor_pin_1, input_text.backdoor_pin_2
        platform: state
      condition:
        - condition: state
          state: 'on'
          value_template: >-
            {% set b = 'input_boolean.enabled_backdoor_' + code_slot | string %}
          data_template:
            title: "backdoor LOCK MANAGER"
            message: >-
          data_template:
            entity_id: >-
              {{ 'input_boolean.enabled_backdoor_' + code_slot | string }}
    - alias: Reset BackDoor
      condition:
        - condition: state
          state: 'on'
        entity_id: input_boolean.backdoor_reset_lock
        platform: state
        to: 'on'
        - service: script.backdoor_reset_lock
    - alias: BackDoor Clear Code
      condition:
        - condition: state
          state: 'on'
        platform: state
        to: 'off'
        #   data_template:
        #     node_id: >-
        #         {{states.lock.schlage_allegion_be469_touchscreen_deadbolt_backdoor.attributes.node_id}}
        #     code_slot: >-
        #         {{ code_slot  }}
          data_template:
            node_id: >-
            code_slot: >-
              {{ code_slot  }}
            usercode: >-
    - alias: BackDoor Decrement Access Count
        platform: state
      condition:
        - condition: state
          state: 'on'
          value_template: >-
            {% else %}
              {{ false }}
            {% endif %}
          data_template:
            entity_id: >-
              {{ 'input_number.accesscount_backdoor_' + a[2] }}
Here’s your fix replace the automations as listed:
      condition:
        - condition: state
          state: 'on'
        platform: state
        to: 'on'
          data_template:
            node_id: >-
            code_slot: >-
                {% set index = -1 %}
                {{ code_slot  }}
            usercode: >-
                {{ code | string }}
and
      condition:
        - condition: state
          state: 'on'
        platform: state
        to: 'off'
        #   data_template:
        #     node_id: >-
        #     code_slot: >-
        #         {{ code_slot  }}
          data_template:
            node_id: >-
            code_slot: >-
              {{ code_slot }}
            usercode: >-
Should fix you right up.
Perfect! That worked! Thank you so much.
I’m thinking you can go thru your yamls and change any index = whatever to index = -1.
Maybe leave this post here for others to use as well. :smiley:
