Hello, I wanted to come back around to this addon as the last time I tried it a few months ago, it never worked correctly with my lock (BE469WK V CAM 619). It’s unclear as to why this is (if it was a HA, addon, or zwave issue), but I wanted to link this dude’s github that was used on SmartThings: https://github.com/ethayer/lock-manager
I know that they are completely different technologies and nothing might be gained from it, but I wanted to pass this along in case there was anything that could be gleaned from it that might help in situations where the Schlage BE469 locks were involved, as mine always worked flawlessly with those.
Feel free to ignore this if you don’t think it’s helpful!
I initially installed my front door lock (Schlage BE469ZP) in Feb 2020 and set it up in Home Assistant. The first time I had to replace the batteries was in Feb of this year. Now I have replaced them in May & in August. They only seem to be lasting around 3 months now.
Has anyone else seen this happen? I am not suggesting it is anything to do with this project just curious why all of a sudden I would see this sudden consistent battery drain
All I have currently in my config is the USB path and the network key. Maybe someone else can comment is the polling_intensity line neccessary (it states default: 0 which is no polling)
I am running core-2021.9.7, OS 6.4, with zwavejs2mqtt 0.25.0 and the zwave integration talking to zwavejs2mqtt over websockets. I just upgraded to the above from the legacy zwave 1.4 implementation. I copied my key from the original implementation into the S0 legacy key in zwavejs2mqtt. All of my devices have reappeared and are connected to home assistant.
I have two Yale Security YRD226 locks. Both of them were working perfectly with KeyMaster and the old zwave implementation. Now they show up in zwavejs2mqtt with security ‘S0_Legacy’. However the only entities that show up in home assistant are: lock.front_door_lock, sensor.front_door_lock_node_status, binary_sensor.front_door_lock_the_current_status_of_the_door and I can’t even lock and unlock the lock using lock.front_door_lock.
Any thought on what I need to do to get KeyMaster to work with my locks again? Do I need to rejoin these devices with S2 security?
I am looking to change the auto-lock timeouts for my locks from the default 15min and 5min to 1min and 30 seconds respectively. I have tried changing their respective input text values (input_text.keymaster_front_door_autolock_door_time_day and input_text.keymaster_front_door_autolock_door_time_night) from the lovelace badges which works for about a day and then they get reset for some reason back to 15 and 5. Is this the right place to change the timer lengths or is there somewhere else I should look?
Hi. I have a question about the door sensor in the lock configuration. I have an Elk M1 alarm system that has sensors for all my doors. The values of these sensors is either normal or violated, and none of the alarm sensors are available in the entity autofill entry for the door sensor in the lock config. These locks are Yale YRM476 type, and they don’t have a door state sensor available from the lock.
What should I do to be able to use the door sensors on my alarm? I guess I can try and make a binary sensor based on the value of the alarm sensor, but how should it be defined? On = door open or door closed, etc…?
Thanks. I think I can make a template automation to translate normal/violated to off/on. BTW, does keymaster only allow the use of binary sensors for door status?
